See <http://ares.opengeo.org/jenkins/job/geoserver-master/1002/changes>
Changes:
[tbarsballe] Test fixes for gt-property-ng migration
[...truncated 21683 lines...]
<BoundingBox SRS="EPSG:900913" minx="-2.003750834E7" miny="-2.003750834E7" maxx="2.003750834E7" maxy="2.003750834E7"/>
<BoundingBox SRS="EPSG:4326" minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/>
</Layer>
<Layer queryable="1">
<Name>cite:MapNeatline</Name>
<Title>MapNeatline</Title>
<Abstract>abstract about MapNeatline</Abstract>
<SRS>EPSG:4326</SRS>
<SRS>EPSG:900913</SRS>
<LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/>
</Layer>
<Name>cite:Forests</Name>
<Title>Forests</Title>
<Abstract>abstract about Forests</Abstract>
</Layer>
<Name>cite:RoadSegments</Name>
<Title>RoadSegments</Title>
<Abstract>abstract about RoadSegments</Abstract>
</Layer>
<Name>cdf:Fifteen</Name>
<Title>Fifteen</Title>
<Abstract>abstract about Fifteen</Abstract>
</Layer>
<Name>cdf:Other</Name>
<Title>Other</Title>
<Abstract>abstract about Other</Abstract>
</Layer>
<Name>cite:Buildings</Name>
<Title>Buildings</Title>
<Abstract>abstract about Buildings</Abstract>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.227 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Jan 10, 2015 1:42:32 AM org.geoserver.config.impl.GeoServerImpl getService
SEVERE: Could not locate service of type interface org.geoserver.wps.WPSInfo, local workspace is null
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.165 sec
Results :
Tests in error:
testImportBuildings(org.geoserver.wps.gs.ImportProcessTest): Failed to import data into the target store
Tests run: 195, Failures: 0, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.993s]
[INFO] Core Platform Module .............................. SUCCESS [14.940s]
[INFO] Open Web Service Module ........................... SUCCESS [16.744s]
[INFO] Main Module ....................................... SUCCESS [3:16.673s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.643s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:15.604s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.708s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.008s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:15.615s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:22.244s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.292s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:35.827s]
[INFO] Web Map Service Module ............................ SUCCESS [7:00.044s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.106s]
[INFO] REST Support Module ............................... SUCCESS [45.696s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.562s]
[INFO] Core UI Module .................................... SUCCESS [2:34.946s]
[INFO] WFS UI Module ..................................... SUCCESS [46.339s]
[INFO] Security UI Modules ............................... SUCCESS [0.397s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.239s]
[INFO] Printing Module ................................... SUCCESS [36.157s]
[INFO] Community Space ................................... SUCCESS [0.240s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.528s]
[INFO] Application Schema Support ........................ SUCCESS [0.151s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.779s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.159s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.357s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.138s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.537s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.294s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.529s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.950s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.640s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.775s]
[INFO] Excel Output Format ............................... SUCCESS [37.741s]
[INFO] Chart external graphics support ................... SUCCESS [1.622s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.253s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.697s]
[INFO] OWS request flow controller ....................... SUCCESS [29.546s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.318s]
[INFO] Web Processing Service Module ..................... FAILURE [5:17.076s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.557s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.941s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.139s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.312s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.170s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.143s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [31.202s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.215s]
[INFO] DXF WFS output format ............................. SUCCESS [37.316s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.206s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.411s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:44.721s (Wall Clock)
[INFO] Finished at: Sat Jan 10 01:42:46 UTC 2015
[INFO] Final Memory: 61M/182M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
