[Geoserver-devel] Build failed in Jenkins: geoserver-master #1033
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1033/changes&gt;
Changes:
[andrea.aime] [GEOS-6771] wmsGetFeatureInfo Request in 2.5, 2.6 doesnt work on TextSymbolizers
[...truncated 19231 lines...]
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in Web Processing Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 63.9 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 41.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
913/981 B
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 50.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 41.3 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6771] wmsGetFeatureInfo Request in 2.5, 2.6 doesnt work on TextSymbolizers
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.01.2015 @ 21:46:25 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Jan-2015 21:47
[INFO] [GitCommitIdMojo] build.build.time = 17.01.2015 @ 22:05:55 UTC
[INFO] [GitCommitIdMojo] build.branch = 36c75182066c358ac4629fa1c648c10e1fc4e16c
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 36c7518
[INFO] [GitCommitIdMojo] build.commit.id = 36c75182066c358ac4629fa1c648c10e1fc4e16c
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6771] wmsGetFeatureInfo Request in 2.5, 2.6 doesnt work on TextSymbolizers
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 10 resources
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 186 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/classes&gt;
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 28.965 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 14 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 56 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/test-classes&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.487 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.016 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt;
T E S T S
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.792 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Running org.geoserver.wps.DescribeProcessTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.127 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.73 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.98 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.751 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.246 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.823 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.543 sec
Results :
Tests in error:
  testTwoRules(org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest): Could not load pureLabel.sld from scope class org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest.
  testPureLabelGenericGeometry(org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest): Invalid JSON String
  testPureLabelPolygon(org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest): Invalid JSON String
Tests run: 667, Failures: 0, Errors: 3, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 33.03 sec
Running org.geoserver.wps.ExecuteTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.008s]
[INFO] Core Platform Module .............................. SUCCESS [14.670s]
[INFO] Open Web Service Module ........................... SUCCESS [16.521s]
[INFO] Main Module ....................................... SUCCESS [3:17.052s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.954s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:16.193s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [42.430s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.562s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.483s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.363s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.321s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:36.962s]
[INFO] Web Map Service Module ............................ FAILURE [7:24.881s]
[INFO] REST Support Module ............................... SUCCESS [47.427s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.482s]
[INFO] Core UI Module .................................... SUCCESS [2:26.141s]
[INFO] WFS UI Module ..................................... SUCCESS [44.768s]
[INFO] Security UI Modules ............................... SUCCESS [0.415s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.260s]
[INFO] Printing Module ................................... SUCCESS [36.885s]
[INFO] Community Space ................................... SUCCESS [0.232s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.211s]
[INFO] Application Schema Support ........................ SUCCESS [0.148s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.128s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.174s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.222s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.033s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.540s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.262s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.467s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.321s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.416s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.363s]
[INFO] Excel Output Format ............................... SUCCESS [38.566s]
[INFO] Chart external graphics support ................... SUCCESS [1.436s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.594s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.745s]
[INFO] OWS request flow controller ....................... SUCCESS [28.716s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.253s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.888s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.639s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.974s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.220s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.657s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.354s]
[INFO] DXF WFS output format ............................. SUCCESS [38.354s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.257s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:15.511s (Wall Clock)
[INFO] Finished at: Sat Jan 17 22:06:52 UTC 2015
[INFO] Final Memory: 57M/160M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1034/&gt;
[...truncated 19238 lines...]
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 20.0 KB/sec)
913/976 B
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 45.4 KB/sec)
981/981 B
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 32.7 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2015 02:58
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2015 @ 03:17:27 UTC
[INFO]
[INFO]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 22.867 sec
[INFO]
[INFO]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.388 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.134 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.632 sec
[INFO]
T E S T S
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.668 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.693 sec
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.026 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.676 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.319 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.168 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.615 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.084s]
[INFO] Core Platform Module .............................. SUCCESS [15.001s]
[INFO] Open Web Service Module ........................... SUCCESS [16.348s]
[INFO] Main Module ....................................... SUCCESS [3:17.518s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.799s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:22.264s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.683s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.389s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:12.110s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:24.680s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.886s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:36.029s]
[INFO] Web Map Service Module ............................ FAILURE [7:23.702s]
[INFO] REST Support Module ............................... SUCCESS [44.445s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.596s]
[INFO] Core UI Module .................................... SUCCESS [2:27.096s]
[INFO] WFS UI Module ..................................... SUCCESS [44.727s]
[INFO] Security UI Modules ............................... SUCCESS [0.305s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.238s]
[INFO] Printing Module ................................... SUCCESS [36.755s]
[INFO] Community Space ................................... SUCCESS [0.429s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.808s]
[INFO] Application Schema Support ........................ SUCCESS [0.139s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.993s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.473s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.509s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.124s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.513s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.532s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.453s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.074s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.386s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.923s]
[INFO] Excel Output Format ............................... SUCCESS [39.384s]
[INFO] Chart external graphics support ................... SUCCESS [2.632s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.237s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.898s]
[INFO] OWS request flow controller ....................... SUCCESS [28.817s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.218s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.030s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.541s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [43.356s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.161s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.934s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.200s]
[INFO] DXF WFS output format ............................. SUCCESS [36.655s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.200s]
[INFO] Total time: 19:24.988s (Wall Clock)
[INFO] Finished at: Sun Jan 18 03:18:17 UTC 2015
[INFO] Final Memory: 57M/174M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1035/changes&gt;
Changes:
[jody.garnett] placeholder sld to fix the build
[...truncated 19190 lines...]
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 41.7 KB/sec)
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 95.3 KB/sec)
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 68.4 KB/sec)
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 94.9 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = placeholder sld to fix the build
[INFO] [GitCommitIdMojo] build.commit.time = 18.01.2015 @ 05:57:46 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2015 06:02
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2015 @ 06:20:58 UTC
[INFO] [GitCommitIdMojo] build.branch = e728de97f65f19431e748b456d9a21ef891c9bdb
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e728de9
[INFO] [GitCommitIdMojo] build.commit.id = e728de97f65f19431e748b456d9a21ef891c9bdb
[INFO] [GitCommitIdMojo] build.commit.message.full = placeholder sld to fix the build
[INFO]
[INFO]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.851 sec
[INFO]
[INFO]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.219 sec
[INFO]
T E S T S
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.626 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.921 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.593 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.267 sec
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.248 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.176 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.451 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.512 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 35.334 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.865 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.039s]
[INFO] Core Platform Module .............................. SUCCESS [15.559s]
[INFO] Open Web Service Module ........................... SUCCESS [15.868s]
[INFO] Main Module ....................................... SUCCESS [3:17.124s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.750s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.586s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.976s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.058s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.207s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:21.469s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.259s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:41.752s]
[INFO] Web Map Service Module ............................ FAILURE [7:30.097s]
[INFO] REST Support Module ............................... SUCCESS [41.288s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.393s]
[INFO] Core UI Module .................................... SUCCESS [2:28.075s]
[INFO] WFS UI Module ..................................... SUCCESS [43.242s]
[INFO] Security UI Modules ............................... SUCCESS [0.443s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.167s]
[INFO] Printing Module ................................... SUCCESS [35.285s]
[INFO] Community Space ................................... SUCCESS [0.194s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.105s]
[INFO] Application Schema Support ........................ SUCCESS [0.196s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.931s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.124s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.324s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.017s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.548s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.287s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.353s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.090s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.618s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.832s]
[INFO] Excel Output Format ............................... SUCCESS [37.541s]
[INFO] Chart external graphics support ................... SUCCESS [1.386s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.557s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.754s]
[INFO] OWS request flow controller ....................... SUCCESS [34.763s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.331s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.416s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.106s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [44.425s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.293s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.874s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.222s]
[INFO] DXF WFS output format ............................. SUCCESS [38.073s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.327s]
[INFO] Total time: 19:29.298s (Wall Clock)
[INFO] Finished at: Sun Jan 18 06:22:08 UTC 2015
[INFO] Final Memory: 57M/190M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1036/&gt;
[...truncated 19317 lines...]
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 73.7 KB/sec)
913/976 B
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 79.4 KB/sec)
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 87.1 KB/sec)
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 86.3 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2015 06:57
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2015 @ 07:15:49 UTC
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 31.232 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.316 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.39 sec
[INFO]
T E S T S
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.543 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.602 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.135 sec
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.508 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.705 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.724 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.43 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 36.169 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.176 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.899s]
[INFO] Core Platform Module .............................. SUCCESS [14.550s]
[INFO] Open Web Service Module ........................... SUCCESS [18.523s]
[INFO] Main Module ....................................... SUCCESS [3:15.356s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.839s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:16.534s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [42.373s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.933s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.955s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.676s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.118s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:38.474s]
[INFO] Web Map Service Module ............................ FAILURE [7:37.224s]
[INFO] REST Support Module ............................... SUCCESS [41.386s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.368s]
[INFO] Core UI Module .................................... SUCCESS [2:32.283s]
[INFO] WFS UI Module ..................................... SUCCESS [44.834s]
[INFO] Security UI Modules ............................... SUCCESS [0.391s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.181s]
[INFO] Printing Module ................................... SUCCESS [33.321s]
[INFO] Community Space ................................... SUCCESS [0.226s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.436s]
[INFO] Application Schema Support ........................ SUCCESS [0.181s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.909s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.626s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.408s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.011s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.203s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.300s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.280s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.092s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.489s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.680s]
[INFO] Excel Output Format ............................... SUCCESS [39.621s]
[INFO] Chart external graphics support ................... SUCCESS [1.555s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.857s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.058s]
[INFO] OWS request flow controller ....................... SUCCESS [31.401s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.139s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.300s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.949s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.358s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.243s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.959s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.312s]
[INFO] DXF WFS output format ............................. SUCCESS [38.365s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.137s]
[INFO] Total time: 19:30.697s (Wall Clock)
[INFO] Finished at: Sun Jan 18 07:16:56 UTC 2015
[INFO] Final Memory: 58M/200M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1037/changes&gt;
Changes:
[andrea.aime] The real sld file
[...truncated 19291 lines...]
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 87.1 KB/sec)
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 47.7 KB/sec)
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 106.4 KB/sec)
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 105.5 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = The real sld file
[INFO] [GitCommitIdMojo] build.commit.time = 18.01.2015 @ 07:38:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2015 07:47
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2015 @ 08:05:38 UTC
[INFO] [GitCommitIdMojo] build.branch = e190e9ef77c9755f1e0ab3e5f343cbe6fb1340a9
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e190e9e
[INFO] [GitCommitIdMojo] build.commit.id = e190e9ef77c9755f1e0ab3e5f343cbe6fb1340a9
[INFO] [GitCommitIdMojo] build.commit.message.full = The real sld file
[INFO]
[INFO]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.184 sec
[INFO]
[INFO]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.158 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.587 sec
[INFO]
T E S T S
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.007 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.923 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.402 sec
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.653 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.223 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.418 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.227 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 36.931 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.736 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.481s]
[INFO] Core Platform Module .............................. SUCCESS [15.817s]
[INFO] Open Web Service Module ........................... SUCCESS [15.836s]
[INFO] Main Module ....................................... SUCCESS [3:20.747s]
[INFO] GeoServer Security Modules ........................ SUCCESS [3.076s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:25.434s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.986s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.712s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.465s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:21.936s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.534s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:42.798s]
[INFO] Web Map Service Module ............................ FAILURE [7:30.982s]
[INFO] REST Support Module ............................... SUCCESS [41.988s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.324s]
[INFO] Core UI Module .................................... SUCCESS [2:29.075s]
[INFO] WFS UI Module ..................................... SUCCESS [47.500s]
[INFO] Security UI Modules ............................... SUCCESS [0.216s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.161s]
[INFO] Printing Module ................................... SUCCESS [37.101s]
[INFO] Community Space ................................... SUCCESS [0.173s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.464s]
[INFO] Application Schema Support ........................ SUCCESS [0.140s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.321s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.818s]
[INFO] H2 DataStore Extension ............................ SUCCESS [28.931s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.054s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.569s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.343s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.438s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.863s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.471s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [33.387s]
[INFO] Excel Output Format ............................... SUCCESS [38.308s]
[INFO] Chart external graphics support ................... SUCCESS [1.250s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.731s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.931s]
[INFO] OWS request flow controller ....................... SUCCESS [33.814s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.325s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.666s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.968s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.408s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.247s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.212s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.219s]
[INFO] DXF WFS output format ............................. SUCCESS [36.293s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.259s]
[INFO] Total time: 19:41.992s (Wall Clock)
[INFO] Finished at: Sun Jan 18 08:06:44 UTC 2015
[INFO] Final Memory: 58M/199M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1038/&gt;
[...truncated 19254 lines...]
981/981 B
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 31.8 KB/sec)
913/981 B
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 63.9 KB/sec)
972/972 B
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2015 08:55
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2015 @ 09:13:27 UTC
[INFO]
[INFO]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.982 sec
[INFO]
[INFO]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.959 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.383 sec
[INFO]
T E S T S
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.17 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.278 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.925 sec
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.287 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.575 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.554 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.174 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 35.35 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.634 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.263s]
[INFO] Core Platform Module .............................. SUCCESS [14.544s]
[INFO] Open Web Service Module ........................... SUCCESS [16.296s]
[INFO] Main Module ....................................... SUCCESS [3:18.440s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.620s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.556s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [42.695s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.156s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.391s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:21.171s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.911s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:39.776s]
[INFO] Web Map Service Module ............................ FAILURE [7:33.607s]
[INFO] REST Support Module ............................... SUCCESS [44.639s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.392s]
[INFO] Core UI Module .................................... SUCCESS [2:33.937s]
[INFO] WFS UI Module ..................................... SUCCESS [45.145s]
[INFO] Security UI Modules ............................... SUCCESS [0.314s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.179s]
[INFO] Printing Module ................................... SUCCESS [33.675s]
[INFO] Community Space ................................... SUCCESS [0.297s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.779s]
[INFO] Application Schema Support ........................ SUCCESS [0.135s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.555s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.721s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.060s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.364s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.536s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.332s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.413s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.919s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.488s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.479s]
[INFO] Excel Output Format ............................... SUCCESS [39.758s]
[INFO] Chart external graphics support ................... SUCCESS [0.951s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.408s]
[INFO] OWS request flow controller ....................... SUCCESS [29.254s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.379s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.862s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.396s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.805s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.355s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.384s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.438s]
[INFO] DXF WFS output format ............................. SUCCESS [38.186s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.296s]
[INFO] Total time: 19:26.226s (Wall Clock)
[INFO] Finished at: Sun Jan 18 09:14:33 UTC 2015
[INFO] Final Memory: 58M/187M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1039/changes&gt;
Changes:
[andrea.aime] Revert "[GEOS-6807] WCS GetCapabilties requests with Sections parameter throws an exception" as it breaks CITE tests
[...truncated 19331 lines...]
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Processing Service Module 2.7-SNAPSHOT
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
981/981 B
976/976 B
913/981 B
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 56.4 KB/sec)
913/972 B
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 59.3 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Revert "[GEOS-6807] WCS GetCapabilties requests with Sections parameter throws an exception" as it breaks CITE tests
[INFO] [GitCommitIdMojo] build.commit.time = 18.01.2015 @ 09:03:36 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2015 09:14
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2015 @ 09:33:40 UTC
[INFO] [GitCommitIdMojo] build.branch = 1754db917e649fe5b28467f443fadaf4b2761760
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1754db9
[INFO] [GitCommitIdMojo] build.commit.id = 1754db917e649fe5b28467f443fadaf4b2761760
[INFO] [GitCommitIdMojo] build.commit.message.full = Revert "[GEOS-6807] WCS GetCapabilties requests with Sections parameter throws an exception" as it breaks CITE tests
This reverts commit 0268f97b3dfe40b7e2f8fc4a16d6c65d9a7fb021.
[INFO]
[INFO]
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.793 sec
[INFO]
[INFO]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.539 sec
[INFO]
T E S T S
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.125 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.507 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.724 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.013s]
[INFO] Core Platform Module .............................. SUCCESS [19.693s]
[INFO] Open Web Service Module ........................... SUCCESS [23.172s]
[INFO] Main Module ....................................... SUCCESS [3:23.521s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.704s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:24.750s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.130s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.772s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.599s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.127s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:03.365s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:45.929s]
[INFO] Web Map Service Module ............................ FAILURE [6:54.935s]
[INFO] REST Support Module ............................... SUCCESS [44.755s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.817s]
[INFO] Core UI Module .................................... SUCCESS [2:24.628s]
[INFO] WFS UI Module ..................................... SUCCESS [45.048s]
[INFO] Security UI Modules ............................... SUCCESS [0.225s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.279s]
[INFO] Printing Module ................................... SUCCESS [36.283s]
[INFO] Community Space ................................... SUCCESS [0.375s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.654s]
[INFO] Application Schema Support ........................ SUCCESS [0.175s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.176s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.921s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.174s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.279s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.714s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.700s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.594s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.826s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.704s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [38.989s]
[INFO] Excel Output Format ............................... SUCCESS [38.855s]
[INFO] Chart external graphics support ................... SUCCESS [1.121s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.687s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.662s]
[INFO] OWS request flow controller ....................... SUCCESS [31.306s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.316s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.043s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.996s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.758s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.142s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.947s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.524s]
[INFO] DXF WFS output format ............................. SUCCESS [37.816s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.303s]
[INFO] Total time: 19:24.650s (Wall Clock)
[INFO] Finished at: Sun Jan 18 09:34:15 UTC 2015
[INFO] Final Memory: 57M/213M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1040/changes&gt;
Changes:
[andrea.aime] Use a file name without uppercase letters, creates confusion between windows and unix file name conventions
[...truncated 19715 lines...]
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1421)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1357)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1121)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1056)
  at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1036)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1306)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1289)
  at org.geoserver.wps.InputLimitsTest.testCountourTooManyLevels(InputLimitsTest.java:467)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.1 sec
Running org.geoserver.wcs2_0.eo.GetCoverageTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.733 sec
Running org.geoserver.wps.MemoryProcessStoreTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.135 sec
Running org.geoserver.wps.NearestTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.068 sec
Running org.geoserver.wcs2_0.eo.GranuleCoverageExtensionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.023 sec
Results :
Failed tests: testSectionsCoverageDescriptions(org.geoserver.wcs2_0.eo.DescribeOECoverageSetTest): expected:<[1]> but was:<[0]>
  testSectionsAll(org.geoserver.wcs2_0.eo.DescribeOECoverageSetTest): expected:<[1]> but was:<[0]>
  testSectionsDatasetSeries(org.geoserver.wcs2_0.eo.DescribeOECoverageSetTest): expected:<[1]> but was:<[0]>
  testSectionsInvalid(org.geoserver.wcs2_0.eo.DescribeOECoverageSetTest): expected:<400> but was:<500>
Tests run: 31, Failures: 4, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.666 sec
Running org.geoserver.wps.RawInputOutputTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.62 sec
Running org.geoserver.wps.ResourceAccessManagerWPSTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.287s]
[INFO] Core Platform Module .............................. SUCCESS [15.954s]
[INFO] Open Web Service Module ........................... SUCCESS [16.867s]
[INFO] Main Module ....................................... SUCCESS [3:18.969s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.695s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.501s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.802s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.996s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.249s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:22.665s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.009s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:39.848s]
[INFO] Web Map Service Module ............................ SUCCESS [7:15.019s]
[INFO] REST Support Module ............................... SUCCESS [45.854s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.369s]
[INFO] Core UI Module .................................... SUCCESS [2:27.710s]
[INFO] WFS UI Module ..................................... SUCCESS [45.078s]
[INFO] Security UI Modules ............................... SUCCESS [0.351s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.162s]
[INFO] Printing Module ................................... SUCCESS [35.468s]
[INFO] Community Space ................................... SUCCESS [0.228s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.751s]
[INFO] Application Schema Support ........................ SUCCESS [0.174s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.742s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.823s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.117s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.407s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.522s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.265s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.349s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.855s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.589s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.911s]
[INFO] Excel Output Format ............................... SUCCESS [39.003s]
[INFO] Chart external graphics support ................... SUCCESS [0.976s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.041s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.614s]
[INFO] OWS request flow controller ....................... SUCCESS [29.156s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.125s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.965s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.919s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.202s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.503s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.155s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.578s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.364s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.327s]
[INFO] DXF WFS output format ............................. SUCCESS [39.236s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.158s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions FAILURE [58.058s]
[INFO] Total time: 20:40.258s (Wall Clock)
[INFO] Finished at: Sun Jan 18 10:03:15 UTC 2015
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.237 sec
Running org.geoserver.wps.SnapTest
[INFO] Final Memory: 59M/187M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0-eo-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0-eo-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1041/changes&gt;
