[Geoserver-devel] Build failed in Jenkins: geoserver-master #1062
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1062/&gt;
[...truncated 4860 lines...]
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.223 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.038 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.156 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.144 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.549 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.848 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.075 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.249 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.105 sec
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.756 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.984 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.061 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.438 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.173 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.343 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.309 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.403 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.229 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.16 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.042 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.784 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.887 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.081 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.898 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.318 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.944 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.106 sec
Results :
Tests in error:
  testMissingNullValuesInCoverageDimensions(org.geoserver.catalog.ResourcePoolTest): Error persisting CoverageInfoImpl[DEM] to workspaces/wcs/DEM/DEM/coverage.xml
  testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
Tests run: 641, Failures: 0, Errors: 18, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.298s]
[INFO] Core Platform Module .............................. SUCCESS [14.784s]
[INFO] Open Web Service Module ........................... SUCCESS [16.054s]
[INFO] Main Module ....................................... FAILURE [3:04.287s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.428s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.215s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.172s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.150s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.082s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.525s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.334s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.382s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.993s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.391s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.149s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.301s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.218s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.344s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.239s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:45.276s (Wall Clock)
[INFO] Finished at: Sun Jan 25 10:08:25 UTC 2015
[INFO] Final Memory: 40M/210M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1063/&gt;
