See <http://ares.opengeo.org/jenkins/job/geoserver-master/1072/changes>
Changes:
[mike] Correcting default anchor value for labels
[...truncated 19071 lines...]
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in Web Processing Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
913/981 B
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 3.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 56.1 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 56.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (972 B at 86.3 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Correcting default anchor value for labels
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 29.01.2015 @ 00:53:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 29-Jan-2015 00:58
[INFO] [GitCommitIdMojo] build.build.time = 29.01.2015 @ 01:17:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 8235e031368c7a47a10a2ac436e99179750b68e4
[INFO] [GitCommitIdMojo] build.commit.user.email = mike@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Mike Pumphrey
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8235e03
[INFO] [GitCommitIdMojo] build.commit.id = 8235e031368c7a47a10a2ac436e99179750b68e4
[INFO] [GitCommitIdMojo] build.commit.message.full = Correcting default anchor value for labels
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 10 resources
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 186 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 14 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 56 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/test-classes>
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 29.82 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports>
T E S T S
Running org.geoserver.wps.DescribeProcessTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.145 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.406 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.213 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.558 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.53 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.939 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.868 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.946 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 34.74 sec
Running org.geoserver.wps.ExecuteTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.954 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.541 sec
Results :
Failed tests: testExplicitMaxTimeCoverageSelector(org.geoserver.wms.dimension.RasterTimeDimensionDefaultValueTest): Default time should be the biggest one
Tests run: 667, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.970s]
[INFO] Core Platform Module .............................. SUCCESS [14.730s]
[INFO] Open Web Service Module ........................... SUCCESS [17.569s]
[INFO] Main Module ....................................... SUCCESS [3:25.392s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.747s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.612s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.963s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.759s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.888s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.805s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.506s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:41.322s]
[INFO] Web Map Service Module ............................ FAILURE [7:46.839s]
[INFO] REST Support Module ............................... SUCCESS [43.773s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.325s]
[INFO] Core UI Module .................................... SUCCESS [2:24.067s]
[INFO] WFS UI Module ..................................... SUCCESS [48.422s]
[INFO] Security UI Modules ............................... SUCCESS [0.388s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.240s]
[INFO] Printing Module ................................... SUCCESS [39.966s]
[INFO] Community Space ................................... SUCCESS [0.481s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.156s]
[INFO] Application Schema Support ........................ SUCCESS [0.182s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.243s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.425s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.987s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.877s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.570s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.887s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.480s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.238s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.614s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.577s]
[INFO] Excel Output Format ............................... SUCCESS [40.195s]
[INFO] Chart external graphics support ................... SUCCESS [2.067s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.592s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.726s]
[INFO] OWS request flow controller ....................... SUCCESS [31.532s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.136s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.693s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.405s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.740s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.356s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.514s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.395s]
[INFO] DXF WFS output format ............................. SUCCESS [36.435s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.196s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:55.740s (Wall Clock)
[INFO] Finished at: Thu Jan 29 01:18:27 UTC 2015
[INFO] Final Memory: 58M/194M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
