See <http://ares.opengeo.org/jenkins/job/geoserver-master/1180/changes>
Changes:
[ahuarte47] [GEOS-6906] Fix bad calculation of source Coverage Transform
[ksmith] Allow user specification of aliases for localhost
[...truncated 20814 lines...]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping CSW UI Module
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
at com.sun.media.jai.mlib.MlibScaleRIF.create(MlibScaleRIF.java:67)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getSampleModel(RenderedOp.java:2233)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.affine(GridCoverageRenderer.java:631)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderCoverage(GridCoverageRenderer.java:441)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:849)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:743)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:858)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:336)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
at org.geoserver.kml.KMLMapResponse.encodeAsKmz(KMLMapResponse.java:111)
at org.geoserver.kml.KMLMapResponse.write(KMLMapResponse.java:63)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:990)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:284)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1433)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1452)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1387)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
at org.geoserver.kml.KMLTest.testKMZMixed(KMLTest.java:468)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 79 more
Tests run: 20, Failures: 0, Errors: 0, Skipped: 2, Time elapsed: 4.215 sec
Running org.geoserver.kml.KMLWFSTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.117s]
[INFO] Core Platform Module .............................. SUCCESS [15.582s]
[INFO] Open Web Service Module ........................... SUCCESS [22.974s]
[INFO] Main Module ....................................... SUCCESS [3:43.054s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.818s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.091s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:17.887s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.925s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [58.213s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:22.625s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:11.790s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:34.515s]
[INFO] Web Map Service Module ............................ SUCCESS [7:39.745s]
[INFO] REST Support Module ............................... SUCCESS [43.618s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.629s]
[INFO] Core UI Module .................................... SUCCESS [2:34.810s]
[INFO] WFS UI Module ..................................... SUCCESS [46.896s]
[INFO] Security UI Modules ............................... SUCCESS [0.301s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.308s]
[INFO] Printing Module ................................... SUCCESS [52.361s]
[INFO] Community Space ................................... SUCCESS [0.461s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.525s]
[INFO] Application Schema Support ........................ SUCCESS [0.234s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.812s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.836s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.977s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.214s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.731s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [3.505s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.408s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.867s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.660s]
[INFO] OGR parent ........................................ SUCCESS [0.345s]
[INFO] OGR WFS ........................................... SUCCESS [35.991s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.331s]
[INFO] Web Processing Service Module ..................... FAILURE [4:56.098s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [38.810s]
[INFO] Chart external graphics support ................... SUCCESS [1.634s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.723s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.739s]
[INFO] OWS request flow controller ....................... SUCCESS [32.616s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.114s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.230s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.496s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.057s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.318s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.298s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.994s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:54.502s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.495s]
[INFO] DXF WFS output format ............................. SUCCESS [37.908s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.438s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:05.958s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 24:44.461s (Wall Clock)
[INFO] Finished at: Wed Mar 11 04:23:03 UTC 2015
[INFO] Final Memory: 61M/261M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
