See <http://ares.opengeo.org/jenkins/job/geoserver-master/1201/changes>
Changes:
[ksmith] Add hazelcast cluster moduler to community extensions build
[...truncated 23899 lines...]
Add hazelcast cluster module to community extensions build
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-xslt ---
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/xslt/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-xslt ---
[INFO] Compiling 12 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/xslt/target/classes>
[WARNING] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[26,21\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[160,11\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[166,12\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[166,39\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-test ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.BBox3DTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-xslt ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-xslt ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/xslt/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-xslt ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/xslt/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.xslt.GetFeatureXSLTTest
Empty formats
Formats are: {HTML=HTML, text/html; subtype=xslt=text/html; subtype=xslt}
Empty formats
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 37.48 sec <<< FAILURE!
testIncompatibleMix(org.geoserver.wfs.xslt.GetFeatureXSLTTest) Time elapsed: 214 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[typeName]> but was:<[outputFormat]>
at junit.framework.Assert.assertEquals(Assert.java:100)
at junit.framework.Assert.assertEquals(Assert.java:107)
at org.geoserver.test.GeoServerSystemTestSupport.checkOws10Exception(GeoServerSystemTestSupport.java:1626)
at org.geoserver.wfs.xslt.GetFeatureXSLTTest.testIncompatibleMix(GetFeatureXSLTTest.java:167)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wfs.xslt.config.TransformRepositoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 45.526 sec
Running org.geoserver.test.BBoxFilterTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.376 sec
Running org.geoserver.wfs.xslt.rest.TransformRestTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.84 sec
Results :
Failed tests: testIncompatibleMix(org.geoserver.wfs.xslt.GetFeatureXSLTTest): expected:<[typeName]> but was:<[outputFormat]>
Tests run: 29, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.18 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.3 sec
Running org.geoserver.test.DefaultIdTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [17.006s]
[INFO] Core Platform Module .............................. SUCCESS [15.593s]
[INFO] Open Web Service Module ........................... SUCCESS [17.189s]
[INFO] Main Module ....................................... SUCCESS [3:23.934s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.719s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.946s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:45.415s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.075s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [53.822s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.199s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:17.634s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:46.820s]
[INFO] Web Map Service Module ............................ SUCCESS [7:11.774s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:21.064s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:46.332s]
[INFO] REST Support Module ............................... SUCCESS [47.659s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:18.664s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.581s]
[INFO] Core UI Module .................................... SUCCESS [2:29.877s]
[INFO] WMS UI Module ..................................... SUCCESS [1:06.941s]
[INFO] GWC UI Module ..................................... SUCCESS [1:34.339s]
[INFO] WFS UI Module ..................................... SUCCESS [43.178s]
[INFO] Demoes Module ..................................... SUCCESS [1:12.320s]
[INFO] Security UI Modules ............................... SUCCESS [0.175s]
[INFO] Security UI Core Module ........................... SUCCESS [3:42.473s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [42.979s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.233s]
[INFO] Printing Module ................................... SUCCESS [45.261s]
[INFO] Community Space ................................... SUCCESS [0.154s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.112s]
[INFO] Application Schema Support ........................ SUCCESS [0.151s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.128s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.758s]
[INFO] GeoSearch Index Module ............................ SUCCESS [49.433s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.149s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.170s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.603s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.390s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.408s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.152s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.856s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.524s]
[INFO] OGR parent ........................................ SUCCESS [0.132s]
[INFO] OGR WFS ........................................... SUCCESS [34.729s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.143s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:58.178s]
[INFO] OGR WPS ........................................... SUCCESS [38.627s]
[INFO] Excel Output Format ............................... SUCCESS [37.501s]
[INFO] Chart external graphics support ................... SUCCESS [1.627s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.351s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.806s]
[INFO] OWS request flow controller ....................... SUCCESS [30.348s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [28.418s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.056s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.078s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.610s]
[INFO] Core Monitor Extension ............................ SUCCESS [28.157s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... FAILURE [57.058s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [52.033s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.027s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.278s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.378s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [23.104s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:58.219s]
[INFO] CSW UI Module ..................................... SUCCESS [42.269s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.168s]
[INFO] DXF WFS output format ............................. SUCCESS [38.475s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [44.048s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.147s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:00.972s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [29.913s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.121s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.174s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 35:48.745s (Wall Clock)
[INFO] Finished at: Fri Mar 20 01:18:54 UTC 2015
[INFO] Final Memory: 74M/196M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/xslt/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
