See <http://ares.opengeo.org/jenkins/job/geoserver-master/1243/changes>
Changes:
[lago.88] GEOS-6960: Updating GS code after viewsManager cleanup (GEOT-5050)
[lago.88] GSIP-128 JAIEXT integration
[...truncated 9647 lines...]
[INFO] [GitCommitIdMojo] build.branch = c88b5875b64455378ee2a50fdafc21b961248123
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c88b587
[INFO] [GitCommitIdMojo] build.commit.id = c88b5875b64455378ee2a50fdafc21b961248123
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #997 from n-lagomarsini/GSIP-128
GSIP-128 JAIEXT integration in GeoServer
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wfs ---
[INFO] Copying 12 resources
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wfs ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wfs/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wfs ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wfs/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wfs ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wfs/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapOutputFormat.java>:\[743,14\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping OGR WFS
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF WFS output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wfs ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wfs/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/affine/jt-affine/1.0.1/jt-affine-1.0.1.jar!/META-INF/registryFile.jai" :
Error in registry file at line number #5
A descriptor is already registered against the name "Affine" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/scale/jt-scale/1.0.1/jt-scale-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Scale" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/translate/jt-translate/1.0.1/jt-translate-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Translate" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/bandmerge/jt-bandmerge/1.0.1/jt-bandmerge-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "BandMerge" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/bandselect/jt-bandselect/1.0.1/jt-bandselect-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "BandSelect" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/border/jt-border/1.0.1/jt-border-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Border" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/crop/jt-crop/1.0.1/jt-crop-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Crop" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/lookup/jt-lookup/1.0.1/jt-lookup-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Lookup" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/mosaic/jt-mosaic/1.0.1/jt-mosaic-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Mosaic" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/nullop/jt-nullop/1.0.1/jt-nullop-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Null" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/rescale/jt-rescale/1.0.1/jt-rescale-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Rescale" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/warp/jt-warp/1.0.1/jt-warp-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Warp" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/binarize/jt-binarize/1.0.1/jt-binarize-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Binarize" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/format/jt-format/1.0.1/jt-format-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "Format" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/colorconvert/jt-colorconvert/1.0.1/jt-colorconvert-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "ColorConvert" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/errordiffusion/jt-errordiffusion/1.0.1/jt-errordiffusion-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "ErrorDiffusion" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/orderdither/jt-orderdither/1.0.1/jt-orderdither-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "OrderedDither" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/imagefunction/jt-imagefunction/1.0.1/jt-imagefunction-1.0.1.jar!/META-INF/registryFile.jai" :
A descriptor is already registered against the name "ImageFunction" under registry mode "rendered"
Error while parsing JAI registry file "file:/var/lib/jenkins/.m2/repository/it/geosolutions/jaiext/vectorbin/jt-vectorbin/1.0.1/jt-vectorbin-1.0.1.jar!/META-INF/registryFile.jai" :
Error in registry file at line number #4
A descriptor is already registered against the name "VectorBinarize" under registry mode "rendered"
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.158s]
[INFO] Core Platform Module .............................. SUCCESS [16.056s]
[INFO] Open Web Service Module ........................... SUCCESS [18.461s]
[INFO] Main Module ....................................... SUCCESS [3:21.729s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.913s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:25.441s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:49.761s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.528s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [55.741s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:13.423s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [4:43.724s]
[INFO] Web Map Service Module ............................ FAILURE [18.063s]
[INFO] REST Support Module ............................... SUCCESS [46.189s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.368s]
[INFO] Core UI Module .................................... SUCCESS [2:31.887s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.161s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.099s]
[INFO] Printing Module ................................... SUCCESS [46.224s]
[INFO] Community Space ................................... SUCCESS [0.118s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.101s]
[INFO] Application Schema Support ........................ SUCCESS [0.116s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.084s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.702s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.024s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.637s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.332s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.229s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.585s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.450s]
[INFO] OGR parent ........................................ SUCCESS [0.111s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.221s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.293s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.315s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.049s]
[INFO] OWS request flow controller ....................... SUCCESS [27.173s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.898s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [43.541s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.306s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.319s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.243s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.196s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 13:03.574s (Wall Clock)
[INFO] Finished at: Tue Apr 07 13:40:05 UTC 2015
[INFO] Final Memory: 60M/279M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
