[Geoserver-devel] Build failed in Jenkins: geoserver-master #1351
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1351/changes&gt;
Changes:
[andrea.aime] [GEOS-7007] CQL_FILTER is ignored against a mosaic if the ResourceAccessManager also adds its own filter
[...truncated 18842 lines...]
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/14-SNAPSHOT/maven-metadata.xml (971 B at 94.8 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/14-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/14-SNAPSHOT/maven-metadata.xml (976 B at 79.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/14-SNAPSHOT/maven-metadata.xml
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/14-SNAPSHOT/maven-metadata.xml (967 B at 12.8 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7007] CQL_FILTER is ignored against a mosaic if the ResourceAccessManager also adds its own filter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.05.2015 @ 12:21:33 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 05-May-2015 12:59
[INFO] [GitCommitIdMojo] build.build.time = 05.05.2015 @ 13:19:55 UTC
[INFO] [GitCommitIdMojo] build.branch = db10a8c03824131755573c49be376a615d08432a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = db10a8c
[INFO] [GitCommitIdMojo] build.commit.id = db10a8c03824131755573c49be376a615d08432a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7007] CQL_FILTER is ignored against a mosaic if the ResourceAccessManager also adds its own filter
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 10 resources
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 187 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/classes&gt;
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.506 sec
Running org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 14 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 59 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/test-classes&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.028 sec
Running org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.DescribeProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.08 sec
Running org.geoserver.wms.wms_1_1_1.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.765 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.735 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.582 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.421 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesIntegrationTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.519 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 34.353 sec
Running org.geoserver.wps.ExecuteOnCoverageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.451 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.202 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.457 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.879 sec
Running org.geoserver.wps.ExecuteTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.566 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.1 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.532 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 39, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 23.999 sec
Running org.geoserver.wps.GeoServerFactoryExtensionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.753 sec
Running org.geoserver.wps.GetCapabilitiesTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.696 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.825 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.782 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.282 sec
Results :
Failed tests: testRasterCrop(org.geoserver.wms.ResourceAccessManagerWMSTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
  testRasterFilterGreen(org.geoserver.wms.ResourceAccessManagerWMSTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
  testDoubleMosaic(org.geoserver.wms.ResourceAccessManagerWMSTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
Tests run: 672, Failures: 3, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Catalog Services for the Web core module
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.833 sec
Running org.geoserver.wps.InputLimitsTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.180s]
[INFO] Core Platform Module .............................. SUCCESS [16.164s]
[INFO] Open Web Service Module ........................... SUCCESS [17.608s]
[INFO] Main Module ....................................... SUCCESS [3:31.776s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.095s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.505s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:53.340s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.147s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [55.111s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.990s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:12.180s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:39.940s]
[INFO] Web Map Service Module ............................ FAILURE [9:06.782s]
[INFO] REST Support Module ............................... SUCCESS [51.097s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.308s]
[INFO] Core UI Module .................................... SUCCESS [2:30.003s]
[INFO] WFS UI Module ..................................... SUCCESS [46.227s]
[INFO] Security UI Modules ............................... SUCCESS [0.363s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.233s]
[INFO] Printing Module ................................... SUCCESS [45.245s]
[INFO] Community Space ................................... SUCCESS [0.175s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.576s]
[INFO] Application Schema Support ........................ SUCCESS [0.140s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [42.638s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.374s]
[INFO] H2 DataStore Extension ............................ SUCCESS [27.097s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.045s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.656s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.345s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.492s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.105s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.683s]
[INFO] OGR parent ........................................ SUCCESS [0.266s]
[INFO] OGR WFS ........................................... SUCCESS [37.593s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.270s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [39.303s]
[INFO] Chart external graphics support ................... SUCCESS [1.397s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.011s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.107s]
[INFO] OWS request flow controller ....................... SUCCESS [31.123s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.228s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.547s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.254s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.906s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.389s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.014s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.791s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.309s]
[INFO] DXF WFS output format ............................. SUCCESS [41.415s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.239s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:02.989s (Wall Clock)
[INFO] Finished at: Tue May 05 13:21:55 UTC 2015
[INFO] Final Memory: 63M/250M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1352/changes&gt;
