[Geoserver-devel] Build failed in Jenkins: geoserver-master #1364
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1364/changes&gt;
Changes:
[andrea.aime] [GEOS-7010] GeoServer layer preview can be too large or too wide
[andrea.aime] [GEOS-6992] Add gdalwarp/gdal_translate/gdaladdo transformation support in importer
[andrea.aime] [GEOS-7000] Allow importer to add granules to a mosaic as an indirect import
[...truncated 25396 lines...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
testGdalTranslateTrasform(org.geoserver.importer.transform.GdalTransformTest) Time elapsed: 0 sec <<< ERROR!
java.io.IOException: Could not locate executable (or could locate, but does not have execution rights): gdal_translate
  at org.geoserver.importer.transform.AbstractCommandLineTransform.getExecutableFromPath(AbstractCommandLineTransform.java:289)
  at org.geoserver.importer.transform.GdalTranslateTransform.getExecutable(GdalTranslateTransform.java:56)
  at org.geoserver.importer.transform.AbstractCommandLineTransform.checkAvailable(AbstractCommandLineTransform.java:138)
  at org.geoserver.importer.transform.GdalTranslateTransform.isAvailable(GdalTranslateTransform.java:31)
  at org.geoserver.importer.transform.GdalTransformTest.testGdalTranslateTrasform(GdalTransformTest.java:34)
testGdalAddo(org.geoserver.importer.transform.GdalTransformTest) Time elapsed: 1 sec <<< ERROR!
java.io.IOException: Could not locate executable (or could locate, but does not have execution rights): gdaladdo
  at org.geoserver.importer.transform.GdalAddoTransform.getExecutable(GdalAddoTransform.java:96)
  at org.geoserver.importer.transform.GdalAddoTransform.isAvailable(GdalAddoTransform.java:35)
  at org.geoserver.importer.transform.GdalTransformTest.testGdalAddo(GdalTransformTest.java:81)
Running org.geoserver.importer.transform.KMLPlacemarkTransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.importer.transform.TransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Results :
Tests in error:
  testTranslateAddo(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdal_translate
  testWarpFromGroundControlPoint(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdalwarp
  testGdalTranslateTrasform(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdal_translate
  testGdalAddo(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdaladdo
Tests run: 81, Failures: 0, Errors: 4, Skipped: 2
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.296s]
[INFO] Core Platform Module .............................. SUCCESS [16.054s]
[INFO] Open Web Service Module ........................... SUCCESS [22.029s]
[INFO] Main Module ....................................... SUCCESS [3:31.814s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.980s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.209s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:51.020s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.185s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [55.039s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.699s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.166s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:47.885s]
[INFO] Web Map Service Module ............................ SUCCESS [9:15.832s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:32.967s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [3:05.325s]
[INFO] REST Support Module ............................... SUCCESS [50.864s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:27.525s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.617s]
[INFO] Core UI Module .................................... SUCCESS [2:25.312s]
[INFO] WMS UI Module ..................................... SUCCESS [1:09.305s]
[INFO] GWC UI Module ..................................... SUCCESS [1:46.458s]
[INFO] WFS UI Module ..................................... SUCCESS [47.086s]
[INFO] Demoes Module ..................................... SUCCESS [1:07.323s]
[INFO] WCS UI Module ..................................... SUCCESS [54.223s]
[INFO] Security UI Modules ............................... SUCCESS [0.244s]
[INFO] Security UI Core Module ........................... SUCCESS [3:57.447s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [51.618s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.274s]
[INFO] Printing Module ................................... SUCCESS [41.653s]
[INFO] Community Space ................................... SUCCESS [0.156s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.239s]
[INFO] Application Schema Support ........................ SUCCESS [0.210s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:28.183s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.638s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [34.498s]
[INFO] GeoSearch Index Module ............................ SUCCESS [48.612s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.761s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.021s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.798s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.440s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.545s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.597s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.269s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.810s]
[INFO] OGR parent ........................................ SUCCESS [0.135s]
[INFO] OGR WFS ........................................... SUCCESS [39.400s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.366s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:58.354s]
[INFO] OGR WPS ........................................... SUCCESS [39.785s]
[INFO] Excel Output Format ............................... SUCCESS [40.211s]
[INFO] Chart external graphics support ................... SUCCESS [1.468s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.138s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.993s]
[INFO] OWS request flow controller ....................... SUCCESS [29.724s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [31.989s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [55.539s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.892s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.440s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.316s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.923s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [1:00.719s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.659s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.750s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.514s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [29.116s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.092s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:49.140s]
[INFO] CSW UI Module ..................................... SUCCESS [40.989s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.265s]
[INFO] DXF WFS output format ............................. SUCCESS [41.495s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [38.106s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.246s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:01.529s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [38.825s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [39.597s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.192s]
[INFO] Importer Core Module .............................. FAILURE [2:04.014s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 41:18.159s (Wall Clock)
[INFO] Finished at: Fri May 08 14:09:49 UTC 2015
[INFO] Final Memory: 82M/265M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1365/changes&gt;
