See <http://ares.opengeo.org/jenkins/job/geoserver-master/1381/changes>
Changes:
[jody.garnett] Build speed up with explicitly setting which beans need early initialization instead
[...truncated 5434 lines...]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wfs ---
[INFO] Compiling 87 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-rest ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/surefire-reports>
T E S T S
Running org.geoserver.rest.EnviromentInjectionCallbackTest
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,4\] error: cannot find symbol
[ERROR] class GetFeatureCurvesTest
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,4\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[30,33\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[60,33\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[54,5\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,32\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,38\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,76\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,30\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,36\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,72\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[34,30\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[34,52\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[35,44\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[36,16\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[37,49\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[38,46\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[39,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[40,44\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[56,16\] error: cannot find symbol
[INFO] 20 errors
[INFO]
[INFO] Skipping Core UI Module
[INFO]
[INFO] Skipping Feature Generalization Extension
[INFO]
[INFO] Skipping OWS request flow controller
[INFO]
[INFO] Skipping Catalog Services for the Web parent
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.005 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Running org.geoserver.rest.RESTDispatcherCallbackTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.793s]
[INFO] Core Platform Module .............................. SUCCESS [16.279s]
[INFO] Open Web Service Module ........................... SUCCESS [23.401s]
[INFO] Main Module ....................................... SUCCESS [2:42.897s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.875s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SUCCESS [5.675s]
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ FAILURE [27.208s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.395s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.163s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.099s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.087s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.992s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.623s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.389s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.424s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.136s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.469s]
[INFO] OGR parent ........................................ SUCCESS [0.091s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.169s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.510s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.903s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.121s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.149s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:07.278s (Wall Clock)
[INFO] Finished at: Tue May 12 18:52:41 UTC 2015
[INFO] Final Memory: 48M/299M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wfs: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,4\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[30,33\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[60,33\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[54,5\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,38\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[23,76\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,30\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[25,72\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[34,30\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[34,52\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[35,44\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[36,16\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[37,49\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[38,46\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[39,47\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[40,44\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/src/test/java/org/geoserver/wfs/GetFeatureCurvesTest.java>:\[56,16\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
