[Geoserver-devel] Build failed in Jenkins: geoserver-master #1385
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1385/&gt;
[...truncated 23056 lines...]
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer Core Module
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.125 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1051 from bencaradocdavies/hazelcast-nomulti
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.05.2015 @ 19:49:45 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2015 21:48
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2015 @ 22:16:03 UTC
[INFO] [GitCommitIdMojo] build.branch = 7c49f65bd9da8075d48daab90d8cdb50559ac1a0
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7c49f65
[INFO] [GitCommitIdMojo] build.commit.id = 7c49f65bd9da8075d48daab90d8cdb50559ac1a0
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1051 from bencaradocdavies/hazelcast-nomulti
Disabled multicast node discovery in HazelcastTest
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.232s]
[INFO] Core Platform Module .............................. SUCCESS [16.246s]
[INFO] Open Web Service Module ........................... SUCCESS [18.613s]
[INFO] Main Module ....................................... SUCCESS [2:30.846s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.936s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.837s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:00.683s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.139s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.494s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.517s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:58.021s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:18.287s]
[INFO] Web Map Service Module ............................ SUCCESS [6:49.198s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:12.414s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:18.745s]
[INFO] REST Support Module ............................... SUCCESS [39.806s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:28.950s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.637s]
[INFO] Core UI Module .................................... SUCCESS [1:48.992s]
[INFO] WMS UI Module ..................................... SUCCESS [56.806s]
[INFO] WFS UI Module ..................................... SUCCESS [32.493s]
[INFO] Demoes Module ..................................... SUCCESS [56.262s]
[INFO] Security UI Modules ............................... SUCCESS [0.198s]
[INFO] Security UI Core Module ........................... FAILURE [2:56.502s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.304s]
[INFO] Printing Module ................................... SUCCESS [37.674s]
[INFO] Community Space ................................... SUCCESS [0.177s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.695s]
[INFO] Application Schema Support ........................ SUCCESS [0.158s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.244s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.623s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.042s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.494s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.771s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.408s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.420s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.556s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.001s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.753s]
[INFO] OGR parent ........................................ SUCCESS [0.312s]
[INFO] OGR WFS ........................................... SUCCESS [26.512s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.379s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:11.168s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [39.406s]
[INFO] Chart external graphics support ................... SUCCESS [1.699s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.230s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.125s]
[INFO] OWS request flow controller ....................... SUCCESS [28.484s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.601s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.349s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.213s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.303s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [46.741s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.114s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.506s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [32.031s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.833s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.128s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.263s]
[INFO] DXF WFS output format ............................. SUCCESS [37.510s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.373s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.848s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [30.058s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [30.305s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.367s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 27:12.981s (Wall Clock)
[INFO] Finished at: Tue May 12 22:16:03 UTC 2015
[INFO] Final Memory: 72M/215M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1386/&gt;
[...truncated 21333 lines...]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-wms ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wms/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-wms ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wms ---
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2015 22:20
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2015 @ 22:43:24 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wms ---
[INFO] Copying 12 resources
[INFO] Copying 16 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wms ---
[INFO] Compiling 21 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wms/target/classes&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.163 sec
Running org.geoserver.service.rest.LocalWFSSettingsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.027 sec
Running org.geoserver.service.rest.LocalWMSSettingsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.892 sec
Running org.geoserver.service.rest.WCSSettingsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.645 sec
Running org.geoserver.service.rest.WFSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.866 sec
Running org.geoserver.service.rest.WMSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.464 sec
Results :
Tests in error:
  org.geoserver.catalog.rest.CoverageStoreTest: Unable to delete directory ./target/default7045988594038427896data.
Tests run: 345, Failures: 0, Errors: 1, Skipped: 3
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wms ---
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wms/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wms ---
[INFO] Compiling 7 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wms/target/test-classes&gt;
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.976s]
[INFO] Core Platform Module .............................. SUCCESS [15.856s]
[INFO] Open Web Service Module ........................... SUCCESS [19.851s]
[INFO] Main Module ....................................... SUCCESS [2:34.994s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.832s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.431s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:00.935s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.681s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.980s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.492s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.142s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:20.047s]
[INFO] Web Map Service Module ............................ SUCCESS [6:39.317s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:16.093s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:16.503s]
[INFO] REST Support Module ............................... SUCCESS [41.033s]
[INFO] REST Configuration Service Module ................. FAILURE [2:20.966s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.594s]
[INFO] Core UI Module .................................... SUCCESS [1:50.518s]
[INFO] WFS UI Module ..................................... SUCCESS [31.860s]
[INFO] Security UI Modules ............................... SUCCESS [0.316s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.311s]
[INFO] Printing Module ................................... SUCCESS [38.633s]
[INFO] Community Space ................................... SUCCESS [0.157s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.090s]
[INFO] Application Schema Support ........................ SUCCESS [0.150s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.953s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.362s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.858s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.519s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.824s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.618s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.422s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.140s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.714s]
[INFO] OGR parent ........................................ SUCCESS [0.137s]
[INFO] OGR WFS ........................................... SUCCESS [23.748s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.276s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:12.551s]
[INFO] Excel Output Format ............................... SUCCESS [37.796s]
[INFO] Chart external graphics support ................... SUCCESS [1.615s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.181s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.165s]
[INFO] OWS request flow controller ....................... SUCCESS [29.270s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.996s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.784s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.271s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.574s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.662s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.593s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.897s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:41.900s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.175s]
[INFO] DXF WFS output format ............................. SUCCESS [37.771s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.154s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [51.756s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Total time: 23:30.040s (Wall Clock)
[INFO] Finished at: Tue May 12 22:43:34 UTC 2015
[INFO] Final Memory: 67M/263M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wms ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wms/target/surefire-reports&gt;
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1387/changes&gt;
