[Geoserver-devel] Build failed in Jenkins: geoserver-master #1392
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1392/changes&gt;
Changes:
[niels] Complex features refactoring: update csw & app-schema
[...truncated 26703 lines...]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1064 from NielsCharlier/complexrefact
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.05.2015 @ 04:54:39 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-May-2015 04:59
[INFO] [GitCommitIdMojo] build.build.time = 16.05.2015 @ 05:36:16 UTC
[INFO] [GitCommitIdMojo] build.branch = 8814145bcd69ffb707bad078d250cdce2cc92bf2
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8814145
[INFO] [GitCommitIdMojo] build.commit.id = 8814145bcd69ffb707bad078d250cdce2cc92bf2
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1064 from NielsCharlier/complexrefact
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 16.05.2015 @ 05:36:19 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.101s]
[INFO] Core Platform Module .............................. SUCCESS [19.489s]
[INFO] Open Web Service Module ........................... SUCCESS [23.353s]
[INFO] Main Module ....................................... SUCCESS [2:59.600s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.879s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:07.986s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:12.380s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.588s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.297s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [59.028s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:01.493s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:29.544s]
[INFO] Web Map Service Module ............................ SUCCESS [6:47.625s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.447s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:29.058s]
[INFO] REST Support Module ............................... SUCCESS [41.339s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:23.296s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.728s]
[INFO] Core UI Module .................................... SUCCESS [1:57.426s]
[INFO] WMS UI Module ..................................... SUCCESS [53.959s]
[INFO] GWC UI Module ..................................... SUCCESS [1:12.759s]
[INFO] WFS UI Module ..................................... SUCCESS [33.836s]
[INFO] Demoes Module ..................................... SUCCESS [53.551s]
[INFO] WCS UI Module ..................................... SUCCESS [41.706s]
[INFO] Security UI Modules ............................... SUCCESS [0.545s]
[INFO] Security UI Core Module ........................... SUCCESS [2:48.342s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:04.433s]
[INFO] Security UI LDAP Module ........................... SUCCESS [43.879s]
[INFO] REST UI Module .................................... SUCCESS [34.216s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.351s]
[INFO] Printing Module ................................... SUCCESS [35.799s]
[INFO] Community Space ................................... SUCCESS [0.181s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.728s]
[INFO] GeoServer Web Application ......................... SUCCESS [30.578s]
[INFO] Application Schema Support ........................ SUCCESS [0.203s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:45.671s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.214s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.451s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.057s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.968s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.162s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.769s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.679s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.571s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.553s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.365s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.703s]
[INFO] OGR parent ........................................ SUCCESS [0.585s]
[INFO] OGR WFS ........................................... SUCCESS [28.629s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.248s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:09.940s]
[INFO] OGR WPS ........................................... SUCCESS [29.910s]
[INFO] Excel Output Format ............................... SUCCESS [40.091s]
[INFO] Chart external graphics support ................... SUCCESS [2.395s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.575s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.246s]
[INFO] OWS request flow controller ....................... SUCCESS [29.074s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [28.406s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:10.692s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.017s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.860s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.466s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.221s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.383s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.384s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [28.127s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [3.763s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.084s]
[INFO] XLST based WFS output format ...................... SUCCESS [52.403s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [51.226s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.772s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.424s]
[INFO] Catalog Services for the Web interfaces ........... FAILURE [9.022s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.262s]
[INFO] DXF WFS output format ............................. SUCCESS [36.705s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [28.110s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.529s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.127s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.914s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [24.036s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.272s]
[INFO] Importer Core Module .............................. SUCCESS [1:46.636s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:26.363s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.957s]
[INFO] Importer Web UI Module ............................ SUCCESS [7.939s]
[INFO] BUILD FAILURE
[INFO] Total time: 36:19.958s (Wall Clock)
[INFO] Finished at: Sat May 16 05:36:19 UTC 2015
[INFO] Final Memory: 89M/256M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-csw-api: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[9,31\] error: package org.geotools.xml.complex does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[18,63\] error: cannot find symbol
[ERROR] class FeatureTypeRegistryConfiguration
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[85,50\] error: no suitable constructor found for FeatureTypeRegistry(NamespaceSupport,FeatureTypeFactory,RecordFeatureTypeRegistryConfiguration,boolean)
[ERROR] constructor FeatureTypeRegistry.FeatureTypeRegistry(NamespaceSupport,FeatureTypeFactory,FeatureTypeRegistryHelper,boolean) is not applicable
[ERROR] (actual argument RecordFeatureTypeRegistryConfiguration cannot be converted to FeatureTypeRegistryHelper by method invocation conversion)
[ERROR] constructor FeatureTypeRegistry.FeatureTypeRegistry(NamespaceSupport,FeatureTypeFactory,FeatureTypeRegistryHelper) is not applicable
[ERROR] (actual and formal argument lists differ in length)
[ERROR] constructor FeatureTypeRegistry.FeatureTypeRegistry(FeatureTypeFactory,FeatureTypeRegistryHelper) is not applicable
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[26,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[31,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[36,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[41,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/RecordFeatureTypeRegistryConfiguration.java&gt;:\[46,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[154,50\] error: no suitable constructor found for FeatureTypeRegistry(NamespaceSupport,FeatureTypeFactory,RecordFeatureTypeRegistryConfiguration)
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-api
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1393/&gt;
