[Geoserver-devel] Build failed in Jenkins: geoserver-master #1400
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1400/&gt;
[...truncated 26197 lines...]
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 9cbc814
[INFO] [GitCommitIdMojo] build.commit.id = 9cbc814dadb56b04f6afa4bd8518c906b28673a0
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1074 from mbarto/geos7020_more_fix
GEOS-7020: additional fix to avoid overflows of hitArea outside of pa…
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1074 from mbarto/geos7020_more_fix
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.05.2015 @ 16:48:33 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-May-2015 11:05
[INFO] [GitCommitIdMojo] build.build.time = 19.05.2015 @ 11:40:25 UTC
[INFO] [GitCommitIdMojo] build.branch = 9cbc814dadb56b04f6afa4bd8518c906b28673a0
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com03...
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.664 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.207 sec
Results :
Tests run: 53, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] build.build.time = 19.05.2015 @ 11:40:45 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.320s]
[INFO] Core Platform Module .............................. SUCCESS [25.664s]
[INFO] Open Web Service Module ........................... SUCCESS [27.153s]
[INFO] Main Module ....................................... SUCCESS [3:19.803s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.111s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:09.499s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:05.233s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.027s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.399s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.693s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:54.230s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:21.548s]
[INFO] Web Map Service Module ............................ SUCCESS [6:51.739s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:21.331s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:14.312s]
[INFO] REST Support Module ............................... SUCCESS [48.353s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:23.962s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.866s]
[INFO] Core UI Module .................................... SUCCESS [1:55.071s]
[INFO] WMS UI Module ..................................... SUCCESS [58.339s]
[INFO] GWC UI Module ..................................... SUCCESS [1:22.533s]
[INFO] WFS UI Module ..................................... SUCCESS [31.059s]
[INFO] Demoes Module ..................................... SUCCESS [52.704s]
[INFO] WCS UI Module ..................................... SUCCESS [41.032s]
[INFO] Security UI Modules ............................... SUCCESS [0.225s]
[INFO] Security UI Core Module ........................... FAILURE [2:44.839s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [32.652s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.380s]
[INFO] Printing Module ................................... SUCCESS [37.946s]
[INFO] Community Space ................................... SUCCESS [0.642s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.586s]
[INFO] Application Schema Support ........................ SUCCESS [0.196s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:49.637s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.647s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.707s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.134s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.341s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.836s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.364s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.714s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.740s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.584s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.555s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.111s]
[INFO] OGR parent ........................................ SUCCESS [0.347s]
[INFO] OGR WFS ........................................... SUCCESS [24.927s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.325s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:57.684s]
[INFO] OGR WPS ........................................... SUCCESS [26.996s]
[INFO] Excel Output Format ............................... SUCCESS [38.048s]
[INFO] Chart external graphics support ................... SUCCESS [2.911s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.215s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.302s]
[INFO] OWS request flow controller ....................... SUCCESS [28.614s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [28.140s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.809s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.359s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.351s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.712s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.070s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [56.698s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [48.055s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.975s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.212s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.116s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.354s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:38.547s]
[INFO] CSW UI Module ..................................... SUCCESS [25.108s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.419s]
[INFO] DXF WFS output format ............................. SUCCESS [37.748s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [27.679s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.350s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.253s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [37.101s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.571s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.461s]
[INFO] Importer Core Module .............................. SUCCESS [1:49.324s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:20.816s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [50.875s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.452s]
[INFO] BUILD FAILURE
[INFO] Total time: 35:25.844s (Wall Clock)
[INFO] Finished at: Tue May 19 11:40:45 UTC 2015
[INFO] Final Memory: 83M/241M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1401/&gt;
