[Geoserver-devel] Build failed in Jenkins: geoserver-master #1404
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1404/changes&gt;
Changes:
[tbarsballe] [GEOS-7025] Stopped GeoServerDataDirectory.parsedStyle from creating files for nonexistant URLs
[...truncated 26144 lines...]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1076 from tbarsballe/GEOS-7025
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 20.05.2015 @ 02:38:20 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-May-2015 02:43
[INFO] [GitCommitIdMojo] build.build.time = 20.05.2015 @ 03:18:02 UTC
[INFO] [GitCommitIdMojo] build.branch = 4aa2fa9f502ab6ca8228f591e56c5b3256eab242
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4aa2fa9
[INFO] [GitCommitIdMojo] build.commit.id = 4aa2fa9f502ab6ca8228f591e56c5b3256eab242
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1076 from tbarsballe/GEOS-7025
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 26.338 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.902 sec
Results :
Tests run: 53, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] build.build.time = 20.05.2015 @ 03:18:08 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.517s]
[INFO] Core Platform Module .............................. SUCCESS [18.310s]
[INFO] Open Web Service Module ........................... SUCCESS [24.330s]
[INFO] Main Module ....................................... SUCCESS [2:36.484s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.992s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.798s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:33.127s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.053s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.995s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [54.294s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:53.563s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:18.431s]
[INFO] Web Map Service Module ............................ SUCCESS [6:40.626s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.277s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:17.493s]
[INFO] REST Support Module ............................... SUCCESS [44.325s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:28.887s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.328s]
[INFO] Core UI Module .................................... SUCCESS [2:09.783s]
[INFO] WMS UI Module ..................................... SUCCESS [59.097s]
[INFO] GWC UI Module ..................................... SUCCESS [1:19.926s]
[INFO] WFS UI Module ..................................... SUCCESS [29.467s]
[INFO] Demoes Module ..................................... SUCCESS [51.484s]
[INFO] WCS UI Module ..................................... SUCCESS [38.007s]
[INFO] Security UI Modules ............................... SUCCESS [0.225s]
[INFO] Security UI Core Module ........................... FAILURE [2:37.128s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [40.166s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.268s]
[INFO] Printing Module ................................... SUCCESS [32.933s]
[INFO] Community Space ................................... SUCCESS [0.398s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.314s]
[INFO] Application Schema Support ........................ SUCCESS [0.164s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:33.342s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.964s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.607s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.685s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.051s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.117s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.979s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.470s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.441s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.005s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.158s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.642s]
[INFO] OGR parent ........................................ SUCCESS [0.207s]
[INFO] OGR WFS ........................................... SUCCESS [24.838s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.597s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:07.304s]
[INFO] OGR WPS ........................................... SUCCESS [33.074s]
[INFO] Excel Output Format ............................... SUCCESS [39.778s]
[INFO] Chart external graphics support ................... SUCCESS [2.199s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.760s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.182s]
[INFO] OWS request flow controller ....................... SUCCESS [27.100s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [37.012s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.007s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.795s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.413s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.455s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.466s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [52.171s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [48.140s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.938s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.207s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.326s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.515s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:30.951s]
[INFO] CSW UI Module ..................................... SUCCESS [25.918s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.254s]
[INFO] DXF WFS output format ............................. SUCCESS [35.758s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [25.896s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.285s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [48.235s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.569s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.773s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.232s]
[INFO] Importer Core Module .............................. SUCCESS [1:55.270s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:25.985s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.129s]
[INFO] Importer Web UI Module ............................ SUCCESS [10.292s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:31.903s (Wall Clock)
[INFO] Finished at: Wed May 20 03:18:08 UTC 2015
[INFO] Final Memory: 83M/184M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
Yes, yes, I merged it, even when Travis CI was failing for oraclejdk7. Andrea, I hope you are smiling.
I have kicked it again to see if the failure really is as intermittent as I claimed.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1405/&gt;
The build fixed itself: the failure is intermittent.
I can make gs-web-sec-core fail in random places by adding system load elsewhere. (-T likely has a similar effect.) I will file a Jira issue.
as I claimed.
Director
New Zealand
