[Geoserver-devel] Build failed in Jenkins: geoserver-master #1440
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1440/&gt;
[...truncated 17977 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1089 from geosolutions-it/GEOS-6895
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 28.05.2015 @ 16:27:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 29-May-2015 00:08
[INFO] [GitCommitIdMojo] build.build.time = 29.05.2015 @ 00:45:56 UTC
[INFO] [GitCommitIdMojo] build.branch = d54d57219141b9d8806307c1f02228c0008912c4
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d54d572
[INFO] [GitCommitIdMojo] build.commit.id = d54d57219141b9d8806307c1f02228c0008912c4
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1089 from geosolutions-it/GEOS-6895
[GEOS-6895]: Improve NetCDF community module: NetCDF4 support, projec…
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 29.05.2015 @ 00:45:59 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 29.05.2015 @ 00:46:00 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.100s]
[INFO] Core Platform Module .............................. SUCCESS [15.268s]
[INFO] Open Web Service Module ........................... SUCCESS [20.496s]
[INFO] Main Module ....................................... SUCCESS [2:33.585s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.772s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.460s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [3:53.222s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.048s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:02.418s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [53.630s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:57.333s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:43.902s]
[INFO] Web Map Service Module ............................ SUCCESS [6:58.864s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:16.273s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:19.464s]
[INFO] REST Support Module ............................... SUCCESS [44.830s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:54.364s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.281s]
[INFO] Core UI Module .................................... SUCCESS [1:59.989s]
[INFO] WMS UI Module ..................................... SUCCESS [55.397s]
[INFO] GWC UI Module ..................................... SUCCESS [1:24.261s]
[INFO] WFS UI Module ..................................... SUCCESS [33.044s]
[INFO] Demoes Module ..................................... SUCCESS [1:00.155s]
[INFO] WCS UI Module ..................................... SUCCESS [38.548s]
[INFO] Security UI Modules ............................... SUCCESS [0.138s]
[INFO] Security UI Core Module ........................... SUCCESS [3:31.830s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:34.655s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.712s]
[INFO] REST UI Module .................................... SUCCESS [34.498s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.160s]
[INFO] Printing Module ................................... SUCCESS [26.131s]
[INFO] Community Space ................................... SUCCESS [0.097s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.630s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.519s]
[INFO] Application Schema Support ........................ SUCCESS [0.115s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:39.580s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.411s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.386s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.554s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.946s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.923s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.837s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.387s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.373s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.365s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.273s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.847s]
[INFO] OGR parent ........................................ SUCCESS [0.242s]
[INFO] OGR WFS ........................................... SUCCESS [25.770s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.313s]
[INFO] Web Processing Service Module ..................... FAILURE [4:30.008s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [40.775s]
[INFO] Chart external graphics support ................... SUCCESS [2.040s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.321s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.988s]
[INFO] OWS request flow controller ....................... SUCCESS [27.361s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.516s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.599s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.179s]
[INFO] Core Monitor Extension ............................ SUCCESS [28.005s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [36.908s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.344s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [18.971s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.224s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [8.354s]
[INFO] XLST based WFS output format ...................... SUCCESS [58.063s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [50.560s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.026s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.120s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.857s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.109s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:45.527s]
[INFO] CSW UI Module ..................................... SUCCESS [27.893s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.129s]
[INFO] DXF WFS output format ............................. SUCCESS [38.268s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.171s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.306s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [37.148s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.897s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.156s]
[INFO] Importer Core Module .............................. SUCCESS [1:54.589s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:27.753s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.502s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.345s]
[INFO] BUILD FAILURE
[INFO] Total time: 38:01.372s (Wall Clock)
[INFO] Finished at: Fri May 29 00:46:03 UTC 2015
[INFO] Final Memory: 90M/237M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1441/&gt;
