[Geoserver-devel] Build failed in Jenkins: geoserver-master #1451
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1451/&gt;
[...truncated 18086 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1097 from kolosov-sergey/master
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 01.06.2015 @ 09:30:11 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 01-Jun-2015 15:41
[INFO] [GitCommitIdMojo] build.build.time = 01.06.2015 @ 16:14:23 UTC
[INFO] [GitCommitIdMojo] build.branch = 307591171391398791d24190df673f34d66dd99a
[INFO] [GitCommitIdMojo] build.commit.user.email = fgdrf@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Frank Gasdorf
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3075911
[INFO] [GitCommitIdMojo] build.commit.id = 307591171391398791d24190df673f34d66dd99a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1097 from kolosov-sergey/master
Thanks for updating Russian translations!
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 01.06.2015 @ 16:14:26 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.649s]
[INFO] Core Platform Module .............................. SUCCESS [15.844s]
[INFO] Open Web Service Module ........................... SUCCESS [19.527s]
[INFO] Main Module ....................................... SUCCESS [2:34.914s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.124s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:14.199s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:05.366s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.802s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.189s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:02.050s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:50.260s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:20.691s]
[INFO] Web Map Service Module ............................ SUCCESS [6:17.274s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:19.083s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:17.930s]
[INFO] REST Support Module ............................... SUCCESS [41.473s]
[INFO] REST Configuration Service Module ................. FAILURE [2:24.546s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.250s]
[INFO] Core UI Module .................................... SUCCESS [1:49.672s]
[INFO] WMS UI Module ..................................... SUCCESS [58.456s]
[INFO] GWC UI Module ..................................... SUCCESS [1:21.552s]
[INFO] WFS UI Module ..................................... SUCCESS [32.592s]
[INFO] Demoes Module ..................................... SUCCESS [1:00.797s]
[INFO] WCS UI Module ..................................... SUCCESS [40.204s]
[INFO] Security UI Modules ............................... SUCCESS [0.280s]
[INFO] Security UI Core Module ........................... SUCCESS [2:58.206s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:12.227s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.877s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.166s]
[INFO] Printing Module ................................... SUCCESS [37.610s]
[INFO] Community Space ................................... SUCCESS [0.198s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.530s]
[INFO] Application Schema Support ........................ SUCCESS [0.114s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.692s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.683s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.274s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.762s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.493s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.833s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.443s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.356s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.152s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.903s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.573s]
[INFO] OGR parent ........................................ SUCCESS [0.183s]
[INFO] OGR WFS ........................................... SUCCESS [26.023s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.203s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:01.702s]
[INFO] OGR WPS ........................................... SUCCESS [28.129s]
[INFO] Excel Output Format ............................... SUCCESS [41.892s]
[INFO] Chart external graphics support ................... SUCCESS [1.965s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.308s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.941s]
[INFO] OWS request flow controller ....................... SUCCESS [30.774s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [28.661s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:12.144s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.071s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.122s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.168s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.619s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [24.955s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.195s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.556s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.308s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.227s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [50.978s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.049s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.200s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [29.016s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [24.981s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.202s]
[INFO] CSW UI Module ..................................... SUCCESS [28.161s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.187s]
[INFO] DXF WFS output format ............................. SUCCESS [36.681s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.851s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.156s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [52.335s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.148s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.982s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.185s]
[INFO] Importer Core Module .............................. SUCCESS [1:47.502s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [56.266s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.391s]
[INFO] BUILD FAILURE
[INFO] Total time: 32:54.520s (Wall Clock)
[INFO] Finished at: Mon Jun 01 16:14:26 UTC 2015
[INFO] Final Memory: 87M/267M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1452/&gt;
[...truncated 10210 lines...]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-wcs2_0-eo ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] build.timestamp = 01-Jun-2015 16:52
[INFO] [GitCommitIdMojo] build.build.time = 01.06.2015 @ 17:05:26 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs2_0-eo ---
[INFO] Copying 3 resources
[INFO] Copying 9 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs2_0-eo ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs2_0-eo ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs2_0.eo.web.WCSEOAdminPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.052 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.041 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 01.06.2015 @ 17:05:48 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.203s]
[INFO] Core Platform Module .............................. SUCCESS [17.102s]
[INFO] Open Web Service Module ........................... SUCCESS [18.949s]
[INFO] Main Module ....................................... SUCCESS [2:32.182s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.723s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.407s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:58.785s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.851s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.820s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:03.578s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:01.349s]
[INFO] Web Feature Service Module ........................ FAILURE [3:19.353s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [41.926s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.383s]
[INFO] Core UI Module .................................... SUCCESS [1:48.786s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.139s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.208s]
[INFO] Printing Module ................................... SUCCESS [35.309s]
[INFO] Community Space ................................... SUCCESS [0.091s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.929s]
[INFO] Application Schema Support ........................ SUCCESS [0.090s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.845s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.042s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.836s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.725s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.385s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.366s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.739s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.701s]
[INFO] OGR parent ........................................ SUCCESS [0.114s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.220s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [6.304s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.141s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.805s]
[INFO] OWS request flow controller ....................... SUCCESS [27.900s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.711s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.647s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.355s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.872s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.638s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:33.161s]
[INFO] CSW UI Module ..................................... SUCCESS [28.427s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.086s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.139s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [44.920s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [21.844s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] Total time: 13:31.994s (Wall Clock)
[INFO] Finished at: Mon Jun 01 17:05:48 UTC 2015
[INFO] Final Memory: 62M/247M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1453/&gt;
