See <http://ares.opengeo.org/jenkins/job/geoserver-master/1472/changes>
Changes:
[andrea.aime] [GEOS-7066] Chance of WPS chained execution progress misreport when mixing complex and simple inputs
[...truncated 17697 lines...]
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.8-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7066] Chance of WPS chained execution progress misreport when mixing complex and simple inputs
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.06.2015 @ 17:05:35 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 09-Jun-2015 17:08
[INFO] [GitCommitIdMojo] build.build.time = 09.06.2015 @ 17:44:47 UTC
[INFO] [GitCommitIdMojo] build.branch = a59d2daf3d25a4387e9f3c351e9c0a8e83a5bcec
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a59d2da
[INFO] [GitCommitIdMojo] build.commit.id = a59d2daf3d25a4387e9f3c351e9c0a8e83a5bcec
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7066] Chance of WPS chained execution progress misreport when mixing complex and simple inputs
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.06.2015 @ 17:44:51 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.829s]
[INFO] Core Platform Module .............................. SUCCESS [16.082s]
[INFO] Open Web Service Module ........................... SUCCESS [20.252s]
[INFO] Main Module ....................................... SUCCESS [2:34.735s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.938s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.353s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:59.489s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.547s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.968s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.057s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:57.197s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:18.288s]
[INFO] Web Map Service Module ............................ SUCCESS [6:57.909s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:26.273s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:19.234s]
[INFO] REST Support Module ............................... SUCCESS [40.928s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:42.901s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.324s]
[INFO] Core UI Module .................................... SUCCESS [2:12.702s]
[INFO] WMS UI Module ..................................... SUCCESS [59.357s]
[INFO] GWC UI Module ..................................... SUCCESS [1:23.154s]
[INFO] WFS UI Module ..................................... SUCCESS [31.119s]
[INFO] Demoes Module ..................................... SUCCESS [53.096s]
[INFO] WCS UI Module ..................................... SUCCESS [40.303s]
[INFO] Security UI Modules ............................... SUCCESS [0.233s]
[INFO] Security UI Core Module ........................... SUCCESS [3:01.915s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:08.738s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.903s]
[INFO] REST UI Module .................................... SUCCESS [39.703s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.246s]
[INFO] Printing Module ................................... SUCCESS [40.883s]
[INFO] Community Space ................................... SUCCESS [0.199s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.991s]
[INFO] GeoServer Web Application ......................... SUCCESS [13.100s]
[INFO] Application Schema Support ........................ SUCCESS [0.156s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:01.720s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.476s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.280s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.935s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.098s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.411s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.752s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.491s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.450s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.054s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.869s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.586s]
[INFO] OGR parent ........................................ SUCCESS [0.197s]
[INFO] OGR WFS ........................................... SUCCESS [22.052s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.534s]
[INFO] Web Processing Service Module ..................... FAILURE [4:12.147s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [42.241s]
[INFO] Chart external graphics support ................... SUCCESS [3.497s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.442s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.804s]
[INFO] OWS request flow controller ....................... SUCCESS [28.910s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.173s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.420s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.305s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.756s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [21.202s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.249s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.649s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.366s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [5.360s]
[INFO] XLST based WFS output format ...................... SUCCESS [56.468s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [55.479s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.883s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.403s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.542s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.884s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:43.899s]
[INFO] CSW UI Module ..................................... SUCCESS [23.190s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.176s]
[INFO] DXF WFS output format ............................. SUCCESS [36.820s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.159s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [51.906s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [38.173s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.208s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.422s]
[INFO] Importer Core Module .............................. SUCCESS [2:01.858s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:30.436s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [56.774s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.353s]
[INFO] BUILD FAILURE
[INFO] Total time: 36:24.883s (Wall Clock)
[INFO] Finished at: Tue Jun 09 17:44:51 UTC 2015
[INFO] Final Memory: 88M/265M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
