See <http://ares.opengeo.org/jenkins/job/geoserver-master/1493/>
[...truncated 18154 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1103 from NielsCharlier/GEOS-7068
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.06.2015 @ 18:25:40 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-Jun-2015 11:16
[INFO] [GitCommitIdMojo] build.build.time = 15.06.2015 @ 11:50:01 UTC
[INFO] [GitCommitIdMojo] build.branch = 05b5f7e9315a616fb64f8bcf8a41ee511eb1d261
[INFO] [GitCommitIdMojo] build.commit.user.email = ksmith@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Kevin Smith
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 05b5f7e
[INFO] [GitCommitIdMojo] build.commit.id = 05b5f7e9315a616fb64f8bcf8a41ee511eb1d261
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1103 from NielsCharlier/GEOS-7068
GEOS-7068: fix GWC parameter filter editor bug
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 15.06.2015 @ 11:50:04 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.104s]
[INFO] Core Platform Module .............................. SUCCESS [21.083s]
[INFO] Open Web Service Module ........................... SUCCESS [19.262s]
[INFO] Main Module ....................................... SUCCESS [2:32.634s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.837s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.421s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.365s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.282s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.981s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:02.221s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:55.921s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:20.379s]
[INFO] Web Map Service Module ............................ SUCCESS [6:27.885s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:15.785s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:15.529s]
[INFO] REST Support Module ............................... SUCCESS [39.165s]
[INFO] REST Configuration Service Module ................. FAILURE [2:26.122s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.728s]
[INFO] Core UI Module .................................... SUCCESS [1:51.114s]
[INFO] WMS UI Module ..................................... SUCCESS [1:00.666s]
[INFO] GWC UI Module ..................................... SUCCESS [1:18.924s]
[INFO] WFS UI Module ..................................... SUCCESS [34.960s]
[INFO] Demoes Module ..................................... SUCCESS [59.926s]
[INFO] WCS UI Module ..................................... SUCCESS [39.535s]
[INFO] Security UI Modules ............................... SUCCESS [0.260s]
[INFO] Security UI Core Module ........................... SUCCESS [2:49.783s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:14.611s]
[INFO] Security UI LDAP Module ........................... SUCCESS [39.370s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.265s]
[INFO] Printing Module ................................... SUCCESS [36.669s]
[INFO] Community Space ................................... SUCCESS [0.167s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.637s]
[INFO] Application Schema Support ........................ SUCCESS [0.188s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.612s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.542s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.775s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.684s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.523s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.929s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.750s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.445s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.248s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.936s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.649s]
[INFO] OGR parent ........................................ SUCCESS [0.317s]
[INFO] OGR WFS ........................................... SUCCESS [25.900s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.446s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:05.638s]
[INFO] OGR WPS ........................................... SUCCESS [28.893s]
[INFO] Excel Output Format ............................... SUCCESS [40.734s]
[INFO] Chart external graphics support ................... SUCCESS [1.999s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.385s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.092s]
[INFO] OWS request flow controller ....................... SUCCESS [30.645s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.054s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:10.905s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.594s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.547s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.216s]
[INFO] Core Monitor Extension ............................ SUCCESS [32.714s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [24.106s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.472s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.279s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.285s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.136s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.119s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.915s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.376s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.866s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.614s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.719s]
[INFO] CSW UI Module ..................................... SUCCESS [32.765s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.416s]
[INFO] DXF WFS output format ............................. SUCCESS [36.137s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [25.566s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.240s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [52.812s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [40.459s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [20.966s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.276s]
[INFO] Importer Core Module .............................. SUCCESS [1:47.812s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [59.407s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.334s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:10.112s (Wall Clock)
[INFO] Finished at: Mon Jun 15 11:50:04 UTC 2015
[INFO] Final Memory: 85M/271M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
