See <http://ares.opengeo.org/jenkins/job/geoserver-master/1506/>
[...truncated 17612 lines...]
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1095 from smithkm/gwc-param-ui
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.06.2015 @ 21:17:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Jun-2015 23:31
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 00:03:08 UTC
[INFO] [GitCommitIdMojo] build.branch = 725743a0fef3b74b28d7e7e2895a47c9c688f22d
[INFO] [GitCommitIdMojo] build.commit.user.email = ksmith@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Kevin Smith
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 725743a
[INFO] [GitCommitIdMojo] build.commit.id = 725743a0fef3b74b28d7e7e2895a47c9c688f22d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1095 from smithkm/gwc-param-ui
GEOS-6987 - Support new GWC Parameter Filter options via UI
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 00:03:12 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.916s]
[INFO] Core Platform Module .............................. SUCCESS [15.683s]
[INFO] Open Web Service Module ........................... SUCCESS [19.466s]
[INFO] Main Module ....................................... SUCCESS [2:43.603s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.184s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.300s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.980s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.300s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.442s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:03.751s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:00.137s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:23.166s]
[INFO] Web Map Service Module ............................ SUCCESS [6:39.523s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:39.369s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [15.624s]
[INFO] REST Support Module ............................... SUCCESS [37.906s]
[INFO] REST Configuration Service Module ................. FAILURE [2:24.192s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.555s]
[INFO] Core UI Module .................................... SUCCESS [1:51.794s]
[INFO] WMS UI Module ..................................... SUCCESS [1:03.176s]
[INFO] WFS UI Module ..................................... SUCCESS [32.814s]
[INFO] Demoes Module ..................................... SUCCESS [1:01.612s]
[INFO] WCS UI Module ..................................... SUCCESS [43.676s]
[INFO] Security UI Modules ............................... SUCCESS [0.277s]
[INFO] Security UI Core Module ........................... SUCCESS [2:45.080s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:08.510s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.710s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.254s]
[INFO] Printing Module ................................... SUCCESS [37.948s]
[INFO] Community Space ................................... SUCCESS [0.163s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.208s]
[INFO] Application Schema Support ........................ SUCCESS [0.168s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.589s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [26.448s]
[INFO] GeoSearch Index Module ............................ SUCCESS [36.740s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.839s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.880s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.849s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.497s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.430s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.405s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.960s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.644s]
[INFO] OGR parent ........................................ SUCCESS [0.195s]
[INFO] OGR WFS ........................................... SUCCESS [25.991s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.404s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:35.036s]
[INFO] OGR WPS ........................................... SUCCESS [29.940s]
[INFO] Excel Output Format ............................... SUCCESS [40.727s]
[INFO] Chart external graphics support ................... SUCCESS [1.972s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.289s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.042s]
[INFO] OWS request flow controller ....................... SUCCESS [27.750s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [25.253s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:15.104s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.387s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.312s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.414s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.096s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.207s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.340s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.680s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.279s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.552s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.417s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.032s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.390s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.906s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.370s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:34.775s]
[INFO] CSW UI Module ..................................... SUCCESS [34.834s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.267s]
[INFO] DXF WFS output format ............................. SUCCESS [35.897s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.068s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.269s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.704s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.973s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.725s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.218s]
[INFO] Importer Core Module .............................. SUCCESS [1:48.971s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [57.796s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.883s]
[INFO] BUILD FAILURE
[INFO] Total time: 32:08.873s (Wall Clock)
[INFO] Finished at: Thu Jun 18 00:03:12 UTC 2015
[INFO] Final Memory: 84M/270M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[82,7\] error: GeoServerTileLayer is not abstract and does not override abstract method getBlobStoreId() in TileLayer
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
