[Geoserver-devel] Build failed in Jenkins: geoserver-master #1516
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1516/changes&gt;
Changes:
[groldan] ConfigurableBlobStore must ensure listeners are kept in sync with delegate.
[...truncated 17177 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = ed8ee88
[INFO] [GitCommitIdMojo] build.commit.id = ed8ee88376c17b3a4ae15fac9b8a396a4f858604
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1073 from groldan/restore_gwc_blobstore_listener
ConfigurableBlobStore must add listeners to delegate
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-bdb <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-bdb ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1073 from groldan/restore_gwc_blobstore_listener
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.06.2015 @ 14:45:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Jun-2015 16:36
[INFO] [GitCommitIdMojo] build.build.time = 19.06.2015 @ 17:09:14 UTC
[INFO] [GitCommitIdMojo] build.branch = ed8ee88376c17b3a4ae15fac9b8a396a4f858604
[INFO] [GitCommitIdMojo] build.commit.user.email = gabriel.roldan@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 19.06.2015 @ 17:09:15 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.305s]
[INFO] Core Platform Module .............................. SUCCESS [16.500s]
[INFO] Open Web Service Module ........................... SUCCESS [23.032s]
[INFO] Main Module ....................................... SUCCESS [2:32.280s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.435s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.833s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.492s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.249s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.057s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.337s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:56.321s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:18.527s]
[INFO] Web Map Service Module ............................ SUCCESS [6:53.989s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.748s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:27.743s]
[INFO] REST Support Module ............................... SUCCESS [42.115s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:26.160s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.558s]
[INFO] Core UI Module .................................... SUCCESS [1:55.450s]
[INFO] WMS UI Module ..................................... SUCCESS [57.482s]
[INFO] GWC UI Module ..................................... SUCCESS [1:30.585s]
[INFO] WFS UI Module ..................................... SUCCESS [31.603s]
[INFO] Demoes Module ..................................... SUCCESS [55.571s]
[INFO] WCS UI Module ..................................... SUCCESS [41.317s]
[INFO] Security UI Modules ............................... SUCCESS [0.639s]
[INFO] Security UI Core Module ........................... SUCCESS [2:50.116s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:36.080s]
[INFO] Security UI LDAP Module ........................... SUCCESS [43.748s]
[INFO] REST UI Module .................................... SUCCESS [37.172s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.287s]
[INFO] Printing Module ................................... SUCCESS [38.852s]
[INFO] Community Space ................................... SUCCESS [0.170s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.240s]
[INFO] Application Schema Support ........................ SUCCESS [0.187s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:04.448s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.169s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.830s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.894s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.263s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.631s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.975s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.494s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.952s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.106s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.977s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.774s]
[INFO] OGR parent ........................................ SUCCESS [0.252s]
[INFO] OGR WFS ........................................... SUCCESS [26.873s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.495s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [41.827s]
[INFO] Chart external graphics support ................... SUCCESS [1.852s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.241s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.034s]
[INFO] OWS request flow controller ....................... SUCCESS [28.006s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.558s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.952s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.062s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.985s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [22.435s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.233s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [16.095s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.364s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [5.105s]
[INFO] XLST based WFS output format ...................... SUCCESS [53.303s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.856s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.544s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.255s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.047s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.245s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:34.554s]
[INFO] CSW UI Module ..................................... SUCCESS [24.748s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.524s]
[INFO] DXF WFS output format ............................. SUCCESS [36.366s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.323s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.934s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.268s]
[INFO] Importer Core Module .............................. SUCCESS [1:54.089s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:13.470s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.394s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.027s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:05.127s (Wall Clock)
[INFO] Finished at: Fri Jun 19 17:09:15 UTC 2015
[INFO] Final Memory: 83M/257M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
FWIW, the failure doesn’t seem related to my commit.
On Fri, Jun 19, 2015 at 2:09 PM, <monitor@anonymised.com> wrote:
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1516/changes>
Changes:
[…truncated 17177 lines…]
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-bdb —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] — git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-bdb —
[INFO] [GitCommitIdMojo] Running on ‘<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository…
[INFO] [GitCommitIdMojo] Initializing properties…
[INFO] [GitCommitIdMojo] Using maven project properties…
[INFO] [GitCommitIdMojo] Loading data from git repository…
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gs-importer-bdb —
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-cas —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO]
[INFO] — git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas —
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas —
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [8.305s]
[INFO] Core Platform Module … SUCCESS [16.500s]
[INFO] Open Web Service Module … SUCCESS [23.032s]
[INFO] Main Module … SUCCESS [2:32.280s]
[INFO] GeoServer Security Modules … SUCCESS [1.435s]
[INFO] GeoServer JDBC Security Module … SUCCESS [1:11.833s]
[INFO] GeoServer LDAP Security Module … SUCCESS [2:04.492s]
[INFO] Web Coverage Service Module … SUCCESS [6.249s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [42.057s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [1:05.337s]
[INFO] Web Coverage Service 2.0 Module … FAILURE [1:56.321s]
[INFO] Web Feature Service Module … SUCCESS [3:18.527s]
[INFO] Web Map Service Module … SUCCESS [6:53.989s]
[INFO] KML support for GeoServer … SUCCESS [1:22.748s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [2:27.743s]
[INFO] REST Support Module … SUCCESS [42.115s]
[INFO] REST Configuration Service Module … SUCCESS [2:26.160s]
[INFO] GeoServer Web Modules … SUCCESS [0.558s]
[INFO] Core UI Module … SUCCESS [1:55.450s]
[INFO] WMS UI Module … SUCCESS [57.482s]
[INFO] GWC UI Module … SUCCESS [1:30.585s]
[INFO] WFS UI Module … SUCCESS [31.603s]
[INFO] Demoes Module … SUCCESS [55.571s]
[INFO] WCS UI Module … SUCCESS [41.317s]
[INFO] Security UI Modules … SUCCESS [0.639s]
[INFO] Security UI Core Module … SUCCESS [2:50.116s]
[INFO] Security UI JDBC Module … SUCCESS [2:36.080s]
[INFO] Security UI LDAP Module … SUCCESS [43.748s]
[INFO] REST UI Module … SUCCESS [37.172s]
[INFO] GeoServer Extensions … SUCCESS [0.287s]
[INFO] Printing Module … SUCCESS [38.852s]
[INFO] Community Space … SUCCESS [0.170s]
[INFO] HTTP Proxy Extension … SUCCESS [12.240s]
[INFO] GeoServer Web Application … SKIPPED
[INFO] Application Schema Support … SUCCESS [0.187s]
[INFO] Application Schema Integration Test … SUCCESS [4:04.448s]
[INFO] Sample DataAccess Integration Test … SUCCESS [35.169s]
[INFO] ArcSDE DataStore Extension … SUCCESS [28.830s]
[INFO] GeoSearch Index Module … SUCCESS [31.894s]
[INFO] H2 DataStore Extension … SUCCESS [23.263s]
[INFO] SQL Server DataStore Extension … SUCCESS [2.631s]
[INFO] Oracle DataStore Extension … SUCCESS [0.975s]
[INFO] MySQL DataStore Extension … SUCCESS [0.494s]
[INFO] DB2 DataStore Extension … SUCCESS [0.952s]
[INFO] ImageMap Output Format … SUCCESS [20.106s]
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [0.977s]
[INFO] JP2K Coverage Extension … SUCCESS [0.774s]
[INFO] OGR parent … SUCCESS [0.252s]
[INFO] OGR WFS … SUCCESS [26.873s]
[INFO] Web Processing Service parent … SUCCESS [0.495s]
[INFO] Web Processing Service Module … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SUCCESS [41.827s]
[INFO] Chart external graphics support … SUCCESS [1.852s]
[INFO] Feature Generalization Extension … SUCCESS [4.241s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [1.034s]
[INFO] OWS request flow controller … SUCCESS [28.006s]
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SUCCESS [51.558s]
[INFO] Teradata DataStore Extension … SUCCESS [4.952s]
[INFO] GeoServer Monitor Extensions … SUCCESS [1.062s]
[INFO] Core Monitor Extension … SUCCESS [33.985s]
[INFO] Monitor Hibernate Extension … SUCCESS [22.435s]
[INFO] GeoServer Security Extension Modules … SUCCESS [0.233s]
[INFO] GeoServer CAS Security Module … SUCCESS [16.095s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [0.364s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [5.105s]
[INFO] XLST based WFS output format … SUCCESS [53.303s]
[INFO] GeoServer INSPIRE Extensions … SUCCESS [54.856s]
[INFO] GeoServer CSS Styling … SUCCESS [37.544s]
[INFO] Catalog Services for the Web parent … SUCCESS [0.255s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [28.047s]
[INFO] Catalog Services for the Web core module … SUCCESS [1:34.554s]
[INFO] CSW UI Module … SUCCESS [24.748s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [0.524s]
[INFO] DXF WFS output format … SUCCESS [36.366s]
[INFO] DXF WPS PPIO … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [0.323s]
[INFO] GeoServer libjpeg-turbo Module … SUCCESS [21.934s]
[INFO] GeoServer Data Importer … SUCCESS [0.268s]
[INFO] Importer Core Module … SUCCESS [1:54.089s]
[INFO] Importer REST Api Module … SUCCESS [1:13.470s]
[INFO] Importer Berkley DB Persistence Module … SUCCESS [54.394s]
[INFO] Importer Web UI Module … SUCCESS [8.027s]
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wcs2_0
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@boundlessgeo
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1517/changes&gt;
