[Geoserver-devel] Build failed in Jenkins: geoserver-master #153
See <http://ares.opengeo.org/jenkins/job/geoserver-master/153/changes&gt;
Changes:
[andrea.aime] [GEOS-6221] Have GetFeatureInfo report what the user really clicked onto (taking into account symbol shapes and the like)
[...truncated 79979 lines...]
[INFO] Nothing to compile - all classes are up to date
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/11-SNAPSHOT/gt-coverage-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/11-SNAPSHOT/gt-xsd-sld-11-SNAPSHOT.jar
[INFO] Tests are skipped.
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.5-SNAPSHOT/gs-sample-data-access-test-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.5-SNAPSHOT/gs-sample-data-access-test-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.5-SNAPSHOT/gs-sample-data-access-test-2.5-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-sample-data-access-test/2.5-SNAPSHOT/gs-sample-data-access-test-2.5-SNAPSHOT.jar
2397/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:gs-sample-data-access-test'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:gs-sample-data-access-test:2.5-SNAPSHOT'
[INFO] Uploading project information for gs-sample-data-access-test 2.5-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-sample-data-access-test/2.5-SNAPSHOT/gs-sample-data-access-test-2.5-SNAPSHOT-tests.jar
4096/?
8192/?
11126/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-sample-data-access-test/2.5-SNAPSHOT/gs-sample-data-access-test-2.5-SNAPSHOT-test-sources.jar
4096/?
5572/?
[INFO] Building ArcSDE DataStore Extension
[INFO] task-segment: [deploy]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6221] Have GetFeatureInfo report what the user really clicked onto (taking into account symbol shapes and the like)
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.12.2013 @ 12:06:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Dec-2013 12:49
[INFO] [GitCommitIdMojo] build.build.time = 17.12.2013 @ 12:51:51 UTC
[INFO] [GitCommitIdMojo] build.branch = abdd6b0f12abab412d501e54878638ca79520b9f
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = abdd6b0
[INFO] [GitCommitIdMojo] build.commit.id = abdd6b0f12abab412d501e54878638ca79520b9f
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6221] Have GetFeatureInfo report what the user really clicked onto (taking into account symbol shapes and the like)
[INFO] Copying 3 resources
[INFO] Copying 8 resources
[INFO] snapshot org.geotools:gt-arcsde-common:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde-common:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:arcsde-plugin:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcsde:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-sde-dummy:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sde-dummy:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-postgis/11-SNAPSHOT/gt-jdbc-postgis-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/11-SNAPSHOT/gt-arcgrid-11-SNAPSHOT.jar
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/src/test/resources&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/arcsde/target/gs-arcsde-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT-test-sources.jar
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
27541/?
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:gs-arcsde:2.5-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:gs-arcsde'
[INFO] Uploading project information for gs-arcsde 2.5-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT-tests.jar
4096/?
8192/?
9765/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
14713/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-arcsde/2.5-SNAPSHOT/gs-arcsde-2.5-SNAPSHOT-test-sources.jar
3380/?
[INFO] Building GeoSearch Index Module
[INFO] [GitCommitIdMojo] build.build.time = 17.12.2013 @ 12:51:55 UTC
[INFO] Copying 7 resources
[INFO] Copying 2 resources
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: Server returned HTTP response code: 408 for URL: http://repo.opengeo.org/org/geotools/gt-arcgrid/11-SNAPSHOT/gt-arcgrid-11-SNAPSHOT.jar
  org.geotools:gt-arcgrid:jar:11-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
  opengeo (http://repo.opengeo.org/)
Path to dependency:
  1) org.geoserver.extension:gs-geosearch:jar:2.5-SNAPSHOT
  2) org.geoserver.web:gs-web-core:jar:2.5-SNAPSHOT
  3) org.geotools:gt-arcgrid:jar:11-SNAPSHOT
[INFO] Total time: 3 minutes 15 seconds
[INFO] Finished at: Tue Dec 17 12:52:56 UTC 2013
[INFO] Final Memory: 84M/301M
See <http://ares.opengeo.org/jenkins/job/geoserver-master/154/&gt;
