[Geoserver-devel] Build failed in Jenkins: geoserver-master #1565
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1565/changes&gt;
Changes:
[jody.garnett] include maven placeholder directories
[jody.garnett] do not target java 1.5
[jody.garnett] easy to include gs-programming-guide project
[jody.garnett] cross link to eclipse guide instructions
[jody.garnett] no need to reference svn
[jody.garnett] describe how to try out from eclipse
[jody.garnett] overview of ows services
[tbarsballe] [GEOS-7102] Importer support for non-JDBC databases
[...truncated 18286 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1131 from jodygarnett/doc_review
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 07.07.2015 @ 19:45:35 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Jul-2015 20:27
[INFO] [GitCommitIdMojo] build.build.time = 07.07.2015 @ 21:00:56 UTC
[INFO] [GitCommitIdMojo] build.branch = 3d9f9dae35738d4996772d36325974a050d173af
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3d9f9da
[INFO] [GitCommitIdMojo] build.commit.id = 3d9f9dae35738d4996772d36325974a050d173af
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1131 from jodygarnett/doc_review
developers guide tutorial review and cleanup (GSIP-129)
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 07.07.2015 @ 21:00:59 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.172s]
[INFO] Core Platform Module .............................. SUCCESS [16.274s]
[INFO] Open Web Service Module ........................... SUCCESS [24.686s]
[INFO] Main Module ....................................... SUCCESS [2:41.665s]
[INFO] GeoServer Security Modules ........................ SUCCESS [3.274s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.105s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.447s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.372s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.426s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:01.696s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:56.392s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:20.105s]
[INFO] Web Map Service Module ............................ SUCCESS [6:47.698s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:18.169s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:24.094s]
[INFO] REST Support Module ............................... SUCCESS [43.410s]
[INFO] REST Configuration Service Module ................. FAILURE [2:34.867s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.534s]
[INFO] Core UI Module .................................... SUCCESS [1:50.183s]
[INFO] WMS UI Module ..................................... SUCCESS [57.431s]
[INFO] GWC UI Module ..................................... SUCCESS [1:27.158s]
[INFO] WFS UI Module ..................................... SUCCESS [30.855s]
[INFO] Demoes Module ..................................... SUCCESS [1:03.479s]
[INFO] WCS UI Module ..................................... SUCCESS [40.947s]
[INFO] Security UI Modules ............................... SUCCESS [0.276s]
[INFO] Security UI Core Module ........................... SUCCESS [2:56.287s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:09.391s]
[INFO] Security UI LDAP Module ........................... SUCCESS [37.511s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.258s]
[INFO] Printing Module ................................... SUCCESS [37.688s]
[INFO] Community Space ................................... SUCCESS [0.169s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.983s]
[INFO] Application Schema Support ........................ SUCCESS [0.199s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.632s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.473s]
[INFO] GeoSearch Index Module ............................ SUCCESS [30.698s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.821s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.907s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.303s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.797s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.905s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.629s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.630s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.653s]
[INFO] OGR parent ........................................ SUCCESS [0.177s]
[INFO] OGR WFS ........................................... SUCCESS [24.654s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.506s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:14.229s]
[INFO] OGR WPS ........................................... SUCCESS [28.806s]
[INFO] Excel Output Format ............................... SUCCESS [40.958s]
[INFO] Chart external graphics support ................... SUCCESS [2.495s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.823s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [2.086s]
[INFO] OWS request flow controller ....................... SUCCESS [30.128s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.428s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:15.163s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.079s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.722s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.214s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.037s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.106s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.240s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.811s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.212s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.478s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.461s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.573s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.267s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.653s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.412s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:28.912s]
[INFO] CSW UI Module ..................................... SUCCESS [26.225s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.399s]
[INFO] DXF WFS output format ............................. SUCCESS [37.501s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.069s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.177s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [58.801s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.343s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [28.314s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.451s]
[INFO] Importer Core Module .............................. SUCCESS [1:47.262s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.625s]
[INFO] Importer Web UI Module ............................ SUCCESS [10.057s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:44.847s (Wall Clock)
[INFO] Finished at: Tue Jul 07 21:00:59 UTC 2015
[INFO] Final Memory: 85M/262M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
Hmm. Works locally for me. And Travis CI. Kicked the build to see if this is an intermittent failure.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1566/&gt;
