See <http://ares.opengeo.org/jenkins/job/geoserver-master/1619/>
[...truncated 12900 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 27-Jul-2015 21:34
[INFO] [GitCommitIdMojo] build.build.time = 27.07.2015 @ 22:02:58 UTC
[INFO] [GitCommitIdMojo] build.branch = 01c6d4f220014408f328dfc0a5d9b27a21cd3c9a
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com268...
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 01c6d4f
[INFO] [GitCommitIdMojo] build.commit.id = 01c6d4f220014408f328dfc0a5d9b27a21cd3c9a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1158 from dromagnoli/GEOS-7126
[GEOS-7126]: Updating included files into NetCDF/GRIB zip community m…
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-cluster-hazelcast ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1158 from dromagnoli/GEOS-7126
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 27.07.2015 @ 14:03:24 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.388 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] build.build.time = 27.07.2015 @ 22:03:04 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [29.075s]
[INFO] Core Platform Module .............................. SUCCESS [35.108s]
[INFO] Open Web Service Module ........................... SUCCESS [51.209s]
[INFO] Main Module ....................................... SUCCESS [3:51.356s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.540s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.546s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7:47.489s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.712s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [51.769s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.173s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:01.139s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:34.400s]
[INFO] Web Map Service Module ............................ FAILURE [8:19.555s]
[INFO] REST Support Module ............................... SUCCESS [43.722s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.303s]
[INFO] Core UI Module .................................... SUCCESS [2:32.237s]
[INFO] WFS UI Module ..................................... SUCCESS [30.306s]
[INFO] Security UI Modules ............................... SUCCESS [0.744s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.921s]
[INFO] Printing Module ................................... SUCCESS [39.985s]
[INFO] Community Space ................................... SUCCESS [0.478s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [14.235s]
[INFO] Application Schema Support ........................ SUCCESS [0.936s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.321s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [26.123s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.153s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.989s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [3.314s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [2.079s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.692s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [6.127s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [3.901s]
[INFO] OGR parent ........................................ SUCCESS [1.524s]
[INFO] OGR WFS ........................................... SUCCESS [26.197s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.339s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:59.321s]
[INFO] OGR WPS ........................................... SUCCESS [24.340s]
[INFO] Excel Output Format ............................... SUCCESS [42.988s]
[INFO] Chart external graphics support ................... SUCCESS [3.948s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.272s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [2.603s]
[INFO] OWS request flow controller ....................... SUCCESS [28.170s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [39.239s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.125s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.528s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.958s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [33.609s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [1.449s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.104s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.592s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:41.692s]
[INFO] CSW UI Module ..................................... SUCCESS [27.606s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [1.579s]
[INFO] DXF WFS output format ............................. SUCCESS [39.366s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [20.233s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.409s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [48.934s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.541s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 28:50.247s (Wall Clock)
[INFO] Finished at: Mon Jul 27 22:03:04 UTC 2015
[INFO] Final Memory: 67M/221M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
