[Geoserver-devel] Build failed in Jenkins: geoserver-master #1621
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1621/&gt;
[...truncated 16934 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1158 from dromagnoli/GEOS-7126
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 27.07.2015 @ 14:03:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Jul-2015 08:55
[INFO] [GitCommitIdMojo] build.build.time = 28.07.2015 @ 09:28:40 UTC
[INFO] [GitCommitIdMojo] build.branch = 01c6d4f220014408f328dfc0a5d9b27a21cd3c9a
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com268...
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 01c6d4f
[INFO] [GitCommitIdMojo] build.commit.id = 01c6d4f220014408f328dfc0a5d9b27a21cd3c9a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1158 from dromagnoli/GEOS-7126
[GEOS-7126]: Updating included files into NetCDF/GRIB zip community m…
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 28.07.2015 @ 09:28:44 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.466s]
[INFO] Core Platform Module .............................. SUCCESS [17.040s]
[INFO] Open Web Service Module ........................... SUCCESS [18.929s]
[INFO] Main Module ....................................... SUCCESS [2:30.980s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.263s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:09.810s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.550s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.111s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.896s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.226s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:55.284s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:21.916s]
[INFO] Web Map Service Module ............................ SUCCESS [6:46.512s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.997s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:24.274s]
[INFO] REST Support Module ............................... SUCCESS [40.791s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:36.732s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.511s]
[INFO] Core UI Module .................................... SUCCESS [1:53.193s]
[INFO] WMS UI Module ..................................... SUCCESS [51.996s]
[INFO] GWC UI Module ..................................... SUCCESS [1:31.348s]
[INFO] WFS UI Module ..................................... SUCCESS [33.307s]
[INFO] Demoes Module ..................................... SUCCESS [51.642s]
[INFO] WCS UI Module ..................................... SUCCESS [39.367s]
[INFO] Security UI Modules ............................... SUCCESS [0.302s]
[INFO] Security UI Core Module ........................... SUCCESS [2:53.092s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:02.633s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.190s]
[INFO] REST UI Module .................................... SUCCESS [34.960s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.279s]
[INFO] Printing Module ................................... SUCCESS [38.862s]
[INFO] Community Space ................................... SUCCESS [0.220s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.940s]
[INFO] Application Schema Support ........................ SUCCESS [0.214s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:49.045s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.813s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.129s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.987s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.656s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.390s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.706s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.464s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.507s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.934s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.457s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.808s]
[INFO] OGR parent ........................................ SUCCESS [0.315s]
[INFO] OGR WFS ........................................... SUCCESS [26.338s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.478s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [41.397s]
[INFO] Chart external graphics support ................... SUCCESS [1.743s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.050s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.937s]
[INFO] OWS request flow controller ....................... SUCCESS [32.476s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.044s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.959s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.281s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.541s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.800s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.301s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.152s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.257s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.382s]
[INFO] XLST based WFS output format ...................... SUCCESS [53.433s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.485s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.977s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.393s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.045s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.091s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:37.693s]
[INFO] CSW UI Module ..................................... SUCCESS [25.780s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.288s]
[INFO] DXF WFS output format ............................. SUCCESS [37.706s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.390s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.809s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.710s]
[INFO] Importer Core Module .............................. SUCCESS [1:52.191s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:31.034s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.719s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.122s]
[INFO] BUILD FAILURE
[INFO] Total time: 32:46.032s (Wall Clock)
[INFO] Finished at: Tue Jul 28 09:28:45 UTC 2015
[INFO] Final Memory: 83M/260M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1622/changes&gt;
