[Geoserver-devel] Build failed in Jenkins: geoserver-master #1631
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1631/changes&gt;
Changes:
[groldan] Add unit tests to GeoJSON vector tile builder.
[...truncated 13283 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Add unit tests to GeoJSON vector tile builder.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 30.07.2015 @ 14:16:44 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 30-Jul-2015 16:23
[INFO] [GitCommitIdMojo] build.build.time = 30.07.2015 @ 16:45:01 UTC
[INFO] [GitCommitIdMojo] build.branch = 0dcb1af60936e20bcb50bfbb94a9fcdb59651e15
[INFO] [GitCommitIdMojo] build.commit.user.email = jmiller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jmiller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0dcb1af
[INFO] [GitCommitIdMojo] build.commit.id = 0dcb1af60936e20bcb50bfbb94a9fcdb59651e15
[INFO] [GitCommitIdMojo] build.commit.message.full = Add unit tests to GeoJSON vector tile builder.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-cluster-hazelcast ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.259 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] build.build.time = 30.07.2015 @ 16:45:12 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.407s]
[INFO] Core Platform Module .............................. SUCCESS [16.905s]
[INFO] Open Web Service Module ........................... SUCCESS [21.103s]
[INFO] Main Module ....................................... SUCCESS [2:30.078s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.329s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.638s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.626s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.547s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.608s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.972s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.582s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:26.650s]
[INFO] Web Map Service Module ............................ FAILURE [7:10.345s]
[INFO] REST Support Module ............................... SUCCESS [39.697s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.636s]
[INFO] Core UI Module .................................... SUCCESS [1:50.053s]
[INFO] WFS UI Module ..................................... SUCCESS [31.043s]
[INFO] Security UI Modules ............................... SUCCESS [0.238s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.344s]
[INFO] Printing Module ................................... SUCCESS [39.737s]
[INFO] Community Space ................................... SUCCESS [0.196s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.016s]
[INFO] Application Schema Support ........................ SUCCESS [0.200s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.793s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.908s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.426s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.999s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.784s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.496s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.465s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.258s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.822s]
[INFO] OGR parent ........................................ SUCCESS [0.155s]
[INFO] OGR WFS ........................................... SUCCESS [24.409s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.457s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:09.414s]
[INFO] OGR WPS ........................................... SUCCESS [26.069s]
[INFO] Excel Output Format ............................... SUCCESS [40.278s]
[INFO] Chart external graphics support ................... SUCCESS [2.274s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.499s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.059s]
[INFO] OWS request flow controller ....................... SUCCESS [30.103s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [33.610s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.437s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.881s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.354s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.929s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.363s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.968s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.182s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.008s]
[INFO] CSW UI Module ..................................... SUCCESS [24.556s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.243s]
[INFO] DXF WFS output format ............................. SUCCESS [36.404s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [18.618s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.151s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [53.706s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.747s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21:58.833s (Wall Clock)
[INFO] Finished at: Thu Jul 30 16:45:12 UTC 2015
[INFO] Final Memory: 68M/228M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1632/&gt;
[...truncated 13227 lines...]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 30-Jul-2015 17:26
[INFO] [GitCommitIdMojo] build.build.time = 30.07.2015 @ 17:47:41 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.232s]
[INFO] Core Platform Module .............................. SUCCESS [16.536s]
[INFO] Open Web Service Module ........................... SUCCESS [19.888s]
[INFO] Main Module ....................................... SUCCESS [2:33.420s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.233s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.667s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.565s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.899s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.544s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.217s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:51.829s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:21.546s]
[INFO] Web Map Service Module ............................ FAILURE [7:10.963s]
[INFO] REST Support Module ............................... SUCCESS [40.515s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.933s]
[INFO] Core UI Module .................................... SUCCESS [1:53.228s]
[INFO] WFS UI Module ..................................... SUCCESS [31.844s]
[INFO] Security UI Modules ............................... SUCCESS [0.244s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.258s]
[INFO] Printing Module ................................... SUCCESS [37.266s]
[INFO] Community Space ................................... SUCCESS [0.208s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.798s]
[INFO] Application Schema Support ........................ SUCCESS [0.196s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.823s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.283s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.104s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.377s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.651s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.489s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.603s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.927s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.878s]
[INFO] OGR parent ........................................ SUCCESS [0.304s]
[INFO] OGR WFS ........................................... SUCCESS [23.835s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.290s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:06.882s]
[INFO] OGR WPS ........................................... SUCCESS [27.318s]
[INFO] Excel Output Format ............................... SUCCESS [40.336s]
[INFO] Chart external graphics support ................... SUCCESS [1.987s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.679s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.116s]
[INFO] OWS request flow controller ....................... SUCCESS [29.305s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [30.232s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.147s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.544s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.455s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.425s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.557s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.638s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.311s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.381s]
[INFO] CSW UI Module ..................................... SUCCESS [25.055s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.437s]
[INFO] DXF WFS output format ............................. SUCCESS [37.261s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.036s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.445s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [53.238s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [31.682s]
[INFO] Total time: 21:38.320s (Wall Clock)
[INFO] Finished at: Thu Jul 30 17:47:41 UTC 2015
[INFO] Final Memory: 68M/230M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hum
this is probably the result of my image mosaic commit in GeoTools, although
I did not see it happening yesterday when I built before making the pull
request.
I have to go now, will check tomorrow
On Thu, Jul 30, 2015 at 7:47 PM, <monitor@anonymised.com9…> wrote:
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1632/>
[…truncated 13227 lines…]
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps —
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] — git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-cluster-hazelcast —
[INFO]
[INFO] — git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps —
[INFO] [GitCommitIdMojo] Running on ‘<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository…
[INFO] [GitCommitIdMojo] Initializing properties…
[INFO] [GitCommitIdMojo] Using maven project properties…
[INFO] [GitCommitIdMojo] Loading data from git repository…
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps —
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gs-wps-cluster-hazelcast —
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] GeoServer … SUCCESS [7.232s]
[INFO] Core Platform Module … SUCCESS [16.536s]
[INFO] Open Web Service Module … SUCCESS [19.888s]
[INFO] Main Module … SUCCESS [2:33.420s]
[INFO] GeoServer Security Modules … SUCCESS [0.233s]
[INFO] GeoServer JDBC Security Module … SUCCESS [1:12.667s]
[INFO] GeoServer LDAP Security Module … SUCCESS [2:02.565s]
[INFO] Web Coverage Service Module … SUCCESS [6.899s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [43.544s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [1:08.217s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [1:51.829s]
[INFO] Web Feature Service Module … SUCCESS [3:21.546s]
[INFO] Web Map Service Module … FAILURE [7:10.963s]
[INFO] KML support for GeoServer … SKIPPED
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] REST Support Module … SUCCESS [40.515s]
[INFO] REST Configuration Service Module … SKIPPED
[INFO] GeoServer Web Modules … SUCCESS [0.933s]
[INFO] Core UI Module … SUCCESS [1:53.228s]
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SUCCESS [31.844s]
[INFO] Demoes Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SUCCESS [0.244s]
[INFO] Security UI Core Module … SKIPPED
[INFO] Security UI JDBC Module … SKIPPED
[INFO] Security UI LDAP Module … SKIPPED
[INFO] REST UI Module … SKIPPED
[INFO] GeoServer Extensions … SUCCESS [0.258s]
[INFO] Printing Module … SUCCESS [37.266s]
[INFO] Community Space … SUCCESS [0.208s]
[INFO] HTTP Proxy Extension … SUCCESS [11.798s]
[INFO] GeoServer Web Application … SKIPPED
[INFO] Application Schema Support … SUCCESS [0.196s]
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SUCCESS [32.823s]
[INFO] ArcSDE DataStore Extension … SUCCESS [30.283s]
[INFO] GeoSearch Index Module … SKIPPED
[INFO] H2 DataStore Extension … SUCCESS [22.104s]
[INFO] SQL Server DataStore Extension … SUCCESS [1.377s]
[INFO] Oracle DataStore Extension … SUCCESS [0.651s]
[INFO] MySQL DataStore Extension … SUCCESS [0.489s]
[INFO] DB2 DataStore Extension … SUCCESS [0.603s]
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [0.927s]
[INFO] JP2K Coverage Extension … SUCCESS [0.878s]
[INFO] OGR parent … SUCCESS [0.304s]
[INFO] OGR WFS … SUCCESS [23.835s]
[INFO] Web Processing Service parent … SUCCESS [0.290s]
[INFO] Web Processing Service Module … SUCCESS [4:06.882s]
[INFO] OGR WPS … SUCCESS [27.318s]
[INFO] Excel Output Format … SUCCESS [40.336s]
[INFO] Chart external graphics support … SUCCESS [1.987s]
[INFO] Feature Generalization Extension … SUCCESS [5.679s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [1.116s]
[INFO] OWS request flow controller … SUCCESS [29.305s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [30.232s]
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SUCCESS [51.147s]
[INFO] Teradata DataStore Extension … SUCCESS [5.544s]
[INFO] GeoServer Monitor Extensions … SUCCESS [0.455s]
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SUCCESS [40.425s]
[INFO] Catalog Services for the Web parent … SUCCESS [0.557s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [25.638s]
[INFO] Catalog Services for the Web core module … SUCCESS [1:31.381s]
[INFO] CSW UI Module … SUCCESS [25.055s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [0.437s]
[INFO] DXF WFS output format … SUCCESS [37.261s]
[INFO] DXF WPS PPIO … SUCCESS [23.036s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [0.445s]
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wms
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1633/changes&gt;
Changes:
[maurobartolomeoli] GEOS-7131: fixed formatting in credentialsfromheaders tutorial
[...truncated 13440 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 31-Jul-2015 08:27
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 08:49:39 UTC
[INFO] [GitCommitIdMojo] build.branch = defe3b646a1dd45182979fe0073ce9326848b2f8
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = defe3b6
[INFO] [GitCommitIdMojo] build.commit.id = defe3b646a1dd45182979fe0073ce9326848b2f8
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1167 from mbarto/geos_7131
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1167 from mbarto/geos_7131
[INFO] [GitCommitIdMojo] build.commit.time = 31.07.2015 @ 08:26:09 UTC
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.331 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 08:49:48 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.734s]
[INFO] Core Platform Module .............................. SUCCESS [17.322s]
[INFO] Open Web Service Module ........................... SUCCESS [21.726s]
[INFO] Main Module ....................................... SUCCESS [2:41.464s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.262s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.695s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:01.645s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.392s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.903s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:03.484s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:56.678s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:38.971s]
[INFO] Web Map Service Module ............................ FAILURE [6:48.516s]
[INFO] REST Support Module ............................... SUCCESS [38.784s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.326s]
[INFO] Core UI Module .................................... SUCCESS [2:04.892s]
[INFO] WFS UI Module ..................................... SUCCESS [31.307s]
[INFO] Security UI Modules ............................... SUCCESS [0.409s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.312s]
[INFO] Printing Module ................................... SUCCESS [37.721s]
[INFO] Community Space ................................... SUCCESS [0.203s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.207s]
[INFO] Application Schema Support ........................ SUCCESS [0.262s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.981s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.857s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.453s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.982s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.205s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.525s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.486s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.969s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.617s]
[INFO] OGR parent ........................................ SUCCESS [0.167s]
[INFO] OGR WFS ........................................... SUCCESS [25.927s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.710s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:15.064s]
[INFO] OGR WPS ........................................... SUCCESS [25.015s]
[INFO] Excel Output Format ............................... SUCCESS [38.144s]
[INFO] Chart external graphics support ................... SUCCESS [2.023s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.437s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.636s]
[INFO] OWS request flow controller ....................... SUCCESS [31.742s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [34.545s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.776s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.932s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.311s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [35.736s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.367s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.976s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [24.969s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:40.496s]
[INFO] CSW UI Module ..................................... SUCCESS [23.772s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.186s]
[INFO] DXF WFS output format ............................. SUCCESS [38.173s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [19.221s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.286s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.580s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.544s]
[INFO] Total time: 22:05.767s (Wall Clock)
[INFO] Finished at: Fri Jul 31 08:49:48 UTC 2015
[INFO] Final Memory: 68M/233M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1634/&gt;
