See <http://ares.opengeo.org/jenkins/job/geoserver-master/1637/>
[...truncated 13171 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 31-Jul-2015 15:09
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 15:35:59 UTC
[INFO] [GitCommitIdMojo] build.branch = defe3b646a1dd45182979fe0073ce9326848b2f8
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = defe3b6
[INFO] [GitCommitIdMojo] build.commit.id = defe3b646a1dd45182979fe0073ce9326848b2f8
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1167 from mbarto/geos_7131
GEOS-7131: fixed formatting in credentialsfromheaders tutorial
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-cluster-hazelcast ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1167 from mbarto/geos_7131
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 31.07.2015 @ 08:26:09 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.193 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 15:36:08 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.131s]
[INFO] Core Platform Module .............................. SUCCESS [15.937s]
[INFO] Open Web Service Module ........................... SUCCESS [21.277s]
[INFO] Main Module ....................................... SUCCESS [2:38.385s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.714s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2:20.053s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [8:55.331s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.248s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.180s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [53.800s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.980s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:30.240s]
[INFO] Web Map Service Module ............................ FAILURE [7:32.348s]
[INFO] REST Support Module ............................... SUCCESS [43.359s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.539s]
[INFO] Core UI Module .................................... SUCCESS [2:04.058s]
[INFO] WFS UI Module ..................................... SUCCESS [28.448s]
[INFO] Security UI Modules ............................... SUCCESS [0.211s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.238s]
[INFO] Printing Module ................................... SUCCESS [33.300s]
[INFO] Community Space ................................... SUCCESS [0.202s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.266s]
[INFO] Application Schema Support ........................ SUCCESS [0.197s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.119s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.825s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.704s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.383s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.668s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.394s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.470s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.794s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.802s]
[INFO] OGR parent ........................................ SUCCESS [0.252s]
[INFO] OGR WFS ........................................... SUCCESS [26.609s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.520s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:59.807s]
[INFO] OGR WPS ........................................... SUCCESS [27.873s]
[INFO] Excel Output Format ............................... SUCCESS [45.648s]
[INFO] Chart external graphics support ................... SUCCESS [1.822s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.770s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.943s]
[INFO] OWS request flow controller ....................... SUCCESS [31.163s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [38.518s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.159s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.485s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.118s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [26.028s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.580s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [18.496s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.068s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:37.679s]
[INFO] CSW UI Module ..................................... SUCCESS [29.371s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.185s]
[INFO] DXF WFS output format ............................. SUCCESS [36.887s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [19.242s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.183s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.834s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.507s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 26:32.348s (Wall Clock)
[INFO] Finished at: Fri Jul 31 15:36:08 UTC 2015
[INFO] Final Memory: 67M/206M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
