[Geoserver-devel] Build failed in Jenkins: geoserver-master #1648
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1648/changes&gt;
Changes:
[ridethepenguin] [GEOS-7132] Added docs and examples for app-schema mappings REST API
[...truncated 17227 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2e2faa7
[INFO] [GitCommitIdMojo] build.commit.id = 2e2faa7ad54f1ccbd45b9b62a32f2922e8bbea3e
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1166 from ridethepenguin/master
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1166 from ridethepenguin/master
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 03.08.2015 @ 19:23:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 03-Aug-2015 19:28
[INFO] [GitCommitIdMojo] build.build.time = 03.08.2015 @ 20:03:27 UTC
[INFO] [GitCommitIdMojo] build.branch = 2e2faa7ad54f1ccbd45b9b62a32f2922e8bbea3e
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] build.build.time = 03.08.2015 @ 20:03:28 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [15.364s]
[INFO] Core Platform Module .............................. SUCCESS [19.328s]
[INFO] Open Web Service Module ........................... SUCCESS [30.516s]
[INFO] Main Module ....................................... SUCCESS [2:32.101s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.453s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.794s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.513s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.783s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.813s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.802s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:57.998s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:31.112s]
[INFO] Web Map Service Module ............................ SUCCESS [9:00.717s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.779s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:23.017s]
[INFO] REST Support Module ............................... SUCCESS [42.776s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:42.105s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.458s]
[INFO] Core UI Module .................................... SUCCESS [2:03.182s]
[INFO] WMS UI Module ..................................... SUCCESS [53.323s]
[INFO] GWC UI Module ..................................... SUCCESS [1:31.468s]
[INFO] WFS UI Module ..................................... SUCCESS [32.697s]
[INFO] Demoes Module ..................................... SUCCESS [53.393s]
[INFO] WCS UI Module ..................................... SUCCESS [39.054s]
[INFO] Security UI Modules ............................... SUCCESS [0.418s]
[INFO] Security UI Core Module ........................... SUCCESS [2:44.138s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:59.773s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.927s]
[INFO] REST UI Module .................................... SUCCESS [32.473s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.292s]
[INFO] Printing Module ................................... SUCCESS [40.664s]
[INFO] Community Space ................................... SUCCESS [0.253s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.291s]
[INFO] Application Schema Support ........................ SUCCESS [0.421s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:56.096s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.394s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.040s]
[INFO] GeoSearch Index Module ............................ SUCCESS [27.682s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.756s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.514s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.832s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.450s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.931s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.353s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [12.139s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.943s]
[INFO] OGR parent ........................................ SUCCESS [0.342s]
[INFO] OGR WFS ........................................... SUCCESS [24.761s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.557s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [40.555s]
[INFO] Chart external graphics support ................... SUCCESS [2.840s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.810s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.952s]
[INFO] OWS request flow controller ....................... SUCCESS [29.669s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.970s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.744s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.429s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.362s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [25.499s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.358s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [16.544s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.293s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.922s]
[INFO] XLST based WFS output format ...................... SUCCESS [52.644s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.835s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.956s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.361s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [29.821s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.124s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:34.451s]
[INFO] CSW UI Module ..................................... SUCCESS [24.731s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.322s]
[INFO] DXF WFS output format ............................. SUCCESS [38.237s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.425s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.964s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.508s]
[INFO] Importer Core Module .............................. SUCCESS [2:00.220s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:40.249s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.116s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.675s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:56.114s (Wall Clock)
[INFO] Finished at: Mon Aug 03 20:03:29 UTC 2015
[INFO] Final Memory: 83M/263M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1649/changes&gt;
