See <http://ares.opengeo.org/jenkins/job/geoserver-master/1660/>
[...truncated 17226 lines...]
[INFO] Building GeoServer CAS Security Web Module 2.8-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding linked hash set in the xstream white list, it's used in the layer secondary styles storage
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 07.08.2015 @ 12:32:58 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 08-Aug-2015 10:34
[INFO] [GitCommitIdMojo] build.build.time = 08.08.2015 @ 11:07:45 UTC
[INFO] [GitCommitIdMojo] build.branch = 4c697892e29cc25a89e8c94127a9a4a842ef822e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4c69789
[INFO] [GitCommitIdMojo] build.commit.id = 4c697892e29cc25a89e8c94127a9a4a842ef822e
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding linked hash set in the xstream white list, it's used in the layer secondary styles storage
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.08.2015 @ 11:07:48 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.884s]
[INFO] Core Platform Module .............................. SUCCESS [15.496s]
[INFO] Open Web Service Module ........................... SUCCESS [20.169s]
[INFO] Main Module ....................................... SUCCESS [2:30.048s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.569s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.347s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:06.574s]
[INFO] Web Coverage Service Module ....................... SUCCESS [9.018s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.225s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.321s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:59.489s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:20.468s]
[INFO] Web Map Service Module ............................ SUCCESS [8:16.602s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:21.992s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:27.385s]
[INFO] REST Support Module ............................... SUCCESS [41.121s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:35.848s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.672s]
[INFO] Core UI Module .................................... SUCCESS [1:52.569s]
[INFO] WMS UI Module ..................................... SUCCESS [57.555s]
[INFO] GWC UI Module ..................................... SUCCESS [1:30.456s]
[INFO] WFS UI Module ..................................... SUCCESS [34.292s]
[INFO] Demoes Module ..................................... SUCCESS [53.511s]
[INFO] WCS UI Module ..................................... SUCCESS [40.340s]
[INFO] Security UI Modules ............................... SUCCESS [0.256s]
[INFO] Security UI Core Module ........................... SUCCESS [2:55.967s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:04.912s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.209s]
[INFO] REST UI Module .................................... SUCCESS [32.344s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.260s]
[INFO] Printing Module ................................... SUCCESS [36.603s]
[INFO] Community Space ................................... SUCCESS [0.299s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.789s]
[INFO] Application Schema Support ........................ SUCCESS [0.234s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:50.539s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.461s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.479s]
[INFO] GeoSearch Index Module ............................ SUCCESS [33.043s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.324s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.409s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.714s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.520s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.489s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.700s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.313s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.959s]
[INFO] OGR parent ........................................ SUCCESS [0.329s]
[INFO] OGR CORE .......................................... SUCCESS [4.584s]
[INFO] OGR WFS ........................................... SUCCESS [25.148s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.593s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [41.174s]
[INFO] Chart external graphics support ................... SUCCESS [2.472s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.716s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.918s]
[INFO] OWS request flow controller ....................... SUCCESS [28.003s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.955s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.306s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.321s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.996s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.225s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.226s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [13.306s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.432s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.269s]
[INFO] XLST based WFS output format ...................... SUCCESS [52.534s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [51.879s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.015s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.204s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.735s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.266s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.111s]
[INFO] CSW UI Module ..................................... SUCCESS [24.416s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.148s]
[INFO] DXF WFS output format ............................. SUCCESS [36.871s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.175s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.535s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.557s]
[INFO] Importer Core Module .............................. SUCCESS [1:54.318s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:33.877s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.355s]
[INFO] Importer Web UI Module ............................ SUCCESS [10.154s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:30.691s (Wall Clock)
[INFO] Finished at: Sat Aug 08 11:07:48 UTC 2015
[INFO] Final Memory: 84M/283M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
