See <http://ares.opengeo.org/jenkins/job/geoserver-master/1671/>
[...truncated 18584 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1180 from jodygarnett/docs_cleanup
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.08.2015 @ 18:57:41 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-Aug-2015 23:40
[INFO] [GitCommitIdMojo] build.build.time = 11.08.2015 @ 00:14:46 UTC
[INFO] [GitCommitIdMojo] build.branch = 79a0046d9f934d9476f04cdd46e97df0c491736a
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 79a0046
[INFO] [GitCommitIdMojo] build.commit.id = 79a0046d9f934d9476f04cdd46e97df0c491736a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1180 from jodygarnett/docs_cleanup
Clean up extensions list and remove styler extension
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 11.08.2015 @ 00:14:49 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.501s]
[INFO] Core Platform Module .............................. SUCCESS [15.858s]
[INFO] Open Web Service Module ........................... SUCCESS [20.523s]
[INFO] Main Module ....................................... SUCCESS [2:34.015s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.487s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.927s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:08.876s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.236s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.464s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.387s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:52.202s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:23.190s]
[INFO] Web Map Service Module ............................ SUCCESS [8:14.957s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:11.226s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:26.170s]
[INFO] REST Support Module ............................... SUCCESS [43.394s]
[INFO] REST Configuration Service Module ................. FAILURE [2:36.957s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.749s]
[INFO] Core UI Module .................................... SUCCESS [1:54.507s]
[INFO] WMS UI Module ..................................... SUCCESS [55.294s]
[INFO] GWC UI Module ..................................... SUCCESS [1:28.835s]
[INFO] WFS UI Module ..................................... SUCCESS [31.136s]
[INFO] Demoes Module ..................................... SUCCESS [54.057s]
[INFO] WCS UI Module ..................................... SUCCESS [38.240s]
[INFO] Security UI Modules ............................... SUCCESS [0.243s]
[INFO] Security UI Core Module ........................... SUCCESS [2:50.075s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:12.224s]
[INFO] Security UI LDAP Module ........................... SUCCESS [39.865s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.199s]
[INFO] Printing Module ................................... SUCCESS [41.688s]
[INFO] Community Space ................................... SUCCESS [0.193s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.003s]
[INFO] Application Schema Support ........................ SUCCESS [0.214s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.238s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.768s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.751s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.538s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.403s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.674s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.410s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.519s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.950s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.236s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.922s]
[INFO] OGR parent ........................................ SUCCESS [0.297s]
[INFO] OGR CORE .......................................... SUCCESS [5.565s]
[INFO] OGR WFS ........................................... SUCCESS [21.641s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.470s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:10.243s]
[INFO] OGR WPS ........................................... SUCCESS [27.823s]
[INFO] Excel Output Format ............................... SUCCESS [44.694s]
[INFO] Chart external graphics support ................... SUCCESS [3.235s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.253s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.036s]
[INFO] OWS request flow controller ....................... SUCCESS [29.017s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [34.695s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:13.509s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.147s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.754s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.444s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.811s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [22.855s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.475s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.811s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.336s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.817s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.032s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.669s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.203s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.116s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.438s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:29.043s]
[INFO] CSW UI Module ..................................... SUCCESS [26.530s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.316s]
[INFO] DXF WFS output format ............................. SUCCESS [38.088s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [24.090s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.155s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.396s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.992s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.369s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.251s]
[INFO] Importer Core Module .............................. SUCCESS [1:47.436s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.042s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.555s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:12.182s (Wall Clock)
[INFO] Finished at: Tue Aug 11 00:14:49 UTC 2015
[INFO] Final Memory: 86M/251M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
