See <http://ares.opengeo.org/jenkins/job/geoserver-master/1677/>
[...truncated 17382 lines...]
[INFO] Building GeoServer CAS Security Web Module 2.8-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Documenting single layer sort-by support
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.08.2015 @ 10:37:10 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Aug-2015 14:07
[INFO] [GitCommitIdMojo] build.build.time = 11.08.2015 @ 14:40:57 UTC
[INFO] [GitCommitIdMojo] build.branch = 90264f74eaedb1f4fe0b784cdcb3ab81476dbb91
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 90264f7
[INFO] [GitCommitIdMojo] build.commit.id = 90264f74eaedb1f4fe0b784cdcb3ab81476dbb91
[INFO] [GitCommitIdMojo] build.commit.message.full = Documenting single layer sort-by support
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 11.08.2015 @ 14:41:00 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.843s]
[INFO] Core Platform Module .............................. SUCCESS [17.001s]
[INFO] Open Web Service Module ........................... SUCCESS [19.397s]
[INFO] Main Module ....................................... SUCCESS [2:31.533s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.273s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.760s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:08.040s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.951s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.173s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.225s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:56.811s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:23.706s]
[INFO] Web Map Service Module ............................ SUCCESS [7:57.225s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.972s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:27.029s]
[INFO] REST Support Module ............................... SUCCESS [38.470s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:36.550s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.675s]
[INFO] Core UI Module .................................... SUCCESS [1:52.849s]
[INFO] WMS UI Module ..................................... SUCCESS [53.085s]
[INFO] GWC UI Module ..................................... SUCCESS [1:35.331s]
[INFO] WFS UI Module ..................................... SUCCESS [33.939s]
[INFO] Demoes Module ..................................... SUCCESS [56.719s]
[INFO] WCS UI Module ..................................... SUCCESS [39.003s]
[INFO] Security UI Modules ............................... SUCCESS [0.376s]
[INFO] Security UI Core Module ........................... SUCCESS [2:59.441s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:03.636s]
[INFO] Security UI LDAP Module ........................... SUCCESS [41.389s]
[INFO] REST UI Module .................................... SUCCESS [33.598s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.304s]
[INFO] Printing Module ................................... SUCCESS [39.040s]
[INFO] Community Space ................................... SUCCESS [0.184s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.108s]
[INFO] Application Schema Support ........................ SUCCESS [0.174s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:43.955s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.856s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.738s]
[INFO] GeoSearch Index Module ............................ SUCCESS [35.738s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.358s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.384s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.716s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.474s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.140s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.636s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.276s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.796s]
[INFO] OGR parent ........................................ SUCCESS [0.176s]
[INFO] OGR CORE .......................................... SUCCESS [4.677s]
[INFO] OGR WFS ........................................... SUCCESS [27.198s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.407s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [43.035s]
[INFO] Chart external graphics support ................... SUCCESS [2.828s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.311s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.744s]
[INFO] OWS request flow controller ....................... SUCCESS [31.310s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.154s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.677s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.404s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.388s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.250s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.472s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.033s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.265s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.105s]
[INFO] XLST based WFS output format ...................... SUCCESS [56.397s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.361s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.259s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.449s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [33.728s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.982s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:33.161s]
[INFO] CSW UI Module ..................................... SUCCESS [24.848s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.164s]
[INFO] DXF WFS output format ............................. SUCCESS [39.387s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.166s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.999s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.277s]
[INFO] Importer Core Module .............................. SUCCESS [1:52.977s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:38.272s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [55.208s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.781s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:34.233s (Wall Clock)
[INFO] Finished at: Tue Aug 11 14:41:00 UTC 2015
[INFO] Final Memory: 84M/264M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
