[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #1678
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1678/changes&gt;
Changes:
[andrea.aime] [GEOS-6992] Add gdalwarp/gdal_translate/gdaladdo transformation support in importer
[...truncated 24415 lines...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.importer.transform.KMLPlacemarkTransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.importer.transform.TransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Results :
Tests in error:
  testTranslateAddo(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdal_translate.exe
  testWarpFromGroundControlPoint(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdalwarp.exe
  testGdalTranslateTrasform(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdal_translate.exe
  testGdalAddo(org.geoserver.importer.transform.GdalTransformTest): Could not locate executable (or could locate, but does not have execution rights): gdaladdo.exe
Tests run: 80, Failures: 0, Errors: 4, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 1 second
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.086s]
[INFO] Core Platform Module .............................. SUCCESS [19.188s]
[INFO] Open Web Service Module ........................... SUCCESS [14.679s]
[INFO] Main Module ....................................... SUCCESS [4:52.986s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.702s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [38.040s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [12.699s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.994s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:16.471s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:56.220s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [6:23.056s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:22.904s]
[INFO] Web Map Service Module ............................ SUCCESS [5:50.088s]
[INFO] KML support for GeoServer ......................... SUCCESS [57.950s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:16.993s]
[INFO] REST Support Module ............................... SUCCESS [29.079s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:49.956s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.281s]
[INFO] Core UI Module .................................... SUCCESS [2:22.678s]
[INFO] WMS UI Module ..................................... SUCCESS [45.396s]
[INFO] GWC UI Module ..................................... SUCCESS [1:05.836s]
[INFO] WFS UI Module ..................................... SUCCESS [23.853s]
[INFO] Demoes Module ..................................... SUCCESS [42.370s]
[INFO] WCS UI Module ..................................... SUCCESS [32.760s]
[INFO] Security UI Modules ............................... SUCCESS [0.608s]
[INFO] Security UI Core Module ........................... SUCCESS [3:04.471s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:11.448s]
[INFO] Security UI LDAP Module ........................... SUCCESS [31.658s]
[INFO] REST UI Module .................................... SUCCESS [26.160s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.251s]
[INFO] Community Space ................................... SUCCESS [0.297s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.359s]
[INFO] Application Schema Support ........................ SUCCESS [0.327s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:10.745s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [22.292s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.579s]
[INFO] GeoSearch Index Module ............................ SUCCESS [26.676s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.068s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.375s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.390s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.405s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.359s]
[INFO] ImageMap Output Format ............................ SUCCESS [12.682s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.593s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.468s]
[INFO] OGR parent ........................................ SUCCESS [0.265s]
[INFO] OGR WFS ........................................... SUCCESS [21.778s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.405s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:28.538s]
[INFO] OGR WPS ........................................... SUCCESS [25.225s]
[INFO] Excel Output Format ............................... SUCCESS [23.759s]
[INFO] Chart external graphics support ................... SUCCESS [0.452s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.808s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.531s]
[INFO] OWS request flow controller ....................... SUCCESS [20.191s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.035s]
[INFO] Web Processing Service GUI ........................ SUCCESS [55.396s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [32.308s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.979s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.593s]
[INFO] Core Monitor Extension ............................ SUCCESS [21.512s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [11.840s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.670s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.485s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.671s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.432s]
[INFO] XLST based WFS output format ...................... SUCCESS [34.866s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [37.393s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [24.867s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.514s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [14.711s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [17.815s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:25.591s]
[INFO] CSW UI Module ..................................... SUCCESS [22.480s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.265s]
[INFO] DXF WFS output format ............................. SUCCESS [24.648s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [25.616s]
[INFO] Printing Module ................................... SUCCESS [25.740s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.296s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [42.884s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [23.743s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.431s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.655s]
[INFO] Importer Core Module .............................. FAILURE [1:20.704s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:09:34.509s
[INFO] Finished at: Fri May 08 18:55:56 CEST 2015
[INFO] Final Memory: 103M/251M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/importer/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
channel stopped
Finished Calculation of disk usage of workspace in 5 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1679/changes&gt;
Changes:
[andrea.aime] [GEOS-7000] Allow importer to add granules to a mosaic as an indirect import
[...truncated 23991 lines...]
Results :
Tests in error:
Tests run: 81, Failures: 0, Errors: 4, Skipped: 2
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.538s]
[INFO] Core Platform Module .............................. SUCCESS [19.001s]
[INFO] Open Web Service Module ........................... SUCCESS [14.025s]
[INFO] Main Module ....................................... SUCCESS [5:02.126s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.812s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [39.485s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [12.219s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.214s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:13.088s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.294s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:16.022s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:14.953s]
[INFO] Web Map Service Module ............................ SUCCESS [5:09.895s]
[INFO] KML support for GeoServer ......................... SUCCESS [58.682s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:17.912s]
[INFO] REST Support Module ............................... SUCCESS [28.454s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:50.009s]
[INFO] Core UI Module .................................... SUCCESS [2:21.867s]
[INFO] WMS UI Module ..................................... SUCCESS [47.159s]
[INFO] GWC UI Module ..................................... SUCCESS [1:03.606s]
[INFO] WFS UI Module ..................................... SUCCESS [24.617s]
[INFO] Demoes Module ..................................... SUCCESS [41.231s]
[INFO] WCS UI Module ..................................... SUCCESS [1:11.289s]
[INFO] Security UI Modules ............................... SUCCESS [0.780s]
[INFO] Security UI Core Module ........................... SUCCESS [3:02.805s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:56.904s]
[INFO] Security UI LDAP Module ........................... SUCCESS [33.541s]
[INFO] REST UI Module .................................... SUCCESS [26.754s]
[INFO] GeoServer Web Application ......................... SUCCESS [13.791s]
[INFO] Community Space ................................... SUCCESS [0.312s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.343s]
[INFO] Application Schema Support ........................ SUCCESS [0.358s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:11.600s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [21.341s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.393s]
[INFO] GeoSearch Index Module ............................ SUCCESS [26.442s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.943s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.390s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.375s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.406s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.375s]
[INFO] ImageMap Output Format ............................ SUCCESS [12.480s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.624s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.437s]
[INFO] OGR parent ........................................ SUCCESS [0.266s]
[INFO] OGR WFS ........................................... SUCCESS [22.262s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.561s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:31.144s]
[INFO] OGR WPS ........................................... SUCCESS [25.163s]
[INFO] Excel Output Format ............................... SUCCESS [23.697s]
[INFO] Chart external graphics support ................... SUCCESS [0.483s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.746s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.468s]
[INFO] OWS request flow controller ....................... SUCCESS [20.488s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.471s]
[INFO] Web Processing Service GUI ........................ SUCCESS [54.428s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [34.757s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.933s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.577s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.604s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [11.841s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.686s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.297s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.682s]
[INFO] XLST based WFS output format ...................... SUCCESS [36.661s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [37.534s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [24.695s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.827s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [16.738s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [15.397s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:25.030s]
[INFO] CSW UI Module ..................................... SUCCESS [22.900s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.312s]
[INFO] DXF WFS output format ............................. SUCCESS [24.446s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [24.446s]
[INFO] Printing Module ................................... SUCCESS [25.678s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.297s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [42.744s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [23.681s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.604s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.624s]
[INFO] Importer Core Module .............................. FAILURE [1:16.177s]
[INFO] Total time: 1:03:23.493s
[INFO] Finished at: Fri May 08 20:00:19 CEST 2015
[INFO] Final Memory: 102M/242M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1680/changes&gt;
