See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1699/changes>
Changes:
[maurobartolomeoli] GEOS-7022: fixes WMS GetMap interpolations behavior for layer groups
[...truncated 22182 lines...]
at java.lang.reflect.Method.invoke(Method.java:606)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
Results :
Failed tests: testDelete(org.geoserver.wfs.xslt.rest.TransformRestTest)
Tests run: 29, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.069s]
[INFO] Core Platform Module .............................. SUCCESS [19.890s]
[INFO] Open Web Service Module ........................... SUCCESS [14.539s]
[INFO] Main Module ....................................... SUCCESS [3:37.435s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.780s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.507s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [12.402s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.571s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.054s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.593s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:31.002s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:58.503s]
[INFO] Web Map Service Module ............................ SUCCESS [3:53.010s]
[INFO] KML support for GeoServer ......................... SUCCESS [55.147s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:44.731s]
[INFO] REST Support Module ............................... SUCCESS [27.752s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:04.122s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.359s]
[INFO] Core UI Module .................................... SUCCESS [1:45.086s]
[INFO] WMS UI Module ..................................... SUCCESS [37.362s]
[INFO] GWC UI Module ..................................... SUCCESS [52.749s]
[INFO] WFS UI Module ..................................... SUCCESS [18.876s]
[INFO] Demoes Module ..................................... SUCCESS [33.946s]
[INFO] WCS UI Module ..................................... SUCCESS [24.632s]
[INFO] Security UI Modules ............................... SUCCESS [0.577s]
[INFO] Security UI Core Module ........................... SUCCESS [2:11.914s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:31.469s]
[INFO] Security UI LDAP Module ........................... SUCCESS [25.709s]
[INFO] REST UI Module .................................... SUCCESS [21.669s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.756s]
[INFO] Community Space ................................... SUCCESS [0.343s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.359s]
[INFO] Application Schema Support ........................ SUCCESS [0.296s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:36.297s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [17.550s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.829s]
[INFO] GeoSearch Index Module ............................ SUCCESS [22.745s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.725s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.421s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.593s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.406s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.390s]
[INFO] ImageMap Output Format ............................ SUCCESS [13.556s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.593s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.483s]
[INFO] OGR parent ........................................ SUCCESS [0.374s]
[INFO] OGR WFS ........................................... SUCCESS [16.052s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.390s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:09.787s]
[INFO] OGR WPS ........................................... SUCCESS [18.144s]
[INFO] Excel Output Format ............................... SUCCESS [23.010s]
[INFO] Chart external graphics support ................... SUCCESS [0.468s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.841s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.469s]
[INFO] OWS request flow controller ....................... SUCCESS [18.391s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [16.638s]
[INFO] Web Processing Service GUI ........................ SUCCESS [45.143s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [27.805s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.011s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.608s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.108s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [11.639s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.749s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.235s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.702s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.479s]
[INFO] XLST based WFS output format ...................... FAILURE [32.091s]
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 46:09.990s
[INFO] Finished at: Thu May 14 22:01:47 CEST 2015
[INFO] Final Memory: 90M/235M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/xslt/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
channel stopped
Finished Calculation of disk usage of workspace in 6 second
