[Geoserver-devel] Build failed in Jenkins: geoserver-master #1699
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1699/changes&gt;
Changes:
[andrea.aime] [GEOS-7158] WMS extended capabilities not populated if the first provider return a null root
[...truncated 13352 lines...]
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.487 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-csw ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1187 from aaime/ext_prov_exit_fix
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.08.2015 @ 16:01:14 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Aug-2015 16:03
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2015 @ 16:26:52 UTC
[INFO] [GitCommitIdMojo] build.branch = 6ee2f3a42bb0a42d4173780a5afe93cc4779f71d
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 6ee2f3a
[INFO] [GitCommitIdMojo] build.commit.id = 6ee2f3a42bb0a42d4173780a5afe93cc4779f71d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1187 from aaime/ext_prov_exit_fix
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.105s]
[INFO] Core Platform Module .............................. SUCCESS [16.872s]
[INFO] Open Web Service Module ........................... SUCCESS [25.526s]
[INFO] Main Module ....................................... SUCCESS [2:33.241s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.399s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.947s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.185s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.041s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.100s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.612s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:00.602s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:26.572s]
[INFO] Web Map Service Module ............................ FAILURE [9:06.037s]
[INFO] REST Support Module ............................... SUCCESS [46.398s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.559s]
[INFO] Core UI Module .................................... SUCCESS [1:54.764s]
[INFO] WFS UI Module ..................................... SUCCESS [29.404s]
[INFO] Security UI Modules ............................... SUCCESS [0.286s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.292s]
[INFO] Printing Module ................................... SUCCESS [37.685s]
[INFO] Community Space ................................... SUCCESS [0.219s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.149s]
[INFO] Application Schema Support ........................ SUCCESS [0.187s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.722s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.188s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.644s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.875s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.060s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [3.499s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.104s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.827s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.867s]
[INFO] OGR parent ........................................ SUCCESS [0.274s]
[INFO] OGR CORE .......................................... SUCCESS [5.901s]
[INFO] OGR WFS ........................................... SUCCESS [22.665s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.326s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:15.126s]
[INFO] OGR WPS ........................................... SUCCESS [29.005s]
[INFO] Excel Output Format ............................... SUCCESS [47.105s]
[INFO] Chart external graphics support ................... SUCCESS [2.899s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.711s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.513s]
[INFO] OWS request flow controller ....................... SUCCESS [29.624s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.470s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.525s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.061s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.330s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.747s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.232s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.016s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.285s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.834s]
[INFO] CSW UI Module ..................................... SUCCESS [17.458s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.359s]
[INFO] DXF WFS output format ............................. SUCCESS [36.298s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.309s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.204s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [46.764s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [35.427s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:06.215s (Wall Clock)
[INFO] Finished at: Sun Aug 16 16:26:52 UTC 2015
[INFO] Final Memory: 68M/225M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1700/&gt;
