See <http://ares.opengeo.org/jenkins/job/geoserver-master/1708/changes>
Changes:
[markljung] [GEOS-7167] GML2 xlinks import diverge fixed
[...truncated 13363 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.491 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-csw ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1194 from koordo/geometry_xlinks_ref
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.08.2015 @ 13:12:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 22-Aug-2015 13:17
[INFO] [GitCommitIdMojo] build.build.time = 22.08.2015 @ 13:40:12 UTC
[INFO] [GitCommitIdMojo] build.branch = 7a2e8027a65b423207ef16bcf7923d25538daf8b
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7a2e802
[INFO] [GitCommitIdMojo] build.commit.id = 7a2e8027a65b423207ef16bcf7923d25538daf8b
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1194 from koordo/geometry_xlinks_ref
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.141s]
[INFO] Core Platform Module .............................. SUCCESS [17.109s]
[INFO] Open Web Service Module ........................... SUCCESS [21.791s]
[INFO] Main Module ....................................... SUCCESS [2:39.847s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.509s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:05.581s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:59.930s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.632s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.329s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.554s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.530s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.723s]
[INFO] Web Map Service Module ............................ FAILURE [8:58.351s]
[INFO] REST Support Module ............................... SUCCESS [40.011s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.569s]
[INFO] Core UI Module .................................... SUCCESS [1:54.307s]
[INFO] WFS UI Module ..................................... SUCCESS [32.798s]
[INFO] Security UI Modules ............................... SUCCESS [0.257s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.297s]
[INFO] Printing Module ................................... SUCCESS [41.536s]
[INFO] Community Space ................................... SUCCESS [0.271s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.302s]
[INFO] Application Schema Support ........................ SUCCESS [0.217s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.539s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.436s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.568s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.827s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.771s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.488s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.466s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.364s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.008s]
[INFO] OGR parent ........................................ SUCCESS [0.432s]
[INFO] OGR CORE .......................................... SUCCESS [6.720s]
[INFO] OGR WFS ........................................... SUCCESS [22.613s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.477s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:01.375s]
[INFO] OGR WPS ........................................... SUCCESS [28.115s]
[INFO] Excel Output Format ............................... SUCCESS [43.395s]
[INFO] Chart external graphics support ................... SUCCESS [2.479s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.575s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.093s]
[INFO] OWS request flow controller ....................... SUCCESS [28.671s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [36.559s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.519s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.370s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.402s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.789s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.205s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.588s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.217s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.214s]
[INFO] CSW UI Module ..................................... SUCCESS [18.025s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.504s]
[INFO] DXF WFS output format ............................. SUCCESS [36.035s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [21.960s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.577s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [47.249s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [40.146s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:50.610s (Wall Clock)
[INFO] Finished at: Sat Aug 22 13:40:12 UTC 2015
[INFO] Final Memory: 68M/228M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
