[Geoserver-devel] Build failed in Jenkins: geoserver-master #1714
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1714/&gt;
[...truncated 17274 lines...]
[INFO] Building GeoServer CAS Security Web Module 2.8-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6026] WMS capabilities should report workspace qualified styles as ... qualified
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 23.08.2015 @ 10:12:39 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Aug-2015 12:38
[INFO] [GitCommitIdMojo] build.build.time = 24.08.2015 @ 13:12:44 UTC
[INFO] [GitCommitIdMojo] build.branch = dc0af829750ff5caf40f61f11d91b7a5b840cf76
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = dc0af82
[INFO] [GitCommitIdMojo] build.commit.id = dc0af829750ff5caf40f61f11d91b7a5b840cf76
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6026] WMS capabilities should report workspace qualified styles as ... qualified
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 24.08.2015 @ 13:12:48 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.750s]
[INFO] Core Platform Module .............................. SUCCESS [16.046s]
[INFO] Open Web Service Module ........................... SUCCESS [1:02.438s]
[INFO] Main Module ....................................... SUCCESS [2:35.034s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.261s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:09.409s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.418s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.702s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.281s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.323s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:01.548s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:19.265s]
[INFO] Web Map Service Module ............................ SUCCESS [8:12.269s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.383s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:23.929s]
[INFO] REST Support Module ............................... SUCCESS [40.384s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:36.119s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.772s]
[INFO] Core UI Module .................................... SUCCESS [1:49.183s]
[INFO] WMS UI Module ..................................... SUCCESS [50.891s]
[INFO] GWC UI Module ..................................... SUCCESS [1:32.730s]
[INFO] WFS UI Module ..................................... SUCCESS [32.488s]
[INFO] Demoes Module ..................................... SUCCESS [52.537s]
[INFO] WCS UI Module ..................................... SUCCESS [39.007s]
[INFO] Security UI Modules ............................... SUCCESS [0.271s]
[INFO] Security UI Core Module ........................... SUCCESS [2:45.171s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:04.626s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.340s]
[INFO] REST UI Module .................................... SUCCESS [34.058s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.306s]
[INFO] Printing Module ................................... SUCCESS [38.875s]
[INFO] Community Space ................................... SUCCESS [0.218s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.368s]
[INFO] Application Schema Support ........................ SUCCESS [0.176s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:52.711s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.510s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.660s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.867s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.638s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [40.100s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [3.334s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.483s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.702s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.639s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.295s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.840s]
[INFO] OGR parent ........................................ SUCCESS [0.252s]
[INFO] OGR CORE .......................................... SUCCESS [5.739s]
[INFO] OGR WFS ........................................... SUCCESS [24.842s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.489s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [44.005s]
[INFO] Chart external graphics support ................... SUCCESS [3.379s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.334s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.296s]
[INFO] OWS request flow controller ....................... SUCCESS [27.153s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.791s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.462s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.220s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.295s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.724s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.321s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.774s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.279s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.007s]
[INFO] XLST based WFS output format ...................... SUCCESS [52.714s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.093s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.092s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.202s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.348s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.128s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.575s]
[INFO] CSW UI Module ..................................... SUCCESS [28.008s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.176s]
[INFO] DXF WFS output format ............................. SUCCESS [38.632s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.281s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.827s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.570s]
[INFO] Importer Core Module .............................. SUCCESS [1:50.614s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:37.407s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.780s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.822s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:02.209s (Wall Clock)
[INFO] Finished at: Mon Aug 24 13:12:48 UTC 2015
[INFO] Final Memory: 84M/259M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1715/&gt;
[...truncated 17411 lines...]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 24-Aug-2015 13:17
[INFO] [GitCommitIdMojo] build.build.time = 24.08.2015 @ 13:50:53 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 24.08.2015 @ 13:50:56 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.926s]
[INFO] Core Platform Module .............................. SUCCESS [15.525s]
[INFO] Open Web Service Module ........................... SUCCESS [20.952s]
[INFO] Main Module ....................................... SUCCESS [2:30.534s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.399s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.280s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:01.828s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.317s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.226s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.479s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:58.264s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:23.046s]
[INFO] Web Map Service Module ............................ SUCCESS [8:12.664s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:27.341s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:30.629s]
[INFO] REST Support Module ............................... SUCCESS [41.252s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:39.259s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.605s]
[INFO] Core UI Module .................................... SUCCESS [1:48.982s]
[INFO] WMS UI Module ..................................... SUCCESS [55.323s]
[INFO] GWC UI Module ..................................... SUCCESS [1:41.542s]
[INFO] WFS UI Module ..................................... SUCCESS [32.293s]
[INFO] Demoes Module ..................................... SUCCESS [53.078s]
[INFO] WCS UI Module ..................................... SUCCESS [38.698s]
[INFO] Security UI Modules ............................... SUCCESS [0.281s]
[INFO] Security UI Core Module ........................... SUCCESS [2:43.285s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:08.811s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.840s]
[INFO] REST UI Module .................................... SUCCESS [35.274s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.279s]
[INFO] Printing Module ................................... SUCCESS [37.451s]
[INFO] Community Space ................................... SUCCESS [0.220s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [14.444s]
[INFO] Application Schema Support ........................ SUCCESS [0.233s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:44.129s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.435s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.979s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.261s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.503s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.421s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.772s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.475s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.468s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.429s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.340s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.883s]
[INFO] OGR parent ........................................ SUCCESS [0.351s]
[INFO] OGR CORE .......................................... SUCCESS [3.699s]
[INFO] OGR WFS ........................................... SUCCESS [26.742s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.414s]
[INFO] Excel Output Format ............................... SUCCESS [44.178s]
[INFO] Chart external graphics support ................... SUCCESS [2.849s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.965s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.907s]
[INFO] OWS request flow controller ....................... SUCCESS [27.760s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.952s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.694s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.223s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.919s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.651s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.237s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.202s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.424s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.353s]
[INFO] XLST based WFS output format ...................... SUCCESS [51.586s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.221s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.819s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.405s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.794s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.946s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:30.020s]
[INFO] CSW UI Module ..................................... SUCCESS [24.165s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.195s]
[INFO] DXF WFS output format ............................. SUCCESS [37.642s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.165s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.180s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.286s]
[INFO] Importer Core Module .............................. SUCCESS [1:55.958s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:35.593s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [56.775s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.316s]
[INFO] Total time: 33:31.539s (Wall Clock)
[INFO] Finished at: Mon Aug 24 13:50:56 UTC 2015
[INFO] Final Memory: 84M/264M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1716/changes&gt;
Changes:
[andrea.aime] Adding docs for z-ordering extension
[...truncated 17337 lines...]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding docs for z-ordering extension
[INFO] [GitCommitIdMojo] build.commit.time = 24.08.2015 @ 17:47:31 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Aug-2015 17:48
[INFO] [GitCommitIdMojo] build.build.time = 24.08.2015 @ 18:22:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 5bf07f95bd2209bdbf063a1fa709b7f6b0da3106
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5bf07f9
[INFO] [GitCommitIdMojo] build.commit.id = 5bf07f95bd2209bdbf063a1fa709b7f6b0da3106
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding docs for z-ordering extension
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 24.08.2015 @ 18:22:13 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.208s]
[INFO] Core Platform Module .............................. SUCCESS [15.200s]
[INFO] Open Web Service Module ........................... SUCCESS [20.273s]
[INFO] Main Module ....................................... SUCCESS [2:31.729s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.480s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.873s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:12.311s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.341s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.690s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.365s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:01.866s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:25.077s]
[INFO] Web Map Service Module ............................ SUCCESS [8:04.558s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.242s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:28.814s]
[INFO] REST Support Module ............................... SUCCESS [38.757s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:37.267s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.481s]
[INFO] Core UI Module .................................... SUCCESS [1:58.691s]
[INFO] WMS UI Module ..................................... SUCCESS [51.544s]
[INFO] GWC UI Module ..................................... SUCCESS [1:24.834s]
[INFO] WFS UI Module ..................................... SUCCESS [33.546s]
[INFO] Demoes Module ..................................... SUCCESS [49.105s]
[INFO] WCS UI Module ..................................... SUCCESS [41.672s]
[INFO] Security UI Modules ............................... SUCCESS [0.479s]
[INFO] Security UI Core Module ........................... SUCCESS [2:45.748s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:05.479s]
[INFO] Security UI LDAP Module ........................... SUCCESS [43.420s]
[INFO] REST UI Module .................................... SUCCESS [32.523s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.282s]
[INFO] Printing Module ................................... SUCCESS [39.790s]
[INFO] Community Space ................................... SUCCESS [0.193s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.451s]
[INFO] Application Schema Support ........................ SUCCESS [0.263s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:44.899s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.697s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.612s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.185s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.842s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.453s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.016s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.740s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.478s]
[INFO] ImageMap Output Format ............................ SUCCESS [22.788s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.431s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.889s]
[INFO] OGR parent ........................................ SUCCESS [0.307s]
[INFO] OGR CORE .......................................... SUCCESS [3.454s]
[INFO] OGR WFS ........................................... SUCCESS [23.977s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.485s]
[INFO] Excel Output Format ............................... SUCCESS [46.046s]
[INFO] Chart external graphics support ................... SUCCESS [3.061s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.198s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.947s]
[INFO] OWS request flow controller ....................... SUCCESS [28.659s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.329s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.837s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.307s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.592s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.575s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.446s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [13.228s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.266s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.156s]
[INFO] XLST based WFS output format ...................... SUCCESS [54.437s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [56.264s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.348s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.335s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.826s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.750s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.102s]
[INFO] CSW UI Module ..................................... SUCCESS [27.584s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.242s]
[INFO] DXF WFS output format ............................. SUCCESS [37.862s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.163s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.537s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.485s]
[INFO] Importer Core Module .............................. SUCCESS [1:48.348s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:34.859s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [55.939s]
[INFO] Importer Web UI Module ............................ SUCCESS [10.361s]
[INFO] Total time: 33:26.725s (Wall Clock)
[INFO] Finished at: Mon Aug 24 18:22:13 UTC 2015
[INFO] Final Memory: 84M/241M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
Can anybody else reproduce this one? It's building fine for me
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Nope, builds fine here as well.
–S
On Mon, Aug 24, 2015 at 8:33 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wcs2_0
Build step ‘Invoke top-level Maven targets’ marked build as failure
Can anybody else reproduce this one? It’s building fine for me
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1717/&gt;
