See <http://ares.opengeo.org/jenkins/job/geoserver-master/1721/changes>
Changes:
[andrea.aime] Fixing typo in WPS i18n strings
[...truncated 17320 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 25-Aug-2015 17:01
[INFO] [GitCommitIdMojo] build.build.time = 25.08.2015 @ 17:34:01 UTC
[INFO] [GitCommitIdMojo] build.branch = f6e4ad2da3106f9b82e2934b1eecc085204a4e98
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f6e4ad2
[INFO] [GitCommitIdMojo] build.commit.id = f6e4ad2da3106f9b82e2934b1eecc085204a4e98
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing typo in WPS i18n strings
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing typo in WPS i18n strings
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 25.08.2015 @ 16:49:39 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.488 sec
Running org.geoserver.importer.rest.RESTDataTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.91 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.781 sec
Results :
Tests run: 60, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] build.build.time = 25.08.2015 @ 17:34:25 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.975s]
[INFO] Core Platform Module .............................. SUCCESS [15.491s]
[INFO] Open Web Service Module ........................... SUCCESS [20.553s]
[INFO] Main Module ....................................... SUCCESS [2:33.578s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.246s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.979s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.943s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.786s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.345s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:06.737s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:57.347s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:24.834s]
[INFO] Web Map Service Module ............................ SUCCESS [6:53.184s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:23.476s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:27.267s]
[INFO] REST Support Module ............................... SUCCESS [41.132s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:44.002s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.512s]
[INFO] Core UI Module .................................... SUCCESS [1:53.427s]
[INFO] WMS UI Module ..................................... SUCCESS [58.438s]
[INFO] GWC UI Module ..................................... SUCCESS [1:41.820s]
[INFO] WFS UI Module ..................................... SUCCESS [32.348s]
[INFO] Demoes Module ..................................... SUCCESS [56.031s]
[INFO] WCS UI Module ..................................... SUCCESS [37.261s]
[INFO] Security UI Modules ............................... SUCCESS [0.349s]
[INFO] Security UI Core Module ........................... SUCCESS [2:48.528s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:03.020s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.930s]
[INFO] REST UI Module .................................... SUCCESS [33.798s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.315s]
[INFO] Printing Module ................................... SUCCESS [36.798s]
[INFO] Community Space ................................... SUCCESS [1.359s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.063s]
[INFO] Application Schema Support ........................ SUCCESS [0.199s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:56.080s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.485s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.881s]
[INFO] GeoSearch Index Module ............................ SUCCESS [30.970s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.846s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.793s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.874s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.647s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.717s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.552s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.355s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.756s]
[INFO] OGR parent ........................................ SUCCESS [0.373s]
[INFO] OGR CORE .......................................... SUCCESS [4.900s]
[INFO] OGR WFS ........................................... SUCCESS [27.723s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.503s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [45.806s]
[INFO] Chart external graphics support ................... SUCCESS [3.117s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.130s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.877s]
[INFO] OWS request flow controller ....................... SUCCESS [28.399s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.384s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.488s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.226s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.458s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.506s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.231s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.326s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.433s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.870s]
[INFO] XLST based WFS output format ...................... SUCCESS [54.463s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [52.146s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.089s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.252s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [33.742s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.696s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:34.077s]
[INFO] CSW UI Module ..................................... SUCCESS [26.283s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.153s]
[INFO] DXF WFS output format ............................. SUCCESS [36.417s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.193s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.709s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.632s]
[INFO] Importer Core Module .............................. SUCCESS [1:24.026s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:25.813s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [51.891s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.712s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:19.018s (Wall Clock)
[INFO] Finished at: Tue Aug 25 17:34:25 UTC 2015
[INFO] Final Memory: 84M/269M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
