See <http://ares.opengeo.org/jenkins/job/geoserver-master/1730/>
[...truncated 12027 lines...]
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.162s]
[INFO] Core Platform Module .............................. SUCCESS [19.012s]
[INFO] Open Web Service Module ........................... SUCCESS [20.009s]
[INFO] Main Module ....................................... SUCCESS [2:31.823s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.471s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.312s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:01.618s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.249s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.536s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.005s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:01.281s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:27.162s]
[INFO] Web Map Service Module ............................ FAILURE [8:55.912s]
[INFO] REST Support Module ............................... SUCCESS [42.335s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.545s]
[INFO] Core UI Module .................................... SUCCESS [1:51.956s]
[INFO] WFS UI Module ..................................... SUCCESS [33.349s]
[INFO] Security UI Modules ............................... SUCCESS [0.387s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.340s]
[INFO] Printing Module ................................... SUCCESS [39.217s]
[INFO] Community Space ................................... SUCCESS [0.252s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.186s]
[INFO] Application Schema Support ........................ SUCCESS [0.197s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.678s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.648s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.201s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.406s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.781s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.547s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.635s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.140s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.910s]
[INFO] OGR parent ........................................ SUCCESS [0.327s]
[INFO] OGR CORE .......................................... SUCCESS [5.003s]
[INFO] OGR WFS ........................................... SUCCESS [22.934s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.224s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [44.615s]
[INFO] Chart external graphics support ................... SUCCESS [2.721s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.397s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.985s]
[INFO] OWS request flow controller ....................... SUCCESS [28.267s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.506s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [8.205s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.480s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.791s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.672s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.564s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.831s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:34.611s]
[INFO] CSW UI Module ..................................... SUCCESS [30.379s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.181s]
[INFO] DXF WFS output format ............................. SUCCESS [36.463s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.154s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:35.494s (Wall Clock)
[INFO] Finished at: Thu Aug 27 00:11:11 UTC 2015
[INFO] Final Memory: 64M/259M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
