[Geoserver-devel] Build failed in Jenkins: geoserver-master #1737
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1737/&gt;
[...truncated 13388 lines...]
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2015 @ 15:24:14 UTC
[INFO] [GitCommitIdMojo] build.branch = 77daecff924d552ceea3a90edb535e1d4800a653
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 77daecf
[INFO] [GitCommitIdMojo] build.commit.id = 77daecff924d552ceea3a90edb535e1d4800a653
[INFO] [GitCommitIdMojo] build.commit.message.full = Improve a test that shows fragility as we change image processing options in jai/jai-ext
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
Results :
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Improve a test that shows fragility as we change image processing options in jai/jai-ext
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 27.08.2015 @ 10:54:20 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 27-Aug-2015 15:01
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.745s]
[INFO] Core Platform Module .............................. SUCCESS [16.924s]
[INFO] Open Web Service Module ........................... SUCCESS [22.166s]
[INFO] Main Module ....................................... SUCCESS [2:32.678s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.250s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.610s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.173s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.552s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.469s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.764s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:57.938s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:25.187s]
[INFO] Web Map Service Module ............................ FAILURE [9:42.496s]
[INFO] REST Support Module ............................... SUCCESS [40.670s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.659s]
[INFO] Core UI Module .................................... SUCCESS [1:52.636s]
[INFO] WFS UI Module ..................................... SUCCESS [30.133s]
[INFO] Security UI Modules ............................... SUCCESS [0.259s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.277s]
[INFO] Printing Module ................................... SUCCESS [37.677s]
[INFO] Community Space ................................... SUCCESS [0.175s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [14.041s]
[INFO] Application Schema Support ........................ SUCCESS [0.181s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.674s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.784s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.664s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.423s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.406s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.564s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.657s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.561s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.976s]
[INFO] OGR parent ........................................ SUCCESS [0.488s]
[INFO] OGR CORE .......................................... SUCCESS [4.629s]
[INFO] OGR WFS ........................................... SUCCESS [27.611s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.782s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:08.011s]
[INFO] OGR WPS ........................................... SUCCESS [27.962s]
[INFO] Excel Output Format ............................... SUCCESS [49.132s]
[INFO] Chart external graphics support ................... SUCCESS [2.905s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.244s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.857s]
[INFO] OWS request flow controller ....................... SUCCESS [30.659s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [24.985s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.731s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.239s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.236s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [35.685s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.234s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.429s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.538s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:34.936s]
[INFO] CSW UI Module ..................................... SUCCESS [25.226s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.177s]
[INFO] DXF WFS output format ............................. SUCCESS [40.112s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [28.031s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.252s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [45.766s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.729s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:12.115s (Wall Clock)
[INFO] Finished at: Thu Aug 27 15:24:14 UTC 2015
[INFO] Final Memory: 68M/243M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1738/&gt;
