[Geoserver-devel] Build failed in Jenkins: geoserver-master #1739
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1739/changes&gt;
Changes:
[eliot.jordan] update link to rgeoserver gem
[...truncated 18266 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1193 from eliotjordan/update-ruby-documentation
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 28.08.2015 @ 01:18:06 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Aug-2015 04:35
[INFO] [GitCommitIdMojo] build.build.time = 28.08.2015 @ 05:09:45 UTC
[INFO] [GitCommitIdMojo] build.branch = 190b7a7b38515c45cbb0815fff26074cd831d8aa
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 190b7a7
[INFO] [GitCommitIdMojo] build.commit.id = 190b7a7b38515c45cbb0815fff26074cd831d8aa
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1193 from eliotjordan/update-ruby-documentation
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 28.08.2015 @ 05:09:48 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.031s]
[INFO] Core Platform Module .............................. SUCCESS [16.358s]
[INFO] Open Web Service Module ........................... SUCCESS [21.556s]
[INFO] Main Module ....................................... SUCCESS [2:34.977s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.405s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.669s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.345s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.435s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.027s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.237s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:00.249s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:25.530s]
[INFO] Web Map Service Module ............................ SUCCESS [9:01.404s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:20.601s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:24.437s]
[INFO] REST Support Module ............................... SUCCESS [40.552s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:38.468s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.418s]
[INFO] Core UI Module .................................... SUCCESS [1:55.441s]
[INFO] WMS UI Module ..................................... SUCCESS [53.650s]
[INFO] GWC UI Module ..................................... SUCCESS [1:32.417s]
[INFO] WFS UI Module ..................................... SUCCESS [33.697s]
[INFO] Demoes Module ..................................... SUCCESS [50.819s]
[INFO] WCS UI Module ..................................... SUCCESS [35.389s]
[INFO] Security UI Modules ............................... SUCCESS [0.381s]
[INFO] Security UI Core Module ........................... SUCCESS [2:45.412s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:02.990s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.644s]
[INFO] REST UI Module .................................... SUCCESS [33.492s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.278s]
[INFO] Printing Module ................................... SUCCESS [39.637s]
[INFO] Community Space ................................... SUCCESS [0.209s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.525s]
[INFO] Application Schema Support ........................ SUCCESS [0.193s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:36.373s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.904s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.926s]
[INFO] GeoSearch Index Module ............................ SUCCESS [28.369s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.015s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.622s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.158s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.502s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.532s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.009s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.337s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.890s]
[INFO] OGR parent ........................................ SUCCESS [0.837s]
[INFO] OGR CORE .......................................... SUCCESS [5.286s]
[INFO] OGR WFS ........................................... SUCCESS [24.742s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.290s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [45.595s]
[INFO] Chart external graphics support ................... SUCCESS [2.707s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.560s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.147s]
[INFO] OWS request flow controller ....................... SUCCESS [28.816s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.182s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.676s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.424s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.000s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.994s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.304s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [13.643s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.514s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.905s]
[INFO] XLST based WFS output format ...................... SUCCESS [54.938s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [56.415s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [35.215s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.425s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.680s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [36.112s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.473s]
[INFO] CSW UI Module ..................................... SUCCESS [26.212s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.332s]
[INFO] DXF WFS output format ............................. SUCCESS [37.612s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.451s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.846s]
[INFO] GeoServer Data Importer ........................... SUCCESS [1.520s]
[INFO] Importer Core Module .............................. SUCCESS [1:47.896s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:43.173s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [56.234s]
[INFO] Importer Web UI Module ............................ SUCCESS [11.677s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:15.732s (Wall Clock)
[INFO] Finished at: Fri Aug 28 05:09:48 UTC 2015
[INFO] Final Memory: 84M/269M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1740/&gt;
