[Geoserver-devel] Build failed in Jenkins: geoserver-master #1750
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1750/changes&gt;
Changes:
[andrea.aime] Turning PC bitmap into png
[...truncated 18306 lines...]
[INFO] Building GeoServer CAS Security Web Module 2.8-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Turning PC bitmap into png
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 30.08.2015 @ 08:35:55 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 30-Aug-2015 08:43
[INFO] [GitCommitIdMojo] build.build.time = 30.08.2015 @ 09:18:15 UTC
[INFO] [GitCommitIdMojo] build.branch = a8657d5457c945ad95bc05610696b460f1fcdf0f
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a8657d5
[INFO] [GitCommitIdMojo] build.commit.id = a8657d5457c945ad95bc05610696b460f1fcdf0f
[INFO] [GitCommitIdMojo] build.commit.message.full = Turning PC bitmap into png
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 30.08.2015 @ 09:18:19 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.236s]
[INFO] Core Platform Module .............................. SUCCESS [15.820s]
[INFO] Open Web Service Module ........................... SUCCESS [20.640s]
[INFO] Main Module ....................................... SUCCESS [2:34.534s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.302s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.366s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:06.631s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.806s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.385s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.115s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.235s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:34.082s]
[INFO] Web Map Service Module ............................ SUCCESS [8:01.814s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:21.138s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:27.816s]
[INFO] REST Support Module ............................... SUCCESS [43.144s]
[INFO] REST Configuration Service Module ................. FAILURE [2:34.230s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.765s]
[INFO] Core UI Module .................................... SUCCESS [1:59.982s]
[INFO] WMS UI Module ..................................... SUCCESS [51.628s]
[INFO] GWC UI Module ..................................... SUCCESS [1:27.573s]
[INFO] WFS UI Module ..................................... SUCCESS [30.903s]
[INFO] Demoes Module ..................................... SUCCESS [56.840s]
[INFO] WCS UI Module ..................................... SUCCESS [39.589s]
[INFO] Security UI Modules ............................... SUCCESS [0.225s]
[INFO] Security UI Core Module ........................... SUCCESS [2:50.532s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:08.752s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.157s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.314s]
[INFO] Printing Module ................................... SUCCESS [39.643s]
[INFO] Community Space ................................... SUCCESS [0.207s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.930s]
[INFO] Application Schema Support ........................ SUCCESS [0.197s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.406s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.081s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.826s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.474s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.389s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.673s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.481s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.500s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.513s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.343s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.831s]
[INFO] OGR parent ........................................ SUCCESS [0.471s]
[INFO] OGR CORE .......................................... SUCCESS [5.114s]
[INFO] OGR WFS ........................................... SUCCESS [26.135s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.451s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:19.882s]
[INFO] OGR WPS ........................................... SUCCESS [28.373s]
[INFO] Excel Output Format ............................... SUCCESS [42.120s]
[INFO] Chart external graphics support ................... SUCCESS [2.967s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.497s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.978s]
[INFO] OWS request flow controller ....................... SUCCESS [31.652s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [30.014s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:14.779s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.776s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.261s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.521s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.782s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.798s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.443s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.182s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.297s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.284s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.872s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.972s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.201s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [31.181s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.766s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.965s]
[INFO] CSW UI Module ..................................... SUCCESS [30.552s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.214s]
[INFO] DXF WFS output format ............................. SUCCESS [37.727s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [22.473s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.245s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [52.379s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.194s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.030s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.228s]
[INFO] Importer Core Module .............................. SUCCESS [1:45.950s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [56.822s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.948s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:26.890s (Wall Clock)
[INFO] Finished at: Sun Aug 30 09:18:19 UTC 2015
[INFO] Final Memory: 86M/274M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1751/changes&gt;
