See <http://ares.opengeo.org/jenkins/job/geoserver-master/1754/>
[...truncated 18734 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1207 from dmkelsey/dk-osx-build-fix
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 01.09.2015 @ 00:27:46 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 01-Sep-2015 14:58
[INFO] [GitCommitIdMojo] build.build.time = 01.09.2015 @ 15:33:23 UTC
[INFO] [GitCommitIdMojo] build.branch = 70f51d77d0c642c3e9a8ab38f8c3f4da777933ac
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 70f51d7
[INFO] [GitCommitIdMojo] build.commit.id = 70f51d77d0c642c3e9a8ab38f8c3f4da777933ac
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1207 from dmkelsey/dk-osx-build-fix
Fixes so that GeoServer can be packaged for OS X
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 01.09.2015 @ 15:33:26 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.186s]
[INFO] Core Platform Module .............................. SUCCESS [16.156s]
[INFO] Open Web Service Module ........................... SUCCESS [22.998s]
[INFO] Main Module ....................................... SUCCESS [2:34.443s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.402s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.049s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.540s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.383s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.019s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.235s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.999s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:32.292s]
[INFO] Web Map Service Module ............................ SUCCESS [8:01.652s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:23.800s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:29.141s]
[INFO] REST Support Module ............................... SUCCESS [40.653s]
[INFO] REST Configuration Service Module ................. FAILURE [2:36.793s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.542s]
[INFO] Core UI Module .................................... SUCCESS [1:59.422s]
[INFO] WMS UI Module ..................................... SUCCESS [56.975s]
[INFO] GWC UI Module ..................................... SUCCESS [1:31.165s]
[INFO] WFS UI Module ..................................... SUCCESS [33.874s]
[INFO] Demoes Module ..................................... SUCCESS [51.356s]
[INFO] WCS UI Module ..................................... SUCCESS [37.419s]
[INFO] Security UI Modules ............................... SUCCESS [0.564s]
[INFO] Security UI Core Module ........................... SUCCESS [2:57.471s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:06.589s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.982s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.319s]
[INFO] Printing Module ................................... SUCCESS [40.687s]
[INFO] Community Space ................................... SUCCESS [0.190s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.456s]
[INFO] Application Schema Support ........................ SUCCESS [0.445s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.966s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.365s]
[INFO] GeoSearch Index Module ............................ SUCCESS [33.159s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.718s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.444s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.664s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.523s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.425s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.327s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.381s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.765s]
[INFO] OGR parent ........................................ SUCCESS [0.321s]
[INFO] OGR CORE .......................................... SUCCESS [4.005s]
[INFO] OGR WFS ........................................... SUCCESS [22.933s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.259s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:10.692s]
[INFO] OGR WPS ........................................... SUCCESS [26.710s]
[INFO] Excel Output Format ............................... SUCCESS [47.146s]
[INFO] Chart external graphics support ................... SUCCESS [2.739s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.051s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.186s]
[INFO] OWS request flow controller ....................... SUCCESS [30.197s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [30.511s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:15.614s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.448s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.076s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.247s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.149s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.611s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.265s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.717s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.240s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.819s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [59.626s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [45.084s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.442s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [33.130s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.005s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:26.990s]
[INFO] CSW UI Module ..................................... SUCCESS [26.801s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.346s]
[INFO] DXF WFS output format ............................. SUCCESS [36.595s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.751s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.314s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [51.367s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.312s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.627s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.938s]
[INFO] Importer Core Module .............................. SUCCESS [1:46.883s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [57.773s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.889s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:36.580s (Wall Clock)
[INFO] Finished at: Tue Sep 01 15:33:26 UTC 2015
[INFO] Final Memory: 86M/245M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
