[Geoserver-devel] Build failed in Jenkins: geoserver-master #1770
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1770/&gt;
[...truncated 18173 lines...]
[INFO] Building GeoServer CAS Security Web Module 2.8-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = fix mac_installer.sh
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 03.09.2015 @ 23:54:11 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 08-Sep-2015 09:18
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2015 @ 09:53:21 UTC
[INFO] [GitCommitIdMojo] build.branch = 0113814947381facf922534936248e32757e82f0
[INFO] [GitCommitIdMojo] build.commit.user.email = tbarsballe@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Torben Barsbsballe
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0113814
[INFO] [GitCommitIdMojo] build.commit.id = 0113814947381facf922534936248e32757e82f0
[INFO] [GitCommitIdMojo] build.commit.message.full = fix mac_installer.sh
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2015 @ 09:53:24 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.524s]
[INFO] Core Platform Module .............................. SUCCESS [16.729s]
[INFO] Open Web Service Module ........................... SUCCESS [20.532s]
[INFO] Main Module ....................................... SUCCESS [2:34.276s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.478s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.421s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.367s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.203s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.376s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.404s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.282s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:27.506s]
[INFO] Web Map Service Module ............................ SUCCESS [8:00.902s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:23.751s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:28.257s]
[INFO] REST Support Module ............................... SUCCESS [42.164s]
[INFO] REST Configuration Service Module ................. FAILURE [2:43.670s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.711s]
[INFO] Core UI Module .................................... SUCCESS [1:50.809s]
[INFO] WMS UI Module ..................................... SUCCESS [53.986s]
[INFO] GWC UI Module ..................................... SUCCESS [1:38.336s]
[INFO] WFS UI Module ..................................... SUCCESS [32.673s]
[INFO] Demoes Module ..................................... SUCCESS [53.733s]
[INFO] WCS UI Module ..................................... SUCCESS [40.173s]
[INFO] Security UI Modules ............................... SUCCESS [0.271s]
[INFO] Security UI Core Module ........................... SUCCESS [2:48.377s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:11.485s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.531s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.287s]
[INFO] Printing Module ................................... SUCCESS [39.234s]
[INFO] Community Space ................................... SUCCESS [0.211s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.817s]
[INFO] Application Schema Support ........................ SUCCESS [0.204s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.585s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.449s]
[INFO] GeoSearch Index Module ............................ SUCCESS [33.162s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.345s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.466s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.795s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.471s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.668s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.238s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.022s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.845s]
[INFO] OGR parent ........................................ SUCCESS [0.506s]
[INFO] OGR CORE .......................................... SUCCESS [4.236s]
[INFO] OGR WFS ........................................... SUCCESS [25.405s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.325s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:13.066s]
[INFO] OGR WPS ........................................... SUCCESS [30.377s]
[INFO] Excel Output Format ............................... SUCCESS [38.838s]
[INFO] Chart external graphics support ................... SUCCESS [1.329s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.053s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.078s]
[INFO] OWS request flow controller ....................... SUCCESS [31.414s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.225s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:20.243s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [54.220s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.060s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.304s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.012s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [23.866s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.373s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.826s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.323s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.292s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.525s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.313s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.478s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [29.224s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.903s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.204s]
[INFO] CSW UI Module ..................................... SUCCESS [28.461s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.219s]
[INFO] DXF WFS output format ............................. SUCCESS [39.966s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [30.102s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.299s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [48.952s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.829s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.574s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.234s]
[INFO] Importer Core Module .............................. SUCCESS [1:55.477s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [58.148s]
[INFO] Importer Web UI Module ............................ SUCCESS [12.149s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:50.928s (Wall Clock)
[INFO] Finished at: Tue Sep 08 09:53:24 UTC 2015
[INFO] Final Memory: 86M/249M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1771/changes&gt;
