See <http://ares.opengeo.org/jenkins/job/geoserver-master/1776/>
[...truncated 18273 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7195] WFS SHAPE-ZIP output does not always honor field lenght restrictions
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.09.2015 @ 15:43:13 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 09-Sep-2015 22:05
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2015 @ 22:39:46 UTC
[INFO] [GitCommitIdMojo] build.branch = 84009c6383c818449df6feb347a28419d4949e6d
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 84009c6
[INFO] [GitCommitIdMojo] build.commit.id = 84009c6383c818449df6feb347a28419d4949e6d
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7195] WFS SHAPE-ZIP output does not always honor field lenght restrictions
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-bdb ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/surefire-reports>
T E S T S
Running org.geoserver.importer.bdb.BDBImportStoreTest
org.geoserver.importer.bdb.BDBImportStoreTest$ImportContext2@anonymised.com
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.89 sec
Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.311 sec
Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.908 sec
Results :
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-bdb >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-bdb ---
[INFO] [GitCommitIdMojo] build.build.time = 09.09.2015 @ 22:40:13 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-bdb <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.498s]
[INFO] Core Platform Module .............................. SUCCESS [15.296s]
[INFO] Open Web Service Module ........................... SUCCESS [20.360s]
[INFO] Main Module ....................................... SUCCESS [2:33.320s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.351s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.138s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.459s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.919s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [48.290s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.494s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:58.068s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:29.456s]
[INFO] Web Map Service Module ............................ SUCCESS [8:28.905s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:20.839s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:25.974s]
[INFO] REST Support Module ............................... SUCCESS [43.924s]
[INFO] REST Configuration Service Module ................. FAILURE [2:35.550s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.524s]
[INFO] Core UI Module .................................... SUCCESS [1:55.491s]
[INFO] WMS UI Module ..................................... SUCCESS [55.458s]
[INFO] GWC UI Module ..................................... SUCCESS [1:26.372s]
[INFO] WFS UI Module ..................................... SUCCESS [34.017s]
[INFO] Demoes Module ..................................... SUCCESS [58.573s]
[INFO] WCS UI Module ..................................... SUCCESS [39.764s]
[INFO] Security UI Modules ............................... SUCCESS [0.690s]
[INFO] Security UI Core Module ........................... SUCCESS [2:51.178s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:07.215s]
[INFO] Security UI LDAP Module ........................... SUCCESS [45.616s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.466s]
[INFO] Printing Module ................................... SUCCESS [35.383s]
[INFO] Community Space ................................... SUCCESS [0.188s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.850s]
[INFO] Application Schema Support ........................ SUCCESS [0.225s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.185s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.084s]
[INFO] GeoSearch Index Module ............................ SUCCESS [34.473s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.465s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.675s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.752s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.508s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.724s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.493s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.828s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.815s]
[INFO] OGR parent ........................................ SUCCESS [0.482s]
[INFO] OGR CORE .......................................... SUCCESS [4.601s]
[INFO] OGR WFS ........................................... SUCCESS [24.234s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.258s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:09.936s]
[INFO] OGR WPS ........................................... SUCCESS [31.213s]
[INFO] Excel Output Format ............................... SUCCESS [39.611s]
[INFO] Chart external graphics support ................... SUCCESS [1.797s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.871s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.067s]
[INFO] OWS request flow controller ....................... SUCCESS [28.567s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.901s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:09.139s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.194s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.113s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.227s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.075s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.782s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.371s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.308s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.506s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [5.087s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.910s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [43.491s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.241s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.340s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.078s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.456s]
[INFO] CSW UI Module ..................................... SUCCESS [25.427s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.364s]
[INFO] DXF WFS output format ............................. SUCCESS [40.081s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [23.275s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.208s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [48.561s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.724s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.564s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.992s]
[INFO] Importer Core Module .............................. SUCCESS [1:19.087s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [36.807s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.485s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:45.514s (Wall Clock)
[INFO] Finished at: Wed Sep 09 22:40:14 UTC 2015
[INFO] Final Memory: 86M/274M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
