[Geoserver-devel] Build failed in Jenkins: geoserver-master #1780
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1780/changes&gt;
Changes:
[Schmidt.Sebastian2] fix broken link to spatialite native libs
[bradh] [GEOS-7192] Fix documentation links that pointed to old Codehaus JIRA instance.
[bradh] [GEOS-7192] Fix bug tracker links.
[bradh] [GEOS-7192] Fix JIRA link in contributions guidelines.
[bradh] [GEOS-7192] Fix "Maintainer" reference in test data to point to enduring page.
[bradh] [GEOS-7192] Fix out-of-date reference in scriptlet docs
[...truncated 22508 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = ef3edc8
[INFO] [GitCommitIdMojo] build.commit.id = ef3edc884777373028daaa92786efaadbfb27fe0
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1210 from sebastian-r-schmidt/fix-spatialite-doc
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1210 from sebastian-r-schmidt/fix-spatialite-doc
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.09.2015 @ 20:51:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-Sep-2015 21:21
[INFO] [GitCommitIdMojo] build.build.time = 10.09.2015 @ 22:01:14 UTC
[INFO] [GitCommitIdMojo] build.branch = ef3edc884777373028daaa92786efaadbfb27fe0
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.224 sec
Running org.geoserver.importer.rest.RESTDataTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.516 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.282 sec
Results :
Tests run: 60, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] build.build.time = 10.09.2015 @ 22:01:38 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.100s]
[INFO] Core Platform Module .............................. SUCCESS [15.918s]
[INFO] Open Web Service Module ........................... SUCCESS [21.089s]
[INFO] Main Module ....................................... SUCCESS [2:33.065s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.263s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:09.231s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:05.228s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.239s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.445s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.262s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.206s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:21.512s]
[INFO] Web Map Service Module ............................ SUCCESS [8:45.864s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:21.929s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:25.603s]
[INFO] REST Support Module ............................... SUCCESS [43.120s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:41.430s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.617s]
[INFO] Core UI Module .................................... SUCCESS [1:52.103s]
[INFO] WMS UI Module ..................................... SUCCESS [56.309s]
[INFO] GWC UI Module ..................................... FAILURE [2:07.822s]
[INFO] WFS UI Module ..................................... SUCCESS [32.855s]
[INFO] Demoes Module ..................................... SUCCESS [53.564s]
[INFO] WCS UI Module ..................................... SUCCESS [51.324s]
[INFO] Security UI Modules ............................... SUCCESS [0.492s]
[INFO] Security UI Core Module ........................... SUCCESS [2:49.370s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:58.596s]
[INFO] Security UI LDAP Module ........................... SUCCESS [46.161s]
[INFO] REST UI Module .................................... SUCCESS [46.376s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.315s]
[INFO] Printing Module ................................... SUCCESS [41.679s]
[INFO] Community Space ................................... SUCCESS [0.190s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.021s]
[INFO] Application Schema Support ........................ SUCCESS [0.317s]
[INFO] Application Schema Integration Test ............... SUCCESS [5:15.370s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.681s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.426s]
[INFO] GeoSearch Index Module ............................ SUCCESS [52.188s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.058s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.546s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.735s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.436s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.598s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.557s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.273s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.718s]
[INFO] OGR parent ........................................ SUCCESS [0.416s]
[INFO] OGR CORE .......................................... SUCCESS [5.292s]
[INFO] OGR WFS ........................................... SUCCESS [26.907s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.509s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:07.146s]
[INFO] OGR WPS ........................................... SUCCESS [30.064s]
[INFO] Excel Output Format ............................... SUCCESS [37.979s]
[INFO] Chart external graphics support ................... SUCCESS [1.859s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.053s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.276s]
[INFO] OWS request flow controller ....................... SUCCESS [28.984s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [32.403s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:14.529s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.334s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.355s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.242s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.952s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [28.533s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.551s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.654s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.476s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [5.421s]
[INFO] XLST based WFS output format ...................... SUCCESS [1:17.879s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [52.670s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.711s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.331s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.081s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.148s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:30.083s]
[INFO] CSW UI Module ..................................... SUCCESS [41.138s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.192s]
[INFO] DXF WFS output format ............................. SUCCESS [38.403s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [25.447s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.169s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.738s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.827s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.351s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.395s]
[INFO] Importer Core Module .............................. SUCCESS [1:30.877s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:28.060s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [55.517s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.099s]
[INFO] BUILD FAILURE
[INFO] Total time: 40:32.788s (Wall Clock)
[INFO] Finished at: Thu Sep 10 22:01:38 UTC 2015
[INFO] Final Memory: 89M/269M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1781/changes&gt;
