See <http://ares.opengeo.org/jenkins/job/geoserver-master/1790/>
[...truncated 13148 lines...]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.673 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-csw ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix missing close of resource input stream leading to close being called on the Finalizer thread.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.09.2015 @ 17:14:05 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Sep-2015 00:03
[INFO] [GitCommitIdMojo] build.build.time = 13.09.2015 @ 00:26:13 UTC
[INFO] [GitCommitIdMojo] build.branch = 14723c4bbbb69a0f221bddf48ffbddb63b4ce887
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 14723c4
[INFO] [GitCommitIdMojo] build.commit.id = 14723c4bbbb69a0f221bddf48ffbddb63b4ce887
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix missing close of resource input stream leading to close being called on the Finalizer thread.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.088s]
[INFO] Core Platform Module .............................. SUCCESS [16.480s]
[INFO] Open Web Service Module ........................... SUCCESS [24.050s]
[INFO] Main Module ....................................... SUCCESS [2:40.644s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.669s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:14.996s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:00.913s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.004s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.625s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.883s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:01.583s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:34.693s]
[INFO] Web Map Service Module ............................ FAILURE [8:24.756s]
[INFO] REST Support Module ............................... SUCCESS [42.907s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.966s]
[INFO] Core UI Module .................................... SUCCESS [1:52.314s]
[INFO] WFS UI Module ..................................... SUCCESS [32.891s]
[INFO] Security UI Modules ............................... SUCCESS [0.494s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.343s]
[INFO] Printing Module ................................... SUCCESS [40.124s]
[INFO] Community Space ................................... SUCCESS [0.199s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.959s]
[INFO] Application Schema Support ........................ SUCCESS [0.217s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.762s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.455s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.058s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.550s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.800s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.220s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.290s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.248s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.108s]
[INFO] OGR parent ........................................ SUCCESS [0.404s]
[INFO] OGR CORE .......................................... SUCCESS [5.717s]
[INFO] OGR WFS ........................................... SUCCESS [26.405s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.398s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:00.380s]
[INFO] OGR WPS ........................................... SUCCESS [28.156s]
[INFO] Excel Output Format ............................... SUCCESS [41.156s]
[INFO] Chart external graphics support ................... SUCCESS [1.242s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.115s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.736s]
[INFO] OWS request flow controller ....................... SUCCESS [28.266s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [35.156s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.817s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.046s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.321s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.732s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.519s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.149s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [30.091s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.282s]
[INFO] CSW UI Module ..................................... SUCCESS [17.751s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.176s]
[INFO] DXF WFS output format ............................. SUCCESS [37.440s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [20.747s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.268s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [49.557s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.390s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:54.436s (Wall Clock)
[INFO] Finished at: Sun Sep 13 00:26:13 UTC 2015
[INFO] Final Memory: 68M/250M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
