See <http://ares.opengeo.org/jenkins/job/geoserver-master/1792/>
Started by an SCM change
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/>
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 14723c4bbbb69a0f221bddf48ffbddb63b4ce887 (origin/master)
ERROR: Workspace has a .git repository, but it appears to be corrupt.
hudson.plugins.git.GitException: Error performing command: git rev-parse --is-inside-work-tree
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:797)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:756)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:766)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.hasGitRepo(CliGitAPIImpl.java:96)
at hudson.plugins.git.GitAPI.hasGitRepo(GitAPI.java:177)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:970)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:948)
at hudson.FilePath.act(FilePath.java:914)
at hudson.FilePath.act(FilePath.java:887)
at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:948)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1114)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
at hudson.model.Run.execute(Run.java:1689)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:231)
Caused by: java.io.IOException: Cannot run program "git" (in directory "<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/"\)>: java.io.IOException: error=24, Too many open files
at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
at hudson.Proc$LocalProc.<init>(Proc.java:244)
at hudson.Proc$LocalProc.<init>(Proc.java:216)
at hudson.Launcher$LocalLauncher.launch(Launcher.java:773)
at hudson.Launcher$ProcStarter.start(Launcher.java:353)
at hudson.Launcher$ProcStarter.join(Launcher.java:360)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:786)
... 18 more
Caused by: java.io.IOException: java.io.IOException: error=24, Too many open files
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
... 24 more
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
Error trying to determine the git version: Error performing command: git --version
Assuming 1.6
ERROR: Failed to clean the workspace
java.io.IOException: Unable to delete <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/demo/target/classes/org>
at hudson.Util.deleteFile(Util.java:254)
at hudson.Util.deleteRecursive(Util.java:301)
at hudson.Util.deleteContentsRecursive(Util.java:203)
at hudson.Util.deleteRecursive(Util.java:292)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:198)
at org.jenkinsci.plugins.gitclient.AbstractGitAPIImpl.clone(AbstractGitAPIImpl.java:57)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clone(CliGitAPIImpl.java:33)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:1012)
ERROR: Error cloning remote repo 'origin' : Failed to delete workspace
hudson.plugins.git.GitException: Failed to delete workspace
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:201)
Caused by: java.io.IOException: Unable to delete <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/demo/target/classes/org>
... 16 more
Trying next repository
ERROR: Could not clone repository
java.io.IOException: Could not clone
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:1025)
