See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1797/changes>
Changes:
[smithkm] GEOS-6987 Added UI for case normalization in parameter filters
[smithkm] GEOS-6987 Added UI for IntegerParameterFilter
[smithkm] Document parameter filters UI
[...truncated 5736 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1095 from smithkm/gwc-param-ui
GEOS-6987 - Support new GWC Parameter Filter options via UI
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-gwc ---
[INFO] Copying 16 resources
[INFO] Copying 32 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-gwc ---
[INFO] Compiling 44 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/web/gwc/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-gwc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/web/gwc/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-gwc ---
[INFO] Compiling 14 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/web/gwc/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[37,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[77,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[100,21] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[106,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[115,21] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[121,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[130,21] error: cannot find symbol
[INFO] 7 errors
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.084s]
[INFO] Core Platform Module .............................. SUCCESS [19.531s]
[INFO] Open Web Service Module ........................... SUCCESS [14.352s]
[INFO] Main Module ....................................... SUCCESS [3:29.541s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.796s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.390s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [12.839s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.929s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:23.794s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.342s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.179s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:02.084s]
[INFO] Web Map Service Module ............................ SUCCESS [4:15.513s]
[INFO] KML support for GeoServer ......................... SUCCESS [53.327s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:48.818s]
[INFO] REST Support Module ............................... SUCCESS [27.175s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:04.059s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.327s]
[INFO] Core UI Module .................................... SUCCESS [1:45.144s]
[INFO] WMS UI Module ..................................... SUCCESS [37.253s]
[INFO] GWC UI Module ..................................... FAILURE [11.107s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 25:58.745s
[INFO] Finished at: Wed Jun 17 23:51:11 CEST 2015
[INFO] Final Memory: 58M/285M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-web-gwc: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1798/changes>
Changes:
[groldan] Add GeoServerTileLayer.getBlobStoreId() as per upstream API addition
[groldan] Let GeoServerTileLayer.getMetatilingReponse propagate GeoWebCacheExceptions.
[...truncated 4110 lines...]
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Let GeoServerTileLayer.getMetatilingReponse propagate GeoWebCacheExceptions.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.06.2015 @ 04:45:15 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 04:54
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 05:12:14 CEST
[INFO] [GitCommitIdMojo] build.branch = cc289c2ff87ca6750596d7b37765b070e5ced8a2
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = cc289c2
[INFO] [GitCommitIdMojo] build.commit.id = cc289c2ff87ca6750596d7b37765b070e5ced8a2
[INFO] [GitCommitIdMojo] build.commit.message.full = Let GeoServerTileLayer.getMetatilingReponse propagate GeoWebCacheExceptions.
Wrapping GeoWebCacheException with another GeoWebCacheException produces
meaningless exception messages in the log. Propagate them directly as the
method's signature already declares it throws that kind of exceptions.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 41 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/gwc/target/classes>
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfoImpl.java:[27,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfo.java:[14,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[161,4] error: method does not override or implement a method from a supertype
[INFO] 3 errors
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.677s]
[INFO] Core Platform Module .............................. SUCCESS [20.592s]
[INFO] Open Web Service Module ........................... SUCCESS [16.208s]
[INFO] Main Module ....................................... SUCCESS [3:31.646s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.764s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [31.713s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.338s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.103s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.398s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.624s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.605s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:09.571s]
[INFO] Web Map Service Module ............................ SUCCESS [3:56.325s]
[INFO] KML support for GeoServer ......................... SUCCESS [53.995s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [5.882s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Total time: 17:47.449s
[INFO] Finished at: Thu Jun 18 05:12:19 CEST 2015
[INFO] Final Memory: 54M/273M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1799/changes>
Changes:
[groldan] Add GeoServerTileLayer.setBlobStoreId(String) as per upstream API change.
[...truncated 3912 lines...]
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] build.commit.message.short = Add GeoServerTileLayer.setBlobStoreId(String) as per upstream API change.
[INFO] [GitCommitIdMojo] build.commit.time = 18.06.2015 @ 05:02:51 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 06:24
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 06:41:42 CEST
[INFO] [GitCommitIdMojo] build.branch = 4ea3f0a4bdeeb7a7aa97492e10c76205aa7e660c
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4ea3f0a
[INFO] [GitCommitIdMojo] build.commit.id = 4ea3f0a4bdeeb7a7aa97492e10c76205aa7e660c
[INFO] [GitCommitIdMojo] build.commit.message.full = Add GeoServerTileLayer.setBlobStoreId(String) as per upstream API change.
[INFO]
[INFO]
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[1205,4] error: method does not override or implement a method from a supertype
[INFO] 4 errors
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.286s]
[INFO] Core Platform Module .............................. SUCCESS [19.968s]
[INFO] Open Web Service Module ........................... SUCCESS [14.243s]
[INFO] Main Module ....................................... SUCCESS [3:32.520s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [31.906s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.136s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.165s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:02.634s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.498s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:57.047s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:03.868s]
[INFO] Web Map Service Module ............................ SUCCESS [3:53.268s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.065s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [5.476s]
[INFO] Total time: 17:23.207s
[INFO] Finished at: Thu Jun 18 06:41:47 CEST 2015
[INFO] Final Memory: 53M/299M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1800/>
[...truncated 3893 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 11:03
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 11:22:08 CEST
[INFO]
[INFO]
[INFO] 4 errors
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.281s]
[INFO] Core Platform Module .............................. SUCCESS [20.904s]
[INFO] Open Web Service Module ........................... SUCCESS [15.241s]
[INFO] Main Module ....................................... SUCCESS [3:53.575s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.765s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.904s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.306s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.864s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.969s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:13.554s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.457s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:15.775s]
[INFO] Web Map Service Module ............................ SUCCESS [4:09.133s]
[INFO] KML support for GeoServer ......................... SUCCESS [56.984s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [6.661s]
[INFO] Total time: 18:46.674s
[INFO] Finished at: Thu Jun 18 11:22:14 CEST 2015
[INFO] Final Memory: 54M/316M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1801/>
[...truncated 3897 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 12:35
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 12:53:14 CEST
[INFO]
[INFO]
[INFO] 4 errors
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.224s]
[INFO] Core Platform Module .............................. SUCCESS [19.921s]
[INFO] Open Web Service Module ........................... SUCCESS [15.553s]
[INFO] Main Module ....................................... SUCCESS [3:34.580s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.733s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.637s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.416s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.539s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.693s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.543s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:01.977s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:03.440s]
[INFO] Web Map Service Module ............................ SUCCESS [3:53.985s]
[INFO] KML support for GeoServer ......................... SUCCESS [55.068s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [5.804s]
[INFO] Total time: 17:42.162s
[INFO] Finished at: Thu Jun 18 12:53:20 CEST 2015
[INFO] Final Memory: 55M/396M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
