Hudson
September 24, 2015, 1:29am
1
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1803/> ;
[...truncated 17124 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Documented improved null handling in FormatDateTimezone function
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 23.09.2015 @ 23:27:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Sep-2015 00:54
[INFO] [GitCommitIdMojo] build.build.time = 24.09.2015 @ 01:29:12 UTC
[INFO] [GitCommitIdMojo] build.branch = e947111f9ff89056de15fa1074d2cd30de0fa27c
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e947111
[INFO] [GitCommitIdMojo] build.commit.id = e947111f9ff89056de15fa1074d2cd30de0fa27c
[INFO] [GitCommitIdMojo] build.commit.message.full = Documented improved null handling in FormatDateTimezone function
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git ’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.366 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] build.build.time = 24.09.2015 @ 01:29:17 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.352s]
[INFO] Core Platform Module .............................. SUCCESS [15.950s]
[INFO] Open Web Service Module ........................... SUCCESS [20.739s]
[INFO] Main Module ....................................... SUCCESS [2:34.747s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.257s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.934s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [3:58.306s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.297s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.907s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [52.658s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:03.651s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:24.413s]
[INFO] Web Map Service Module ............................ SUCCESS [8:06.608s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:23.933s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:37.588s]
[INFO] REST Support Module ............................... SUCCESS [41.509s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:46.706s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.566s]
[INFO] Core UI Module .................................... SUCCESS [1:50.834s]
[INFO] WMS UI Module ..................................... SUCCESS [53.837s]
[INFO] GWC UI Module ..................................... SUCCESS [1:39.456s]
[INFO] WFS UI Module ..................................... SUCCESS [34.853s]
[INFO] Demoes Module ..................................... SUCCESS [56.993s]
[INFO] WCS UI Module ..................................... SUCCESS [40.423s]
[INFO] Security UI Modules ............................... SUCCESS [0.474s]
[INFO] Security UI Core Module ........................... SUCCESS [3:06.515s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:05.449s]
[INFO] Security UI LDAP Module ........................... SUCCESS [48.691s]
[INFO] REST UI Module .................................... SUCCESS [33.643s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.281s]
[INFO] Printing Module ................................... SUCCESS [23.051s]
[INFO] Community Space ................................... SUCCESS [0.209s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.475s]
[INFO] Application Schema Support ........................ SUCCESS [0.203s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:49.458s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.032s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [21.040s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.707s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.696s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.464s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.831s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.627s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.520s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.833s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.160s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.939s]
[INFO] OGR parent ........................................ SUCCESS [0.469s]
[INFO] OGR CORE .......................................... SUCCESS [4.292s]
[INFO] OGR WFS ........................................... SUCCESS [27.597s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.360s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [37.930s]
[INFO] Chart external graphics support ................... SUCCESS [1.113s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.567s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.288s]
[INFO] OWS request flow controller ....................... SUCCESS [29.781s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.567s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.290s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.263s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.028s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.201s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.441s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [14.588s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.380s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [6.004s]
[INFO] XLST based WFS output format ...................... SUCCESS [58.584s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:02.112s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.563s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.244s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.979s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.780s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.030s]
[INFO] CSW UI Module ..................................... SUCCESS [25.859s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.370s]
[INFO] DXF WFS output format ............................. SUCCESS [38.098s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.342s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.862s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.328s]
[INFO] Importer Core Module .............................. SUCCESS [1:52.142s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:37.524s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [58.234s]
[INFO] Importer Web UI Module ............................ SUCCESS [35.465s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:59.457s (Wall Clock)
[INFO] Finished at: Thu Sep 24 01:29:17 UTC 2015
[INFO] Final Memory: 84M/247M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
Hudson
September 24, 2015, 4:31am
2
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1804/> ;
[...truncated 21948 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-platform ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-platform ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-platform ---
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-platform ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-platform ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-platform ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-platform ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-platform >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-platform ---
[INFO] [GitCommitIdMojo] build.timestamp = 24-Sep-2015 04:23
[INFO] [GitCommitIdMojo] build.build.time = 24.09.2015 @ 04:30:41 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-platform <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-platform ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-platform ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/gs-platform-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-platform ---
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:gs-platform:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main ): Connection to http://repo.boundlessgeo.com refused
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6:53.118s]
[INFO] Core Platform Module .............................. FAILURE [1:05.012s]
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] Total time: 8:06.273s
[INFO] Finished at: Thu Sep 24 04:31:44 UTC 2015
[INFO] Final Memory: 43M/236M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-platform: Failed to retrieve remote metadata org.geoserver:gs-platform:2.9-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:gs-platform:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main ): Connection to http://repo.boundlessgeo.com refused: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
Hudson
September 24, 2015, 11:27am
3
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1805/> ;
[...truncated 117744 lines...]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-script-py ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/src/main/resources> ;
[INFO] Copying 12 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-script-py ---
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/classes> ;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-script-py ---
[INFO] Copying 11 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-script-py ---
[INFO] Compiling 11 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/test-classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-script-py ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-script-py ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-script-py ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-py >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-script-py ---
[INFO] [GitCommitIdMojo] build.timestamp = 24-Sep-2015 08:53
[INFO] [GitCommitIdMojo] build.build.time = 24.09.2015 @ 10:57:54 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-py <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-py ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-py >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-py <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-py ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-script-py ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-script-py ---
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.script:gs-script-py:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main ): Read timed out
[INFO]
[INFO] GeoServer ......................................... SUCCESS [45.071s]
[INFO] Core Platform Module .............................. SUCCESS [3.378s]
[INFO] Open Web Service Module ........................... SUCCESS [5.409s]
[INFO] Main Module ....................................... SUCCESS [14.766s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.050s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1.635s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.084s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.201s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [2.343s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1.720s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1.513s]
[INFO] Web Feature Service Module ........................ SUCCESS [2.957s]
[INFO] Web Map Service Module ............................ SUCCESS [5.927s]
[INFO] KML support for GeoServer ......................... SUCCESS [4.996s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.020s]
[INFO] REST Support Module ............................... SUCCESS [4.106s]
[INFO] REST Configuration Service Module ................. SUCCESS [4.873s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.875s]
[INFO] Core UI Module .................................... SUCCESS [28.089s]
[INFO] WMS UI Module ..................................... SUCCESS [1.628s]
[INFO] GWC UI Module ..................................... SUCCESS [3.884s]
[INFO] WFS UI Module ..................................... SUCCESS [1.279s]
[INFO] Demoes Module ..................................... SUCCESS [1.727s]
[INFO] WCS UI Module ..................................... SUCCESS [7.102s]
[INFO] Security UI Modules ............................... SUCCESS [2.965s]
[INFO] Security UI Core Module ........................... SUCCESS [3.629s]
[INFO] Security UI JDBC Module ........................... SUCCESS [57.587s]
[INFO] Security UI LDAP Module ........................... SUCCESS [1.041s]
[INFO] REST UI Module .................................... SUCCESS [2.835s]
[INFO] GeoServer Web Application ......................... SUCCESS [30.350s]
[INFO] Community Space ................................... SUCCESS [5.981s]
[INFO] Authentication by unique url key .................. SUCCESS [11.864s]
[INFO] WorldWind Format Module ........................... SUCCESS [8.667s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [5.052s]
[INFO] SpatiaLite Extension .............................. SUCCESS [6.832s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [10.151s]
[INFO] Simple Feature Service ............................ SUCCESS [6.959s]
[INFO] Aggregating Data Store ............................ SUCCESS [5.023s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.625s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.521s]
[INFO] Web Processing Service Module ..................... SUCCESS [1:18.261s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [16:43.978s]
[INFO] Core Scripting Extension .......................... SUCCESS [41.470s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [1:20.744s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [38.890s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [1:37:08.405s]
[INFO] H2 DataStore Extension ............................ SUCCESS [1:07.712s]
[INFO] Python Scripting Extension ........................ FAILURE [30:18.163s]
[INFO] Total time: 2:34:44.772s
[INFO] Finished at: Thu Sep 24 11:27:54 UTC 2015
[INFO] Final Memory: 86M/347M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-script-py: Failed to retrieve remote metadata org.geoserver.script:gs-script-py:2.9-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.script:gs-script-py:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main ): Read timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-script-py
Hudson
September 24, 2015, 4:40pm
4
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1806/changes> ;
Changes:
[simone.giannecchini] Adding travis badge to README.md
[simone.giannecchini] Revert "Adding travis badge to README.md"
[...truncated 13215 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-dxf-wps ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-dxf-wps ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/classes> ;
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1229 from geoserver/revert-1228-travis-badge
[INFO] [GitCommitIdMojo] build.commit.time = 24.09.2015 @ 12:06:42 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Sep-2015 14:01
[INFO] [GitCommitIdMojo] build.build.time = 24.09.2015 @ 16:40:09 UTC
[INFO] [GitCommitIdMojo] build.branch = c07b99e0163e95d33075d494211a221103976135
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c07b99e
[INFO] [GitCommitIdMojo] build.commit.id = c07b99e0163e95d33075d494211a221103976135
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1229 from geoserver/revert-1228-travis-badge
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ogr-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ogr-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.9-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-ogr-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-dxf-wps ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-dxf-wps ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/test-classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-dxf-wps ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/surefire-reports> ;
T E S T S
Running org.geoserver.wps.ppio.DXFPPIOTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.623 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] build.build.time = 24.09.2015 @ 16:40:27 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [31:05.367s]
[INFO] Core Platform Module .............................. SUCCESS [16.377s]
[INFO] Open Web Service Module ........................... SUCCESS [31.822s]
[INFO] Main Module ....................................... SUCCESS [1:43:18.053s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.252s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:04.866s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:51.342s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.840s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.116s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.833s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:25.921s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.174s]
[INFO] Web Map Service Module ............................ FAILURE [7:06.241s]
[INFO] REST Support Module ............................... SUCCESS [39.913s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.573s]
[INFO] Core UI Module .................................... SUCCESS [1:53.161s]
[INFO] WFS UI Module ..................................... SUCCESS [17.913s]
[INFO] Security UI Modules ............................... SUCCESS [0.518s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.343s]
[INFO] Printing Module ................................... SUCCESS [40.014s]
[INFO] Community Space ................................... SUCCESS [0.228s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.098s]
[INFO] Application Schema Support ........................ SUCCESS [0.186s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [23.613s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [11:59.628s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.127s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.635s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.001s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.445s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [15.346s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [59.046s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [8.299s]
[INFO] OGR parent ........................................ SUCCESS [0.177s]
[INFO] OGR CORE .......................................... SUCCESS [3.951s]
[INFO] OGR WFS ........................................... SUCCESS [14.682s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.172s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:04.387s]
[INFO] OGR WPS ........................................... SUCCESS [24.333s]
[INFO] Excel Output Format ............................... SUCCESS [23.439s]
[INFO] Chart external graphics support ................... SUCCESS [0.716s]
[INFO] Feature Generalization Extension .................. SUCCESS [35.883s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.691s]
[INFO] OWS request flow controller ....................... SUCCESS [26.717s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.913s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.009s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.332s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.378s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [26.791s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.325s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [39.924s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [23.880s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.213s]
[INFO] CSW UI Module ..................................... SUCCESS [24.754s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.214s]
[INFO] DXF WFS output format ............................. SUCCESS [23.372s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [18.231s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.352s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.392s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.598s]
[INFO] Total time: 2:38:50.981s (Wall Clock)
[INFO] Finished at: Thu Sep 24 16:40:27 UTC 2015
[INFO] Final Memory: 68M/163M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
http://repo.boundlessgeo.com/ is currently experiencing difficulties (resulting in this build failure), and should be restored shortly.
On Thu, Sep 24, 2015 at 4:27 AM, <monitor@anonymised.com > wrote:
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1805/ >
[…truncated 117744 lines…]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-script-py —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/src/main/resources >
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-script-py —
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/classes >
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-script-py —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-script-py —
[INFO] Compiling 11 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/test-classes >
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-script-py —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-script-py —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT.jar >
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-script-py —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-tests.jar >
[INFO]
[INFO]
[INFO] — git-commit-id-plugin:2.0.4:revision (default) @ gs-script-py —
[INFO] [GitCommitIdMojo] Running on ‘<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git ’> repository…
[INFO] [GitCommitIdMojo] Initializing properties…
[INFO] [GitCommitIdMojo] Using maven project properties…
[INFO] [GitCommitIdMojo] Loading data from git repository…
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-py —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-sources.jar >
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-py —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-test-sources.jar >
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gs-script-py —
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT.jar > to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/pom.xml > to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-tests.jar > to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-sources.jar > to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/script/py/target/gs-script-py-2.9-SNAPSHOT-test-sources.jar > to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-py/2.9-SNAPSHOT/gs-script-py-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-script-py —
[INFO]
[INFO] GeoServer … SUCCESS [45.071s]
[INFO] Core Platform Module … SUCCESS [3.378s]
[INFO] Open Web Service Module … SUCCESS [5.409s]
[INFO] Main Module … SUCCESS [14.766s]
[INFO] GeoServer Security Modules … SUCCESS [1.050s]
[INFO] GeoServer JDBC Security Module … SUCCESS [1.635s]
[INFO] GeoServer LDAP Security Module … SUCCESS [4.084s]
[INFO] Web Coverage Service Module … SUCCESS [1.201s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [2.343s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [1.720s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [1.513s]
[INFO] Web Feature Service Module … SUCCESS [2.957s]
[INFO] Web Map Service Module … SUCCESS [5.927s]
[INFO] KML support for GeoServer … SUCCESS [4.996s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [11.020s]
[INFO] REST Support Module … SUCCESS [4.106s]
[INFO] REST Configuration Service Module … SUCCESS [4.873s]
[INFO] GeoServer Web Modules … SUCCESS [0.875s]
[INFO] Core UI Module … SUCCESS [28.089s]
[INFO] WMS UI Module … SUCCESS [1.628s]
[INFO] GWC UI Module … SUCCESS [3.884s]
[INFO] WFS UI Module … SUCCESS [1.279s]
[INFO] Demoes Module … SUCCESS [1.727s]
[INFO] WCS UI Module … SUCCESS [7.102s]
[INFO] Security UI Modules … SUCCESS [2.965s]
[INFO] Security UI Core Module … SUCCESS [3.629s]
[INFO] Security UI JDBC Module … SUCCESS [57.587s]
[INFO] Security UI LDAP Module … SUCCESS [1.041s]
[INFO] REST UI Module … SUCCESS [2.835s]
[INFO] GeoServer Web Application … SUCCESS [30.350s]
[INFO] Community Space … SUCCESS [5.981s]
[INFO] Authentication by unique url key … SUCCESS [11.864s]
[INFO] WorldWind Format Module … SUCCESS [8.667s]
[INFO] GeoServer Embedded FTP server … SUCCESS [5.052s]
[INFO] SpatiaLite Extension … SUCCESS [6.832s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [10.151s]
[INFO] Simple Feature Service … SUCCESS [6.959s]
[INFO] Aggregating Data Store … SUCCESS [5.023s]
[INFO] GeoServer Extensions … SUCCESS [0.625s]
[INFO] Web Processing Service parent … SUCCESS [0.521s]
[INFO] Web Processing Service Module … SUCCESS [1:18.261s]
[INFO] GeoServer Scripting Extensions … SUCCESS [16:43.978s]
[INFO] Core Scripting Extension … SUCCESS [41.470s]
[INFO] Web UI Scripting Extension … SUCCESS [1:20.744s]
[INFO] BeanShell Scripting Extension … SUCCESS [38.890s]
[INFO] Groovy Scripting Extension … SUCCESS [1:37:08.405s]
[INFO] H2 DataStore Extension … SUCCESS [1:07.712s]
[INFO] Python Scripting Extension … FAILURE [30:18.163s]
[INFO] JavaScript Scripting Extension … SKIPPED
[INFO] Ruby Scripting Extension … SKIPPED
[INFO] WMS-EO … SKIPPED
[INFO] ColorMap … SKIPPED
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[INFO] GeoServer mbtiles Extension … SKIPPED
[INFO] GeoServer GeoPackage Extension … SKIPPED
[INFO] GRIB Coverage Format … SKIPPED
[INFO] Dynamic WMS dimension value defaults … SKIPPED
[INFO] REST plugin community module … SKIPPED
[INFO] GPX PPIO for WPS … SKIPPED
[INFO] KML PPIO for WPS … SKIPPED
[INFO] DownloadProcess … SKIPPED
[INFO] GeoServer JMS based clustering modules … SKIPPED
[INFO] ActiveMQ … SKIPPED
[INFO] GeoServer JMS clustering Commons module … SKIPPED
[INFO] GeoServer JMS clustering module … SKIPPED
[INFO] GeoServer Hazelcast Clustering Module … SKIPPED
[INFO] Solr Module … SKIPPED
[INFO] Resumable REST Upload module … SKIPPED
[INFO] GeoFence security integration … SKIPPED
[INFO] GeoFence Server … SKIPPED
[INFO] REST SLD service … SKIPPED
[INFO] GWC Distributed Caching Plugin … SKIPPED
[INFO] GeoWebCache S3 … SKIPPED
[INFO] OGR parent … SKIPPED
[INFO] OGR CORE … SKIPPED
[INFO] GDAL translate parent … SKIPPED
[INFO] GDAL translate WCS … SKIPPED
[INFO] GDAL translate WPS … SKIPPED
[INFO] GeoServer Community Release Module … SKIPPED
[INFO] Application Schema Support … SKIPPED
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] GeoSearch Index Module … SKIPPED
[INFO] SQL Server DataStore Extension … SKIPPED
[INFO] Oracle DataStore Extension … SKIPPED
[INFO] MySQL DataStore Extension … SKIPPED
[INFO] DB2 DataStore Extension … SKIPPED
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SKIPPED
[INFO] JP2K Coverage Extension … SKIPPED
[INFO] OGR WFS … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Chart external graphics support … SKIPPED
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SKIPPED
[INFO] OWS request flow controller … SKIPPED
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SKIPPED
[INFO] DXF WFS output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] Printing Module … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SKIPPED
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-script-py: Failed to retrieve remote metadata org.geoserver.script:gs-script-py:2.9-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.script:gs-script-py:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main ): Read timed out → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-script-py
Build step ‘Invoke top-level Maven targets’ marked build as failure
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools
in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
Geoserver-devel mailing list
Hudson
September 25, 2015, 12:42am
6
