Hudson
September 26, 2015, 11:05am
1
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1813/changes> ;
Changes:
[m.filocha] Missing space added
[...truncated 16309 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target> ;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git ’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1230 from mfilocha/patch-1
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 26.09.2015 @ 09:06:41 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 26-Sep-2015 10:34
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 11:05:09 UTC
[INFO] [GitCommitIdMojo] build.branch = 28587a24f02530b945df21d4ea2d8e95bfd2032e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 28587a2
[INFO] [GitCommitIdMojo] build.commit.id = 28587a24f02530b945df21d4ea2d8e95bfd2032e
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1230 from mfilocha/patch-1
Missing space in "JMS based Clustering" chapter added
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources> ;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes> ;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java> ;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources> ;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> ;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 11:05:13 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.469s]
[INFO] Core Platform Module .............................. SUCCESS [23.780s]
[INFO] Open Web Service Module ........................... SUCCESS [27.378s]
[INFO] Main Module ....................................... SUCCESS [3:21.937s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.455s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.960s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:08.371s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.172s]
[INFO] Web Coverage Service 1.0 Module ................... FAILURE [45.110s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.833s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:56.068s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:43.817s]
[INFO] Web Map Service Module ............................ SUCCESS [7:50.182s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:19.325s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:20.531s]
[INFO] REST Support Module ............................... SUCCESS [56.826s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.914s]
[INFO] Core UI Module .................................... SUCCESS [1:59.114s]
[INFO] WMS UI Module ..................................... SUCCESS [57.440s]
[INFO] GWC UI Module ..................................... SUCCESS [1:26.167s]
[INFO] WFS UI Module ..................................... SUCCESS [32.018s]
[INFO] Demoes Module ..................................... SUCCESS [56.389s]
[INFO] WCS UI Module ..................................... SUCCESS [42.628s]
[INFO] Security UI Modules ............................... SUCCESS [0.236s]
[INFO] Security UI Core Module ........................... SUCCESS [2:54.181s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:06.739s]
[INFO] Security UI LDAP Module ........................... SUCCESS [41.420s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.899s]
[INFO] Printing Module ................................... SUCCESS [38.010s]
[INFO] Community Space ................................... SUCCESS [0.519s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.904s]
[INFO] Application Schema Support ........................ SUCCESS [0.481s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.534s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.441s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.586s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.145s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.258s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.174s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.766s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.848s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.794s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.840s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.044s]
[INFO] OGR parent ........................................ SUCCESS [0.377s]
[INFO] OGR CORE .......................................... SUCCESS [4.547s]
[INFO] OGR WFS ........................................... SUCCESS [27.506s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.207s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [36.961s]
[INFO] Chart external graphics support ................... SUCCESS [1.444s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.248s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.525s]
[INFO] OWS request flow controller ....................... SUCCESS [29.495s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.213s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.572s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.234s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.515s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.562s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.698s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.923s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [43.485s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.321s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.364s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.834s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.481s]
[INFO] CSW UI Module ..................................... SUCCESS [22.383s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.478s]
[INFO] DXF WFS output format ............................. SUCCESS [41.510s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.449s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [51.432s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [37.637s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.496s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.667s]
[INFO] Importer Core Module .............................. SUCCESS [1:49.928s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [53.886s]
[INFO] Importer Web UI Module ............................ SUCCESS [38.381s]
[INFO] BUILD FAILURE
[INFO] Total time: 30:40.345s (Wall Clock)
[INFO] Finished at: Sat Sep 26 11:05:13 UTC 2015
[INFO] Final Memory: 79M/270M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs1_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs1_0/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs1_0
Hudson
September 26, 2015, 1:05pm
2
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1814/> ;
[...truncated 16330 lines...]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 26-Sep-2015 12:22
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 13:05:02 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 13:05:05 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13:20.436s]
[INFO] Core Platform Module .............................. SUCCESS [16.078s]
[INFO] Open Web Service Module ........................... SUCCESS [21.225s]
[INFO] Main Module ....................................... SUCCESS [2:31.734s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.385s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.479s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.868s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.849s]
[INFO] Web Coverage Service 1.0 Module ................... FAILURE [43.779s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.657s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:55.470s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.318s]
[INFO] Web Map Service Module ............................ SUCCESS [8:05.931s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:21.298s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:20.339s]
[INFO] REST Support Module ............................... SUCCESS [40.259s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.884s]
[INFO] Core UI Module .................................... SUCCESS [1:54.789s]
[INFO] WMS UI Module ..................................... SUCCESS [53.774s]
[INFO] GWC UI Module ..................................... SUCCESS [1:26.546s]
[INFO] WFS UI Module ..................................... SUCCESS [30.685s]
[INFO] Demoes Module ..................................... SUCCESS [55.588s]
[INFO] WCS UI Module ..................................... SUCCESS [39.490s]
[INFO] Security UI Modules ............................... SUCCESS [0.235s]
[INFO] Security UI Core Module ........................... SUCCESS [2:52.800s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:08.646s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.188s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.415s]
[INFO] Printing Module ................................... SUCCESS [40.781s]
[INFO] Community Space ................................... SUCCESS [0.273s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.113s]
[INFO] Application Schema Support ........................ SUCCESS [0.248s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.202s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.754s]
[INFO] GeoSearch Index Module ............................ SUCCESS [30.778s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.752s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.603s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.712s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.518s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.657s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.434s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.124s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.716s]
[INFO] OGR parent ........................................ SUCCESS [0.335s]
[INFO] OGR CORE .......................................... SUCCESS [6.014s]
[INFO] OGR WFS ........................................... SUCCESS [24.762s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.708s]
[INFO] Excel Output Format ............................... SUCCESS [37.806s]
[INFO] Chart external graphics support ................... SUCCESS [1.332s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.781s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.207s]
[INFO] OWS request flow controller ....................... SUCCESS [28.625s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.837s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.552s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.267s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.825s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.429s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.379s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.560s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [44.507s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.215s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [29.437s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.216s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:32.731s]
[INFO] CSW UI Module ..................................... SUCCESS [22.429s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.398s]
[INFO] DXF WFS output format ............................. SUCCESS [37.955s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.349s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [48.440s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.496s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [19.711s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.741s]
[INFO] Importer Core Module .............................. SUCCESS [1:49.044s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [52.970s]
[INFO] Importer Web UI Module ............................ SUCCESS [38.908s]
[INFO] Total time: 42:22.357s (Wall Clock)
[INFO] Finished at: Sat Sep 26 13:05:05 UTC 2015
[INFO] Final Memory: 80M/267M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
September 26, 2015, 4:46pm
3
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1815/changes> ;
Changes:
[andrea.aime] Update .travis.yml
[...truncated 15720 lines...]
[INFO] [GitCommitIdMojo] build.commit.time = 26.09.2015 @ 13:03:21 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 26-Sep-2015 14:26
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 16:46:29 UTC
[INFO] [GitCommitIdMojo] build.branch = 2ad6d3547e7b526c3f78908cfcb0942a078d693d
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2ad6d35
[INFO] [GitCommitIdMojo] build.commit.id = 2ad6d3547e7b526c3f78908cfcb0942a078d693d
[INFO] [GitCommitIdMojo] build.commit.message.full = Update .travis.yml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-sources.jar> ;
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Update .travis.yml
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 16:46:30 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT-tests.jar> ;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/gs-web-wcs-2.9-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.790s]
[INFO] Core Platform Module .............................. SUCCESS [16.369s]
[INFO] Open Web Service Module ........................... SUCCESS [30.162s]
[INFO] Main Module ....................................... SUCCESS [1:33:32.777s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.287s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:05.099s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:34.340s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.072s]
[INFO] Web Coverage Service 1.0 Module ................... FAILURE [1:40.635s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.951s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:45.319s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:16.909s]
[INFO] Web Map Service Module ............................ SUCCESS [4:52.812s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:16.959s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:58.973s]
[INFO] REST Support Module ............................... SUCCESS [43.068s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.675s]
[INFO] Core UI Module .................................... SUCCESS [1:58.950s]
[INFO] WMS UI Module ..................................... SUCCESS [42.928s]
[INFO] GWC UI Module ..................................... SUCCESS [53.319s]
[INFO] WFS UI Module ..................................... SUCCESS [24.630s]
[INFO] Demoes Module ..................................... SUCCESS [30:33.267s]
[INFO] WCS UI Module ..................................... SUCCESS [38.831s]
[INFO] Security UI Modules ............................... SUCCESS [0.347s]
[INFO] Security UI Core Module ........................... SUCCESS [1:55.209s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:27.112s]
[INFO] Security UI LDAP Module ........................... SUCCESS [28.579s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.274s]
[INFO] Printing Module ................................... SUCCESS [33.200s]
[INFO] Community Space ................................... SUCCESS [0.194s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.802s]
[INFO] Application Schema Support ........................ SUCCESS [0.194s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [41.297s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.664s]
[INFO] GeoSearch Index Module ............................ SUCCESS [19.470s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.022s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.851s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.664s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.587s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.426s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.164s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [9.565s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.567s]
[INFO] OGR parent ........................................ SUCCESS [0.345s]
[INFO] OGR CORE .......................................... SUCCESS [4.375s]
[INFO] OGR WFS ........................................... SUCCESS [28.277s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.408s]
[INFO] Excel Output Format ............................... SUCCESS [39.302s]
[INFO] Chart external graphics support ................... SUCCESS [8.487s]
[INFO] Feature Generalization Extension .................. SUCCESS [20.212s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [15.100s]
[INFO] OWS request flow controller ....................... SUCCESS [26.640s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.995s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [17.811s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.252s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.058s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.255s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.741s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [37.729s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.696s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.305s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.808s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.696s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:02.571s]
[INFO] CSW UI Module ..................................... SUCCESS [15.955s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.249s]
[INFO] DXF WFS output format ............................. SUCCESS [36.352s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.169s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [30.110s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [24.271s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [15.829s]
[INFO] GeoServer Data Importer ........................... SUCCESS [3.379s]
[INFO] Importer Core Module .............................. SUCCESS [1:12.986s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [34.458s]
[INFO] Importer Web UI Module ............................ SUCCESS [38.720s]
[INFO] Total time: 2:20:25.535s (Wall Clock)
[INFO] Finished at: Sat Sep 26 16:46:30 UTC 2015
[INFO] Final Memory: 79M/232M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
September 26, 2015, 11:24pm
4
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1816/changes> ;
Changes:
[andrea.aime] Adding some tests for WCS 2.0 (tried to get a bug to show, but could not, the extra test coverage is not wasted though)
[andrea.aime] Adding a test for inserts using local namespace uris
[...truncated 16165 lines...]
[INFO] Building GeoServer CAS Security Web Module 2.9-SNAPSHOT
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding a test for inserts using local namespace uris
[INFO] [GitCommitIdMojo] build.commit.time = 26.09.2015 @ 15:07:36 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 26-Sep-2015 22:57
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 23:24:44 UTC
[INFO] [GitCommitIdMojo] build.branch = a74a76d9c4bab0ef3bb8ea3a13f7abcabb3713d4
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a74a76d
[INFO] [GitCommitIdMojo] build.commit.id = a74a76d9c4bab0ef3bb8ea3a13f7abcabb3713d4
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding a test for inserts using local namespace uris
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 23:24:47 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.007s]
[INFO] Core Platform Module .............................. SUCCESS [16.580s]
[INFO] Open Web Service Module ........................... SUCCESS [20.201s]
[INFO] Main Module ....................................... SUCCESS [2:37.972s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.485s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.660s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:05.412s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.947s]
[INFO] Web Coverage Service 1.0 Module ................... FAILURE [43.989s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.717s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:48.068s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.610s]
[INFO] Web Map Service Module ............................ SUCCESS [4:06.771s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:17.310s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:26.946s]
[INFO] REST Support Module ............................... SUCCESS [41.223s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.693s]
[INFO] Core UI Module .................................... SUCCESS [1:54.197s]
[INFO] WMS UI Module ..................................... SUCCESS [58.781s]
[INFO] GWC UI Module ..................................... SUCCESS [1:33.842s]
[INFO] WFS UI Module ..................................... SUCCESS [30.256s]
[INFO] Demoes Module ..................................... SUCCESS [50.891s]
[INFO] WCS UI Module ..................................... SUCCESS [40.076s]
[INFO] Security UI Modules ............................... SUCCESS [0.507s]
[INFO] Security UI Core Module ........................... SUCCESS [2:52.828s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:04.450s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.854s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.450s]
[INFO] Printing Module ................................... SUCCESS [40.465s]
[INFO] Community Space ................................... SUCCESS [0.226s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.260s]
[INFO] Application Schema Support ........................ SUCCESS [0.313s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.317s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.540s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.150s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.445s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.543s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.687s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.613s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.436s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.419s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.260s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.947s]
[INFO] OGR parent ........................................ SUCCESS [0.527s]
[INFO] OGR CORE .......................................... SUCCESS [5.929s]
[INFO] OGR WFS ........................................... SUCCESS [23.906s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.253s]
[INFO] Excel Output Format ............................... SUCCESS [39.563s]
[INFO] Chart external graphics support ................... SUCCESS [1.112s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.707s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.157s]
[INFO] OWS request flow controller ....................... SUCCESS [28.942s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.876s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.857s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.257s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.079s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.272s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.232s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [55.671s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.834s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.228s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.843s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.744s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:29.930s]
[INFO] CSW UI Module ..................................... SUCCESS [26.013s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.300s]
[INFO] DXF WFS output format ............................. SUCCESS [37.085s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.519s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [53.019s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.547s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [24.020s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.538s]
[INFO] Importer Core Module .............................. SUCCESS [1:51.681s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [55.054s]
[INFO] Importer Web UI Module ............................ SUCCESS [37.672s]
[INFO] Total time: 27:13.787s (Wall Clock)
[INFO] Finished at: Sat Sep 26 23:24:47 UTC 2015
[INFO] Final Memory: 79M/248M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
September 29, 2015, 8:29am
5
