[Geoserver-devel] Build failed in Jenkins: geoserver-master #1818
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1818/&gt;
[...truncated 18285 lines...]
  at org.geotools.xml.XSDParserDelegate.endElement(XSDParserDelegate.java:94)
  at org.geotools.xml.impl.DelegatingHandler.endElement(DelegatingHandler.java:129)
  at org.geotools.xml.impl.ParserHandler.endElement(ParserHandler.java:744)
  at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609)
  at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.endElement(XMLSchemaValidator.java:863)
  at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1781)
  at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2957)
  at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
  at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:117)
  at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
  at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
  at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
  at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
  at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
  at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
  at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:333)
  at org.geotools.xml.Parser.parse(Parser.java:240)
  at org.geotools.xml.Parser.parse(Parser.java:170)
  at org.geotools.xml.Parser.parse(Parser.java:219)
  at org.geoserver.wps.web.WPSExecuteTransformerTest.checkValidationErrors(WPSExecuteTransformerTest.java:307)
  at org.geoserver.wps.web.WPSExecuteTransformerTest.testBoundingBoxEncoding(WPSExecuteTransformerTest.java:236)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
[Fatal Error] :2:1: Content is not allowed in prolog.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 23.183 sec
Running org.geoserver.wps.web.WPSRequestBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.241 sec
Results :
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wps ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding 2.8.x branch to the travis builds
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 29.09.2015 @ 07:35:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 30-Sep-2015 15:10
[INFO] [GitCommitIdMojo] build.build.time = 30.09.2015 @ 15:46:58 UTC
[INFO] [GitCommitIdMojo] build.branch = c3ef181956e1122634b8065f3a221678e7780904
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c3ef181
[INFO] [GitCommitIdMojo] build.commit.id = c3ef181956e1122634b8065f3a221678e7780904
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding 2.8.x branch to the travis builds
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wps >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 30.09.2015 @ 15:46:59 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.935s]
[INFO] Core Platform Module .............................. SUCCESS [21.241s]
[INFO] Open Web Service Module ........................... SUCCESS [27.490s]
[INFO] Main Module ....................................... SUCCESS [3:22.583s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.003s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.071s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:09.116s]
[INFO] Web Coverage Service Module ....................... SUCCESS [10.530s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.994s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:06.182s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:46.463s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:41.664s]
[INFO] Web Map Service Module ............................ SUCCESS [4:20.720s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:17.353s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:26.098s]
[INFO] REST Support Module ............................... SUCCESS [48.520s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:31.441s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.739s]
[INFO] Core UI Module .................................... SUCCESS [1:56.607s]
[INFO] WMS UI Module ..................................... SUCCESS [57.943s]
[INFO] GWC UI Module ..................................... SUCCESS [1:25.033s]
[INFO] WFS UI Module ..................................... SUCCESS [35.359s]
[INFO] Demoes Module ..................................... SUCCESS [1:03.149s]
[INFO] WCS UI Module ..................................... SUCCESS [39.008s]
[INFO] Security UI Modules ............................... SUCCESS [0.469s]
[INFO] Security UI Core Module ........................... SUCCESS [2:51.177s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:06.171s]
[INFO] Security UI LDAP Module ........................... SUCCESS [44.853s]
[INFO] REST UI Module .................................... SUCCESS [35.394s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.488s]
[INFO] Printing Module ................................... SUCCESS [40.375s]
[INFO] Community Space ................................... SUCCESS [0.431s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.931s]
[INFO] GeoServer Web Application ......................... SUCCESS [11.727s]
[INFO] Application Schema Support ........................ SUCCESS [0.352s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:50.196s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.400s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.417s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.535s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.824s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.269s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.305s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.962s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.850s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.579s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.666s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.025s]
[INFO] OGR parent ........................................ SUCCESS [0.671s]
[INFO] OGR CORE .......................................... SUCCESS [3.826s]
[INFO] OGR WFS ........................................... SUCCESS [24.647s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.483s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:11.372s]
[INFO] OGR WPS ........................................... SUCCESS [24.749s]
[INFO] Excel Output Format ............................... SUCCESS [43.723s]
[INFO] Chart external graphics support ................... SUCCESS [1.706s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.150s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.145s]
[INFO] OWS request flow controller ....................... SUCCESS [30.051s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.505s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:17.715s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.131s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.011s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.295s]
[INFO] Core Monitor Extension ............................ SUCCESS [28.297s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [19.289s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.252s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.575s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.362s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [9.994s]
[INFO] XLST based WFS output format ...................... SUCCESS [54.835s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:02.731s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.834s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.501s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.784s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [31.266s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:38.988s]
[INFO] CSW UI Module ..................................... SUCCESS [23.851s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.532s]
[INFO] DXF WFS output format ............................. SUCCESS [36.686s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [29.262s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.453s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.647s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [30.577s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [24.006s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.347s]
[INFO] Importer Core Module .............................. FAILURE [1:57.336s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 36:05.991s (Wall Clock)
[INFO] Finished at: Wed Sep 30 15:46:59 UTC 2015
[INFO] Final Memory: 90M/263M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1819/changes&gt;
Changes:
[bradh] Fix env-var name for data dir
[...truncated 18966 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1244 from bradh/patch-2
[INFO] [GitCommitIdMojo] build.commit.time = 01.10.2015 @ 08:12:38 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 01-Oct-2015 09:06
[INFO] [GitCommitIdMojo] build.build.time = 01.10.2015 @ 09:40:53 UTC
[INFO] [GitCommitIdMojo] build.branch = 3ea15561c5a55711a6d3983dac38e3df99896641
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3ea1556
[INFO] [GitCommitIdMojo] build.commit.id = 3ea15561c5a55711a6d3983dac38e3df99896641
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1244 from bradh/patch-2
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 01.10.2015 @ 09:40:56 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.703s]
[INFO] Core Platform Module .............................. SUCCESS [16.061s]
[INFO] Open Web Service Module ........................... SUCCESS [20.110s]
[INFO] Main Module ....................................... SUCCESS [2:32.437s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.447s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.349s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:05.361s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.177s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.912s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.455s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:44.986s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:23.801s]
[INFO] Web Map Service Module ............................ SUCCESS [4:17.481s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:17.344s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:22.776s]
[INFO] REST Support Module ............................... SUCCESS [44.969s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:38.542s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.636s]
[INFO] Core UI Module .................................... SUCCESS [1:49.561s]
[INFO] WMS UI Module ..................................... SUCCESS [57.575s]
[INFO] GWC UI Module ..................................... SUCCESS [1:23.229s]
[INFO] WFS UI Module ..................................... SUCCESS [30.843s]
[INFO] Demoes Module ..................................... SUCCESS [55.685s]
[INFO] WCS UI Module ..................................... SUCCESS [38.209s]
[INFO] Security UI Modules ............................... SUCCESS [0.492s]
[INFO] Security UI Core Module ........................... SUCCESS [2:43.213s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:01.410s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.216s]
[INFO] REST UI Module .................................... SUCCESS [34.267s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.364s]
[INFO] Printing Module ................................... SUCCESS [37.274s]
[INFO] Community Space ................................... SUCCESS [0.268s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.810s]
[INFO] GeoServer Web Application ......................... SUCCESS [18.658s]
[INFO] Application Schema Support ........................ SUCCESS [0.249s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:39.435s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.352s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.144s]
[INFO] GeoSearch Index Module ............................ SUCCESS [31.415s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.563s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.723s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.817s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.567s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.011s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.736s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.439s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.825s]
[INFO] OGR parent ........................................ SUCCESS [0.352s]
[INFO] OGR CORE .......................................... SUCCESS [4.981s]
[INFO] OGR WFS ........................................... SUCCESS [29.324s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.400s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:14.847s]
[INFO] OGR WPS ........................................... SUCCESS [29.446s]
[INFO] Excel Output Format ............................... SUCCESS [39.025s]
[INFO] Chart external graphics support ................... SUCCESS [1.320s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.286s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.947s]
[INFO] OWS request flow controller ....................... SUCCESS [30.712s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [26.218s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:12.306s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.257s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.924s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.320s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.647s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.939s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.499s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [16.212s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.400s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.900s]
[INFO] XLST based WFS output format ...................... SUCCESS [54.106s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.297s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [36.477s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.359s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.845s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.196s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.564s]
[INFO] CSW UI Module ..................................... SUCCESS [23.611s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.181s]
[INFO] DXF WFS output format ............................. SUCCESS [35.942s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [28.738s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.174s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.855s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.248s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [21.022s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.408s]
[INFO] Importer Core Module .............................. FAILURE [1:48.941s]
[INFO] Total time: 34:09.923s (Wall Clock)
[INFO] Finished at: Thu Oct 01 09:40:56 UTC 2015
[INFO] Final Memory: 90M/270M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1820/&gt;
